测试平台
Platform: RK3328 OS: Android 10.0 现象 机器没有内置重力传感器,所以部分强制竖屏的App(例如360)在上面显示有问题,所以我们强制所有App都横屏显示。 解决方案 以抖音为例,修改方法及效果如下所示 1. 强制横屏,居中竖屏显示 屏幕保持横屏,app竖屏居中如图所示 修改方案: 1.build.prop添加属性设置 persist.sys.forced_orient=2 ro.target.product=box 2.代码强制 diff --git a/frameworks/base/services/core/java/com/android/server/wm/DisplayRotation.java b/frameworks/base/services/core/java/com/android/server/wm/DisplayRotation.java index f2879ce..5a9c1ba 100644 --- a/frameworks/base/services/core/java/com/android/server/wm/DisplayRotation.java +++ b/frameworks/base/services/core/java/com/android/server/wm/DisplayRotation.java @@ -245,10 +245,12 @@ public class DisplayRotation { void configure(int width, int height, int shortSizeDp, int longSizeDp) { 。.. 。.. 。.. // $ adb shell wm size reset && !“true”.equals(SystemProperties.get(“config.override_forced_orient”)); - if(“2”.equals(SystemProperties.get(“persist.sys.forced_orient”,“0”)) + if(“2”.equals(SystemProperties.get(“persist.sys.forced_orient”,“0”)) &&“box”.equals(SystemProperties.get(“ro.target.product”,“unknow”))){ mDefaultFixedToUserRotation = true; } + mDefaultFixedToUserRotation = true; + } 2. 强制横屏,全屏显示 屏幕保持横屏,app全屏如图所示 修改方案: diff --git a/frameworks/base/services/core/java/com/android/server/wm/DisplayContent.java b/frameworks/base/services/core/java/com/android/server/wm/DisplayContent.java index cb38bac..81e345d 100644 --- a/frameworks/base/services/core/java/com/android/server/wm/DisplayContent.java +++ b/frameworks/base/services/core/java/com/android/server/wm/DisplayContent.java @@ -27,6 +27,7 @@ import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_BEHIND; import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_UNSET; import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_UNSPECIFIED; import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_USER; +import static android.content.pm.ActivityInfo.SCREEN_ORIENTATION_LANDSCAPE; import static android.content.res.Configuration.ORIENTATION_LANDSCAPE; import static android.content.res.Configuration.ORIENTATION_PORTRAIT; import static android.os.Trace.TRACE_TAG_WINDOW_MANAGER; @@ -1323,7 +1324,8 @@ class DisplayContent extends WindowContainer《DisplayContent.DisplayChildWindowCo private boolean updateOrientat |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
304 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4374 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1798 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2354 浏览 0 评论
2356 浏览 0 评论
/9
GMT+8, 2025-12-1 21:27 , Processed in 0.670751 second(s), Total 73, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1539
