CPU:RK3288
系统:Android 5.1 RK3288 查看 ddr 当前频率的方式有两种,第一种是通过 adb 查看,第二种是在串口打印中通过指令查看 1、通过 adb 查看 $ adb shell root@rk3288:/ # cd sys/kernel/debug/clk cd sys/kernel/debug/clk root@rk3288:/sys/kernel/debug/clk # cat clk_summary |grep ddr cat clk_summary |grep ddr clk_ddr 0 0 396000000 2、在串口打印中通过指令查看当前ddr频率可以,但是adb中是看不到的。 shell@firefly:/ $ cd sys/dvfs shell@firefly:/sys/dvfs $ ls cpu_temp_enable cpu_temp_target dvfs_tree shell@firefly:/sys/dvfs $ cat dvfs_tree /system/bin/sh: cat: dvfs_tree: Permission denied // 没有权限 1|shell@firefly:/sys/dvfs $ su // 获取root权限 shell@firefly:/sys/dvfs # cat dvfs_tree [ 107.795152] -------------DVFS TREE----------- [ 107.795152] [ 107.795152] [ 107.795205] DVFS TREE: [ 107.795220] | [ 107.795220] |- voltage domain:vd_gpu [ 107.795239] |- current voltage:900000 [ 107.795252] |- current regu_mode:UNKNOWN [ 107.795269] | | [ 107.795269] | |- power domain:pd_gpu, status = OFF, current volt = 900000, current regu_mode = UNKNOWN [ 107.795295] | | | [ 107.795295] | | |- clock: clk_gpu current: rate 198000, volt = 900000, enable_dvfs = ENABLE [ 107.795321] | | |- clk limit(enable):[198000000, 480000000]; last set rate = 198000 [ 107.795336] | | | |- freq = 198000, volt = 900000 [ 107.795350] | | | |- freq = 297000, volt = 950000 [ 107.795363] | | | |- freq = 417000, volt = 1100000 [ 107.795377] | | | |- freq = 480000, volt = 1150000 [ 107.795392] | | |- clock: clk_gpu current: rate 198000, regu_mode = UNKNOWN, regu_mode_en = 0 [ 107.795407] | [ 107.795407] |- voltage domain:vd_logic [ 107.795425] |- current voltage:1125000 [ 107.795437] |- current regu_mode:UNKNOWN [ 107.795452] | | [ 107.795452] | |- power domain:pd_vio, status = OFF, current volt = 0, current regu_mode = UNKNOWN [ 107.795476] | | | [ 107.795476] | | |- clock: aclk_vio1 current: rate 594000, volt = 0, enable_dvfs = ENABLE [ 107.795501] | | |- clk limit(enable):[99000000, 297000000]; last set rate = 594000 [ 107.795516] | | | |- freq = 99000, volt = 1100000 [ 107.795530] | | | |- freq = 297000, volt = 1100000 [ 107.795545] | | |- clock: aclk_vio1 current: rate 594000, regu_mode = UNKNOWN, regu_mode_en = 0 [ 107.795563] | | [ 107.795563] | |- power domain:pd_ddr, status = OFF, current volt = 1125000, current regu_mode = UNKNOWN [ 107.795587] | | | [ 107.795587] | | |- clock: clk_ddr current: rate 456000, volt = 1125000, enable_dvfs = ENABLE // 456000为ddr频率,单位为KHz [ 107.795612] | | |- clk limit(enable):[200000000, 528000000]; last set rate = 456000 [ 107.795626] | | | |- freq = 200000, volt = 1075000 [ 107.795640] | | | |- freq = 300000, volt = 1075000 [ 107.795653] | | | |- freq = 456000, volt = 1125000 [ 107.795666] | | | |- freq = 528000, volt = 1150000 [ 107.795682] | | |- clock: clk_ddr current: rate 456000, regu_mode = UNKNOWN, regu_mode_en = 0 [ 107.795696] | [ 107.795696] |- voltage domain:vd_arm [ 107.795714] |- current voltage:950000 [ 107.795726] |- current regu_mode:UNKNOWN [ 107.795740] | | [ 107.795740] | |- power domain:pd_core, status = OFF, current volt = 950000, current regu_mode = UNKNOWN [ 107.795765] | | | [ 107.795765] | | |- clock: clk_core current: rate 600000, volt = 950000, enable_dvfs = ENABLE [ 107.795789] | | |- clk limit(enable):[126000000, 1800000000]; last set rate = 600000 [ 107.795804] | | | |- freq = 126000, volt = 900000 [ 107.795817] | | | |- freq = 216000, volt = 900000 [ 107.795830] | | | |- freq = 312000, volt = 900000 [ 107.795843] | | | |- freq = 408000, volt = 900000 [ 107.795856] | | | |- freq = 600000, volt = 950000 [ 107.795869] | | | |- freq = 696000, volt = 950000 [ 107.795882] | | | |- freq = 816000, volt = 1000000 [ 107.795895] | | | |- freq = 1008000, volt = 1050000 [ 107.795909] | | | |- freq = 1200000, volt = 1100000 [ 107.795922] | | | |- freq = 1416000, volt = 1200000 [ 107.795936] | | | |- freq = 1512000, volt = 1300000 [ 107.795949] | | | |- freq = 1608000, volt = 1350000 [ 107.795962] | | | |- freq = 1704000, volt = 1350000 [ 107.795975] | | | |- freq = 1800000, volt = 1350000 [ 107.795990] | | |- clock: clk_core current: rate 600000, regu_mode = UNKNOWN, regu_mode_en = 0 [ 107.796004] -------------DVFS TREE END------------ |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
533 浏览 0 评论
803 浏览 1 评论
700 浏览 1 评论
1926 浏览 1 评论
3171 浏览 1 评论
GMT+8, 2024-12-23 01:08 , Processed in 0.797802 second(s), Total 72, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
