Installed file list: out/target/product/rk3288/installed-files.txt
Target system fs image: out/target/product/rk3288/obj/PACKAGING/systemimage_intermediates/system.img Running: mkuserimg.sh -s out/target/product/rk3288/system out/target/product/rk3288/obj/PACKAGING/systemimage_intermediates/system.img ext4 system 1073741824 out/target/product/rk3288/root/file_contexts make_ext4fs -s -T -1 -S out/target/product/rk3288/root/file_contexts -l 1073741824 -a system out/target/product/rk3288/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/rk3288/system Creating filesystem with parameters: Size: 1073741824 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Journal blocks: 4096 Label: Blocks: 262144 Block groups: 8 Reserved block group size: 63 Created filesystem with 1875/65536 inodes and 110947/262144 blocks Construct recovery from boot mkdir -p out/target/product/rk3288/obj/PACKAGING/recovery_patch_intermediates/ PATH=out/host/linux-x86/bin:$PATH out/host/linux-x86/bin/imgdiff out/target/product/rk3288/boot.img out/target/product/rk3288/recovery.img out/target/product/rk3288/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p chunk 0: type 0 start 0 len 7012362 chunk 1: type 2 start 7012362 len 2239232 chunk 2: type 0 start 8354422 len 296330 Construct patches for 3 chunks... patch 0 is 248 bytes (of 7012362) patch 1 is 1378159 bytes (of 1342060) patch 2 is 202 bytes (of 296330) chunk 0: normal ( 0, 7012362) 248 chunk 1: deflate ( 7012362, 2917660) 1378159 (null) chunk 2: normal ( 9930022, 309978) 202 Install system fs image: out/target/product/rk3288/system.img out/target/product/rk3288/system.img+out/target/product/rk3288/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p maxsize=1096212480 blocksize=135168 total=440127133 reserve=11083776 No RK Loader for TARGET_DEVICE rk3288 to otapackage package add resource.img to BOOT and RECOVERY No uboot for uboot/uboot.img to otapackage No trust for uboot/trust.img to otapackage No charge for uboot/charge.img to otapackage No parameter for TARGET_DEVICE rk3288 to otapackage Package target files: out/target/product/rk3288/obj/PACKAGING/target_files_intermediates/rk3288-target_files-eng.root.zip building image from target_files RECOVERY... Traceback (most recent call last): File "./build/tools/releasetools/make_recovery_patch", line 68, in main(sys.argv[1:]) File "./build/tools/releasetools/make_recovery_patch", line 39, in main input_dir, "RECOVERY") File "/media/liw/173d54d9-5bc8-4998-a41d-77fa4e377b61/rk3288_box_sdk_5.1/build/tools/releasetools/common.py", line 419, in GetBootableImage info_dict) File "/media/liw/173d54d9-5bc8-4998-a41d-77fa4e377b61/rk3288_box_sdk_5.1/build/tools/releasetools/common.py", line 376, in BuildBootableImage p4 = Run(sign_cmd) File "/media/liw/173d54d9-5bc8-4998-a41d-77fa4e377b61/rk3288_box_sdk_5.1/build/tools/releasetools/common.py", line 86, in Run return subprocess.Popen(args, **kwargs) File "/usr/lib/python2.7/subprocess.py", line 710, in __init__ errread, errwrite) File "/usr/lib/python2.7/subprocess.py", line 1327, in _execute_child raise child_exception OSError: [Errno 2] No such file or directory make: *** [out/target/product/rk3288/obj/PACKAGING/target_files_intermediates/rk3288-target_files-eng.root.zip] 错误 1 #### make failed to build some targets (03:16 (mm:ss)) #### 解决的方法: device/rockchip/common/releasetools.py 138行try缩进有问题。修改正常即可。 RK总是问题不断。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 00:10 , Processed in 0.987565 second(s), Total 43, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
732
