1个回答
1.编译u-boot 产生错误:make: *** 没有规则可以创建“include/config/uboot.release”需要的目标“include
解决问题:清理文件即可 make distclean 2.编译kernel 产生错误:make[1]: *** [scripts/Makefile.build:411:scripts/dtc] 错误 2 解决问题:由于gcc 版本过高,可以安装gcc-7 #1.查看当前系统gcc 版本 gcc -v #2.下载gcc 7 版本 apt install gcc-7 apt install g++-7 #3.添加gcc 优先级 sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 70 --slave /usr/bin/g++ g++ /usr/bin/g++-7 #4.将当前系统gcc 版本添加优先级 sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-10 100 --slave /usr/bin/g++ g++ /usr/bin/g++-10 #5.配置优先级,根据序号选择默认使用的 gcc 版本 sudo update-alternatives --config gcc 安装之后,切换成gcc-7 版本,清理kernel 文件,重新编译: make distclean make ARCH=arm rockchip_defconfig make ARCH=arm rk3288-miniarm.img 3.编译android 出现问题:Jack server failed to (re)start, try 'jack-diagnose' or see Jack server log No Jack server running. Try 'jack-admin start-server' No Jack server running. Try 'jack-admin start-server' ninja: build stopped: subcommand failed. make: *** [build/core/ninja.mk:149:ninja_wrapper] 错误 1 解决问题:打开文件 $HOME/.jack-settings以及 $HOME/.jack-server/config.properties,修改其中的端口号,端口号值为0~65535,两个文件端口号要保持一致。 如果还不能解决:请尝试make -j2 ,不要单纯使用make,要带参数。 4.编译android 出现问题:Communication error with Jack server (35), try 'jack-diagnose' or see Jack server log SSL error when connecting to the Jack server. Try 'jack-diagnose' SSL error when connecting to the Jack server. Try 'jack-diagnose' ninja: build stopped: subcommand failed. make: *** [build/core/ninja.mk:149:ninja_wrapper] 错误 1 解决问题:将禁用的 TLSv1, TLSv1.1 删除: 打开 gedit dit /etc/java-8-openjdk/security/java.security ,将 jdk.certpath.disabledAlgorithms=MD2, TLSv1, TLSv1.1, MD5, SHA1 jdkCA & usage TLSServer, RSA keySize < 1024, DSA keySize < 1024, EC keySize < 224, include jdk.disabled.namedCurves 修改为: jdk.certpath.disabledAlgorithms=MD2, MD5, SHA1 jdkCA & usage TLSServer, RSA keySize < 1024, DSA keySize < 1024, EC keySize < 224, include jdk.disabled.namedCurves 5.编译android 出现问题:flex-2.5.39: loadlocale.c:130:_nl_intern_locale_data: ?? 'cnt < (sizeof (_nl_value_type_LC_TIME) / sizeof (_nl_value_type_LC_TIME[0]))' ??? Aborted (core dumped) ninja: build stopped: subcommand failed. make: *** [build/core/ninja.mk:149:ninja_wrapper] 错误 1 解决问题:gedit ~/.bashrc 在最后添加 export LC_ALL=C ,再source ~/.bashrc |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 09:36 , Processed in 0.540851 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1431
