正常测试平台
latform: RK3328 OS: Android10.0 现象 在3328 android10.0上开发app,发现无法监听音量,在3399 分析解决 查看代码发现在PhoneWindowManager.java中根据mUseTvRouting || mHandleVolumeKeysInWM的值会决定重量键是否下发到app frameworks/base/services/core/java/com/android/server/policy/PhoneWindowManager.java private long interceptKeyBeforeDispatchingInner(WindowState win, KeyEvent event, 。..。 } else if (keyCode == KeyEvent.KEYCODE_VOLUME_UP || keyCode == KeyEvent.KEYCODE_VOLUME_DOWN || keyCode == KeyEvent.KEYCODE_VOLUME_MUTE) { if (mUseTvRouting || mHandleVolumeKeysInWM) { // On TVs or when the configuration is enabled, volume keys never // go to the foreground app. dispatchDirectAudioEvent(event); return -1; } 打印日志发现 mUseTvRouting:true,mHandleVolumeKeysInWM:false mUseTvRouting = AudioSystem.getPlatformType(mContext) == AudioSystem.PLATFORM_TELEVISION; mHandleVolumeKeysInWM = mHandleVolumeKeysInWM = mContext.getResources().getBoolean( com.android.internal.R.bool.config_handleVolumeKeysInWindowManager); 查看AudioSystem代码可知: frameworks/base/media/java/android/media/AudioSystem.java public static int getPlatformType(Context context) { if (context.getResources().getBoolean(com.android.internal.R.bool.config_voice_capable)) { return PLATFORM_VOICE; } else if (context.getPackageManager().hasSystemFeature(PackageManager.FEATURE_LEANBACK) || “box”.equals(SystemProperties.get(“ro.target.product”, “unknown”))) { return PLATFORM_TELEVISION; } else { return PLATFORM_DEFAULT; } } 系统没有声明PackageManager.FEATURE_LEANBACK的权限,但是ro.target.product=box 所以我们把 else if (context.getPackageManager().hasSystemFeature(PackageManager.FEATURE_LEANBACK) || “box”.equals(SystemProperties.get(“ro.target.product”, “unknown”))) {undefined 修改为 else if (context.getPackageManager().hasSystemFeature(PackageManager.FEATURE_LEANBACK)) {undefined 编译更新后重启,发现音量按键不但无法监听,连音量都无法调节 继续查看代码,发现PhoneWindowManager中还有一个地方会截获按键 // Maps global key codes to the components that will handle them. private GlobalKeyManager mGlobalKeyManager; 。.. public int interceptKeyBeforeQueueing(KeyEvent event, int policyFlags) { … // If the key would be handled globally, just return the result, don’t worry about special // key processing. if (isValidGlobalKey(keyCode) && mGlobalKeyManager.shouldHandleGlobalKey(keyCode, event)) { if (isWakeKey) { wakeUp(event.getEventTime(), mAllowTheaterModeWakeFromKey, PowerManager.WAKE_REASON_WAKE_KEY, “android.policy:KEY”); } return result; } GlobalKeyManager的作用是把指定按键事件转发到特定的app接收,转发按键定义在 com.android.internal.R.xml.global_keys 查看global_keys的值 find device/rockchip/ -name “global_keys.xml” device/rockchip/common/tv/overlay/frameworks/base/core/res/res/xml/global_keys.xml device/rockchip/rk3328/rk3328_box/overlay/frameworks/base/core/res/res/xml/global_keys.xml device/rockchip/rk3328/roc_rk3328_pc_32/overlay/frameworks/base/core/res/res/xml/global_keys.xml device/rockchip/rk3328/rk3328_atv/overlay/frameworks/base/core/res/res/xml/global_keys.xml device/rockchip/rk3328/rk3328_box_32/overlay/frameworks/base/core/res/res/xml/global_keys.xml device/rockchip/rk3328/roc_rk3328_pc/overlay/frameworks/base/core/res/res/xml/global_keys.xml device/rockchip/rk3328/overlay/frameworks/base/core/res/res/xml/global_keys.xml cat device/rockchip/rk3328/overlay/frameworks/base/core/res/res/xml/global_keys.xml 《?xml version=“1.0” encoding=“utf-8”?》 《global_keys version=“1”》 《!-- Example format: id = keycode to handle globally. component = component which will handle this key. --》 《key keyCode=“KEYCODE_GUIDE” component=“com.google.android.tv/.receiver.GlobalKeyReceiver” /》 《key keyCode=“KEYCODE_TV” component=“com.google.android.tv/.receiver.GlobalKeyReceiver” /》 《key keyCode=“KEYCODE_TV_INPUT” component=“com.google.android.tv/.receiver.GlobalKeyReceiver” /》 《key keyCode=“KEYCODE_TV_POWER” component=“com.google.android.athome.globalkeyinterceptor/.Receiver” /》 《key keyCode=“KEYCODE_PAIRING” component=“com.google.android.athome.globalkeyinterceptor/.Receiver” /》 《key keyCode=“KEYCODE_VOLUME_UP” component=“com.google.android.athome.globalkeyinterceptor/.Receiver” /》 《key keyCode=“KEYCODE_VOLUME_DOWN” component=“com.google.android.athome.globalkeyinterceptor/.Receiver” /》 《/global_keys》 可以看出音量按键截获并转发给了com.google.android.athome.globalkeyinterceptor/.Receiver 由于系统内并没有内置对应的apk,导致音量调节无效。 删除所有global_keys.xml中音量按键转发 编译更新后测试正常,音量可以正常调节,app也可以监听到音量键事件。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1268 浏览 1 评论
RK3568平台,进入烧录模式,部分电脑提示无法识别,无法烧录
4270 浏览 1 评论
【RK3568 Android11.0】如何在设置-显示-HDMI-分辨率设置中添加3840*2160的选项?
6867 浏览 1 评论
瑞芯微第二代8nm高性能AIOT平台 RK3576 详细介绍
1707 浏览 0 评论
7132 浏览 1 评论
GMT+8, 2024-5-9 08:50 , Processed in 0.674591 second(s), Total 74, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
