1. 主板型号:AIO-3399J
2. 芯片型号:RK3399 3. 操作系统版本:Android 7.1 4. Linux版本:v4.4.103 PWM(Pulse Width Modulation)控制——脉冲宽度调制技术,通过对一系列脉冲的宽度进行调制,来等效地获得所需要波形(含形状和幅值),驱动的设备是雷达扫描电机RPLIDARA3M1内部带有具有可调速功能的电机驱动器,可通过接口中MOTOCTL信号对旋转电机的启动、停止以及旋转速度进行控制。MOTOCTL可视为特定频率和占空比的PWM信号,此时电机的旋转速度将取决于输入MOTOCTL PWM信号的占空比,它的典型值为25000HZ的方波信号,雷达旋转频率10Hz的高脉宽占空比60%。 5、配置 PWM DTS 节点
6、 开发PWM 内核驱动:kernel/drivers/pwm/pwm-rockchip.c 实现基本的PWM字符驱动程序,实现以下模块:初始化设备、设备打开、PWM数据的读写和控制、设备释放、设备卸载。 #include #include #include #include #include #include #include #include #include #define PWM_CTRL_TIMER_EN (1 << 0) #define PWM_CTRL_OUTPUT_EN (1 << 3) #define PWM_ENABLE (1 << 0) #define PWM_CONTINUOUS (1 << 1) #define PWM_DUTY_POSITIVE (1 << 3) #define PWM_DUTY_NEGATIVE (0 << 3) #define PWM_INACTIVE_NEGATIVE (0 << 4) #define PWM_INACTIVE_POSITIVE (1 << 4) #define PWM_POLARITY_MASK (PWM_DUTY_POSITIVE | PWM_INACTIVE_POSITIVE) #define PWM_OUTPUT_LEFT (0 << 5) #define PWM_LOCK_EN (1 << 6) #define PWM_LP_DISABLE (0 << 8) struct rockchip_pwm_chip { struct pwm_chip chip; struct clk *clk; struct clk *pclk; const struct rockchip_pwm_data *data; void __iomem *base; }; struct rockchip_pwm_regs { unsigned long duty; unsigned long period; unsigned long cntr; unsigned long ctrl; }; struct rockchip_pwm_data { struct rockchip_pwm_regs regs; unsigned int prescaler; bool supports_polarity; bool supports_lock; u32 enable_conf; u32 enable_conf_mask; }; static inline struct rockchip_pwm_chip *to_rockchip_pwm_chip(struct pwm_chip *c) { return container_of(c, struct rockchip_pwm_chip, chip); } static void rockchip_pwm_get_state(struct pwm_chip *chip, struct pwm_device *pwm, struct pwm_state *state) { struct rockchip_pwm_chip *pc = to_rockchip_pwm_chip(chip); u32 enable_conf = pc->data->enable_conf; unsigned long clk_rate; u64 tmp; u32 val; int ret; ret = clk_enable(pc->pclk); if (ret) return; clk_rate = clk_get_rate(pc->clk); tmp = readl_relaxed(pc->base + pc->data->regs.period); tmp *= pc->data->prescaler * NSEC_PER_SEC; state->period = DIV_ROUND_CLOSEST_ULL(tmp, clk_rate); tmp = readl_relaxed(pc->base + pc->data->regs.duty); tmp *= pc->data->prescaler * NSEC_PER_SEC; state->duty_cycle = DIV_ROUND_CLOSEST_ULL(tmp, clk_rate); val = readl_relaxed(pc->base + pc->data->regs.ctrl); if (pc->data->supports_polarity) state->enabled = ((val & enable_conf) != enable_conf) ? false : true; else state->enabled = ((val & enable_conf) == enable_conf) ? true : false; if (pc->data->supports_polarity) { if (!(val & PWM_DUTY_POSITIVE)) state->polarity = PWM_POLARITY_INVERSED; } clk_disable(pc->pclk); } //配置PWM周期和占空比 static void rockchip_pwm_config(struct pwm_chip *chip, struct pwm_device *pwm, struct pwm_state *state) { struct rockchip_pwm_chip *pc = to_rockchip_pwm_chip(chip); unsigned long period, duty; u64 clk_rate, div; u32 ctrl; clk_rate = clk_get_rate(pc->clk); div = clk_rate * state->period; period = DIV_ROUND_CLOSEST_ULL(div, pc->data->prescaler * NSEC_PER_SEC); div = clk_rate * state->duty_cycle; duty = DIV_ROUND_CLOSEST_ULL(div, pc->data->prescaler * NSEC_PER_SEC); ctrl = readl_relaxed(pc->base + pc->data->regs.ctrl); if (pc->data->supports_lock) { ctrl |= PWM_LOCK_EN; writel_relaxed(ctrl, pc->base + pc->data->regs.ctrl); } writel(period, pc->base + pc->data->regs.period); writel(duty, pc->base + pc->data->regs.duty); if (pc->data->supports_polarity) { ctrl &= ~PWM_POLARITY_MASK; if (state->polarity == PWM_POLARITY_INVERSED) ctrl |= PWM_DUTY_NEGATIVE | PWM_INACTIVE_POSITIVE; else ctrl |= PWM_DUTY_POSITIVE | PWM_INACTIVE_NEGATIVE; } if (pc->data->supports_lock) ctrl &= ~PWM_LOCK_EN; writel(ctrl, pc->base + pc->data->regs.ctrl); #ifdef CONFIG_FB_ROCKCHIP if (!pc->data->regs.ctrl) { int ret; ret = rk_fb_set_vop_pwm(); if (ret) dev_err(pc->chip.dev, "rk_fb_set_vop_pwm failed: %dn", ret); } #endif } static int rockchip_pwm_enable(struct pwm_chip *chip, struct pwm_device *pwm, bool enable) { struct rockchip_pwm_chip *pc = to_rockchip_pwm_chip(chip); u32 enable_conf = pc->data->enable_conf; int ret; u32 val; if (enable) { ret = clk_enable(pc->clk); if (ret) return ret; } val = readl_relaxed(pc->base + pc->data->regs.ctrl); val &= ~pc->data->enable_conf_mask; if (enable) val |= enable_conf; else val &= ~enable_conf; writel_relaxed(val, pc->base + pc->data->regs.ctrl); if (!enable) clk_disable(pc->clk); return 0; } static int rockchip_pwm_apply(struct pwm_chip *chip, struct pwm_device *pwm, struct pwm_state *state) { struct rockchip_pwm_chip *pc = to_rockchip_pwm_chip(chip); struct pwm_state curstate; bool enabled; int ret = 0; ret = clk_enable(pc->pclk); if (ret) return ret; pwm_get_state(pwm, &curstate); enabled = curstate.enabled; if (state->polarity != curstate.polarity && enabled && !pc->data->supports_lock) { ret = rockchip_pwm_enable(chip, pwm, false); if (ret) goto out; enabled = false; } rockchip_pwm_config(chip, pwm, state); if (state->enabled != enabled) { ret = rockchip_pwm_enable(chip, pwm, state->enabled); if (ret) goto out; } rockchip_pwm_get_state(chip, pwm, state); out: clk_disable(pc->pclk); return ret; } static const struct pwm_ops rockchip_pwm_ops = { .get_state = rockchip_pwm_get_state, .apply = rockchip_pwm_apply, .owner = THIS_MODULE, }; static const struct rockchip_pwm_data pwm_data_v1 = { .regs = { .duty = 0x04, .period = 0x08, .cntr = 0x00, .ctrl = 0x0c, }, .prescaler = 2, .supports_polarity = false, .supports_lock = false, .enable_conf = PWM_CTRL_OUTPUT_EN | PWM_CTRL_TIMER_EN, .enable_conf_mask = BIT(1) | BIT(3), }; static const struct rockchip_pwm_data pwm_data_v2 = { .regs = { .duty = 0x08, .period = 0x04, .cntr = 0x00, .ctrl = 0x0c, }, .prescaler = 1, .supports_polarity = true, .supports_lock = false, .enable_conf = PWM_OUTPUT_LEFT | PWM_LP_DISABLE | PWM_ENABLE | PWM_CONTINUOUS, .enable_conf_mask = GENMASK(2, 0) | BIT(5) | BIT(8), }; static const struct rockchip_pwm_data pwm_data_vop = { .regs = { .duty = 0x08, .period = 0x04, .cntr = 0x0c, .ctrl = 0x00, }, .prescaler = 1, .supports_polarity = true, .supports_lock = false, .enable_conf = PWM_OUTPUT_LEFT | PWM_LP_DISABLE | PWM_ENABLE | PWM_CONTINUOUS, .enable_conf_mask = GENMASK(2, 0) | BIT(5) | BIT(8), }; static const struct rockchip_pwm_data pwm_data_v3 = { .regs = { .duty = 0x08, .period = 0x04, .cntr = 0x00, .ctrl = 0x0c, }, .prescaler = 1, .supports_polarity = true, .supports_lock = true, .enable_conf = PWM_OUTPUT_LEFT | PWM_LP_DISABLE | PWM_ENABLE | PWM_CONTINUOUS, .enable_conf_mask = GENMASK(2, 0) | BIT(5) | BIT(8), }; static const struct of_device_id rockchip_pwm_dt_ids[] = { { .compatible = "rockchip,rk2928-pwm", .data = &pwm_data_v1}, { .compatible = "rockchip,rk3288-pwm", .data = &pwm_data_v2}, { .compatible = "rockchip,rk3328-pwm", .data = &pwm_data_v3}, { .compatible = "rockchip,vop-pwm", .data = &pwm_data_vop}, { .compatible = "rockchip,rk3399-pwm", .data = &pwm_data_v2}, { /* sentinel */ } }; MODULE_DEVICE_TABLE(of, rockchip_pwm_dt_ids); static int rockchip_pwm_probe(struct platform_device *pdev) { const struct of_device_id *id; struct rockchip_pwm_chip *pc; struct resource *r; int ret, count; id = of_match_device(rockchip_pwm_dt_ids, &pdev->dev); if (!id) return -EINVAL; pc = devm_kzalloc(&pdev->dev, sizeof(*pc), GFP_KERNEL); if (!pc) return -ENOMEM; r = platform_get_resource(pdev, IORESOURCE_MEM, 0); pc->base = devm_ioremap(&pdev->dev, r->start, resource_size(r)); if (IS_ERR(pc->base)) return PTR_ERR(pc->base); pc->clk = devm_clk_get(&pdev->dev, "pwm"); if (IS_ERR(pc->clk)) { pc->clk = devm_clk_get(&pdev->dev, NULL); if (IS_ERR(pc->clk)) { ret = PTR_ERR(pc->clk); if (ret != -EPROBE_DEFER) dev_err(&pdev->dev, "Can't get bus clk: %dn", ret); return ret; } } count = of_count_phandle_with_args(pdev->dev.of_node, "clocks", "#clock-cells"); if (count == 2) pc->pclk = devm_clk_get(&pdev->dev, "pclk"); else pc->pclk = pc->clk; if (IS_ERR(pc->pclk)) { ret = PTR_ERR(pc->pclk); if (ret != -EPROBE_DEFER) dev_err(&pdev->dev, "Can't get APB clk: %dn", ret); return ret; } ret = clk_prepare_enable(pc->clk); if (ret) { dev_err(&pdev->dev, "Can't prepare enable bus clk: %dn", ret); return ret; } ret = clk_prepare(pc->pclk); if (ret) { dev_err(&pdev->dev, "Can't prepare APB clk: %dn", ret); goto err_clk; } platform_set_drvdata(pdev, pc); pc->data = id->data; pc->chip.dev = &pdev->dev; pc->chip.ops = &rockchip_pwm_ops; pc->chip.base = -1; pc->chip.npwm = 1;//PWM通道数 if (pc->data->supports_polarity) { pc->chip.of_xlate = of_pwm_xlate_rockchip_pwm_chipwith_flags; pc->chip.of_pwm_n_cells = 3; } //填充的struct rockchip_pwm_chip(PWM芯片的描述、芯片提供的PWM器件数量以及支持的PWM操作的芯片)作为参数 ret = pwmchip_add(&pc->chip); if (ret < 0) { clk_unprepare(pc->clk); dev_err(&pdev->dev, "pwmchip_add() failed: %dn", ret); goto err_pclk; } /* PWM clk enabled */ if (!pwm_is_enabled(pc->chip.pwms)) clk_disable(pc->clk); return 0; err_pclk: clk_unprepare(pc->pclk); err_clk: clk_disable_unprepare(pc->clk); return ret; } static int rockchip_pwm_remove(struct platform_device *pdev) { struct rockchip_pwm_chip *pc = platform_get_drvdata(pdev); if (pwm_is_enabled(pc->chip.pwms)) clk_disable(pc->clk); clk_unprepare(pc->pclk); clk_unprepare(pc->clk); return pwmchip_remove(&pc->chip); } static struct platform_driver rockchip_pwm_driver = { .driver = { .name = "rockchip-pwm", .of_match_table = rockchip_pwm_dt_ids, }, .probe = rockchip_pwm_probe, .remove = rockchip_pwm_remove, }; module_platform_driver(rockchip_pwm_driver); 7、控制 PWM 设备 7.1、查看当前PWM设备 cat /sys/kernel/debug/pwm 7.2、打开pwm1的占空比60% rk3399_firefly_edp_box:/ # echo 10000 > /sys/pwm/pwm 7.3、关闭pwm1的占空比 rk3399_firefly_edp_box:/ # echo 25000 > /sys/pwm/pwm |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 12:21 , Processed in 0.710422 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1302
