硬件平台: firefly rk3399
操作系统: Ubuntu 16.04(官方SDK) 开发环境: Ubuntu 16.04 1 前言 PC通过WiFi或者以太网登录rk3399 板端Ubuntu16.04,Ubuntu16.04默认是动态IP,所以会出现IP变动的情况,板端IP变动,则导致SSH终端登录失败。此时只能通过板端串口Dbug口去查询板端IP地址,显得繁琐。因此,有必要将rk3399 板端固定为静态IP。 2 设置方法 第一步:查询网络配置文件: cat /etc/network/interfaces firefly@firefly:~$ cat /etc/network/interfaces # interfaces(5) file used by ifup(8) and ifdown(8) # Include files from /etc/network/interfaces.d: source-directory /etc/network/interfaces.d auto wlan0 iface wlan0 inet dhcp 此时,可以看出wlan0网卡设置为动态获取IP的模式。 第二步:重新配置网络配置文件,键入如下内容: sudo vi /etc/network/interfaces iface wlan0 inet static address 192.168.0.105 netmask 255.255.255.0 gateway 192.168.0.1 broadcast 192.168.0.255
第三步:设置服务器dns:vi /etc/resolv.conf nameserver 116.77.76.254 nameserver 116.77.76.253
第四步,重启网卡 sudo /etc/init.d/networking restart 第五步:外网ping测试,能正常ping通说明配置生效 firefly@firefly:~$ ping baidu.com PING baidu.com (39.156.69.79) 56(84) bytes of data. 64 bytes from 39.156.69.79: icmp_seq=1 ttl=46 time=45.3 ms 64 bytes from 39.156.69.79: icmp_seq=3 ttl=46 time=51.4 ms 64 bytes from 39.156.69.79: icmp_seq=4 ttl=46 time=54.1 ms 64 bytes from 39.156.69.79: icmp_seq=5 ttl=46 time=51.4 ms 第六步:重启系统,查看IP地址及能否访问Internet firefly@firefly:~$sudo reboot firefly@firefly:~$ ifconfig eth0 Link encap:Ethernet HWaddr 36:ee:b6:48:de:ea UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:7 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:858 (858.0 B) Interrupt:24 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:5 errors:0 dropped:0 overruns:0 frame:0 TX packets:5 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:365 (365.0 B) TX bytes:365 (365.0 B) wlan0 Link encap:Ethernet HWaddr cc:4b:73:85:5d:66 inet addr:192.168.0.105 Bcast:192.168.0.255 Mask:255.255.255.0 inet6 addr: fe80::ce4b:73ff:fe85:5d66/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:37 errors:0 dropped:0 overruns:0 frame:0 TX packets:79 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:4382 (4.3 KB) TX bytes:12320 (12.3 KB) |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
304 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4374 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1798 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2354 浏览 0 评论
2356 浏览 0 评论
/9
GMT+8, 2025-12-1 22:12 , Processed in 0.753710 second(s), Total 73, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2572
