platform接口学习
//返回dev中类型为type的,第num个资源 struct resource *platform_get_resource(struct platfrom_device *dev, unsigned int type, unsigned int num); //返回该dev所用的第num个中断号 int platform_get_irq(struct platform_device *dev, unsigned int num); //通过名字返回dev的给类型的资源 struct resource *platform_get_resource_byname(struct platform_device *dev, unsigned int type, const char *name); //名字名称给dev的中断号 )int platform_dev_irq_byname(结构体平台_开发者,* 对o返回的设备_开发板_获取程序 ,继续的预测板_一个_led。 chip_demoo_gpio.c,一个是资源文件一个是硬件操作代码。 所以这次的修改方向是
我理解的平台总线的结构:
代码内容 Makefile KERN_DIR = /home/book/Documents/100ask_firefly-rk3288/linux-4.4 all: make -C $(KERN_DIR) M=`pwd` modules $(CROSS_COMPILE)gcc -o led_app led_app.c -Wno-error=未使用但设置变量 clean: make -C $(KERN_DIR) M=`pwd` modules clean rm -rf modules.order rm -f hello_drv_test #myled_drv-y:=led_drv.o board_demoo.o obj-m += board_A_led.o chip_demoo_gpio.o led_drv.o board_A_led.c: #include #include #include #include "led_resource.h" struct resource led_resources [] = { { .start = GROUP_PIN(8,1), .flags = IORESOURCE_IRQ, .name = "myled0", }, { .start = GROUP_PIN(8,2), .flags = IORESOURCE_IRQ, .name = "myled1", }, } ; struct resource *get_led_resource(void) { return led_resources; } static void led_dev_release(struct device *pdev) { } static struct platform_device led_device = { .name = "myled", .resource = led_resources, .num_resources = ARRAY_SIZE(led_resources), .dev = { .release = led_dev_release, }, }; 静态 int led_device_init(void) { int err; 错误 = platform_device_register(&led_device); 返回错误; } 静态无效 led_device_exit(void) { platform_device_unregister(&led_device); } module_init(led_device_init); module_exit(led_device_exit); MODULE_LICENSE("GPL"); chip_demoo_gpio.c: #include #include #include #include #include #包括“led_resource.h” #include“ #include "led_drv.h" static unsigned int led_pins[100]; 静态整数 resPinCount; #define CRU_BASE_PHY_ADDRESS ((unsigned long)(0xff760000)) #define GRF_BASE_PHY_ADDRESS ((unsigned long)(0xff770000)) #define GPIO8_BASE_PHY_ADDRESS ((unsigned long)(0xff7f0000)) #define CRU_CLKGATE14_PHY_CON (0x0198) #define GRF_008ADDRESS ((unsigned long)(0xff7f0000)) #define GRF_0008A GPIO_SWPORTA_PHY_DR (0x0000) #define GPIO_SWPORTA_PHY_DDR (0x0004) static volatile unsigned int *CRU_CLKGATE14_CON; 静态易失性无符号整数*GRF_GPIO8A_IOMUX; 静态易失无符号整数 *GPIO8_SWPORTA_DDR; 静态易失无符号整数 *GPIO8_SWPORTA_DR; 静态 int board_demo_led_init(int which) { printk("%s 哪个 %d", __FUNCTION__, which); if(GROUP(led_pins[which]) == 8) { if(!CRU_CLKGATE14_CON) { CRU_CLKGATE14_CON = ioremap(CRU_BASE_PHY_ADDRESS + CRU_CLKGATE14_PHY_CON, 4); GRF_GPIO8A_IOMUX = ioremap(GRF_BASE_PHY_ADDRESS + GRF_GPIO8A_PHY_IOMUX, 4); GPIO8_SWPORTA_DDR = ioremap(GPIO8_BASE_PHY_ADDRESS + GPIO_SWPORTA_PHY_DDR, 4); GPIO8_SWPORTA_DR = ioremap(GPIO8_BASE_PHY_ADDRESS + GPIO_SWPORTA_PHY_DR, 4); } if(PIN(led_pins[which]) == 1) { *CRU_CLKGATE14_CON = (1<<(8+16)) | (0<<8); *GRF_GPIO8A_IOMUX |= (3<<(2+16)) | (0<<2); *GPIO8_SWPORTA_DDR |= (1<<1); } else if(PIN(led_pins[which]) == 2) { *CRU_CLKGATE14_CON = (1<<(8+16)) | (0<<8); *GRF_GPIO8A_IOMUX |= (3<<(4+16)) | (0<<4); *GPIO8_SWPORTA_DDR |= (1<<2); } } 返回 0; } static int board_demo_led_ctrl(int which, char status) { printk("%s which %d, status %c", __FUNCTION__, which, status); if(PIN(led_pins[which]) == 1) { if(status) { /* on: 输出 0 */ *GPIO8_SWPORTA_DR &= ~(1<<1); } else { /* 关闭:输出 1 */ *GPIO8_SWPORTA_DR |= (1<<1); } } else if(PIN(led_pins[which]) == 2) { if(status) { *GPIO8_SWPORTA_DR &= ~(1<<2); } else { *GPIO8_SWPORTA_DR |= (1<<2); } } 返回 0; } 静态结构 led_operations led_opr = { .init = board_demo_led_init, .ctl = board_demo_led_ctrl, }; 结构 led_operations *get_board_led_ops(void) { 返回 &led_opr; } 静态 int led_platform_driver_probe(struct platform_device *pdev) { int i = 0; 结构资源 *res; while(1) { //1. 获取板 A LED 资源 res = platform_get_resource(pdev, IORESOURCE_IRQ, i); if(res == NULL) { 中断; } led_pins = res->开始; resPinCount++; //2。创建设备 led_class_create_device(i); 我++; } 返回 0; } static int led_platform_driver_remove(struct platform_device *pdev) { struct resource *res; while(1) { //1. get board a led resource res = platform_get_resource(pdev, IORESOURCE_IRQ, resPinCount); if(res == NULL) { break; } //2. destory device led_class_destroy_device(resPinCount); resPinCount--; } return 0; } static struct platform_driver led_driver = { .driver = { .name = "myled", }, .probe = led_platform_driver_probe, .remove = led_platform_driver_remove, }; static int led_platform_driver_init(void) { int err; err = platform_driver_register(&led_driver); register_led_operations(&led_opr); return 0; } static void led_platform_driver_exit(void) { platform_driver_unregister(&led_driver); } module_init(led_platform_driver_init); module_exit(led_platform_driver_exit); MODULE_LICENSE("GPL"); led_drv.c #include #include #include #include #include #include #include #include #include #include "led_ops.h" #include "led_drv.h" static int major = 0; static struct class *led_class; struct led_operations *p_led_ops; void led_class_create_device(int index) { device_create(led_class, NULL, MKDEV(major, index), NULL, "myled%d", index); } void led_class_destroy_device(int index) { device_destroy(led_class, MKDEV(major, index)); } void register_led_operations(struct led_operations *led_opr) { p_led_ops = led_opr; } EXPORT_SYMBOL(led_class_create_device); EXPORT_SYMBOL(led_class_destroy_device); EXPORT_SYMBOL(register_led_operations); static int led_drv_open(struct inode *node, struct file *file) { int minor = iminor(node); printk("%s %s line %dn", __FILE__, __FUNCTION__, __LINE__); p_led_ops->init(minor); return 0; } static ssize_t led_drv_read(struct file *file, char __user *buf, size_t size, loff_t *offset) { printk("%s %s line %dn", __FILE__, __FUNCTION__, __LINE__); return 0; } static ssize_t led_drv_write(struct file *file, const char __user *buf, size_t size, loff_t *offset) { int err; char status; struct inode *inode = file_inode(file); int minor = iminor(inode); printk("%s %s line %dn", __FILE__, __FUNCTION__, __LINE__); err = copy_from_user(&status, buf, 1); printk("write status:%x n", status); p_led_ops->ctl(minor, status); return 1; } |
static int led_drv_close(struct inode *node, struct file *file)
{ printk("%s %s line %dn", __FILE__, __FUNCTION__, __LINE__); return 0; } static struct file_operations led_drv = { .owner = THIS_MODULE, .open = led_drv_open, .read = led_drv_read, .write = led_drv_write, .release = led_drv_close, }; static int __init led_drv_init(void) { int err; major = register_chrdev(0, "myled", &led_drv); led_class = class_create(THIS_MODULE, "led_class"); err = PTR_ERR(led_class); if(IS_ERR(led_class)) { unregister_chrdev(major, "myled"); printk(KERN_WARNING "class creatge failed %dn", err); return -1; } printk("%s %sled_drv_initn", __FILE__, __FUNCTION__); return 0; } static void __exit led_drv_exit(void) { printk("%s %sled_drv_exitn", __FILE__, __FUNCTION__); class_destroy(led_class); unregister_chrdev(major, "myled"); } module_init(led_drv_init); module_exit(led_drv_exit); MODULE_LICENSE("GPL"); MODULE_AUTHOR("chen"); led_drv.h #ifndef __LED_DRV_H_ #define __LED_DRV_H_ void led_class_create_device(int index); void led_class_destroy_device(int index); void register_led_operations(struct led_operations *led_opr); #endif led_ops.h #ifndef __LED_OPS_H_ #define __LED_OPS_H_ struct led_operations { int (*init)(int which); /* init led, which:led num */ int (*ctl)(int which, char status); /* control led, whic:led num,status:0-On 1-Off */ }; struct led_operations *get_board_led_ops(void); #endif led_resource.h #ifndef _LED_RESOUCE_H #define _LED_RESOUCE_H /* bit[31:16] = group */ /* bit[15:0] = which pin */ #define GROUP(x) (x>>16) #define PIN(x) (x&0xffff) #define GROUP_PIN(g, p) ((g<<16| (p))) struct resource *get_led_resource(void); #endif led_app.c: #include #include #include #include #include #include void showUsage(void) { printf("app [dev_path] [on,off]n"); } int main(int argc, char *argv[]) { char status; if(argc < 3) { showUsage(); return -1; } int fd = open(argv[1], O_RDWR); if(fd < 0) { printf("app open device failed path:%s", argv[1]); return -1; } if(0 == strcmp(argv[2], "on")) { status = 1; int ret = write(fd, &status, 1); if(ret <= 0) { printf("app 写入设备失败 %s",argv[2]); 返回-1; } else { printf("app write device %x", status); } } else if(0 == strcmp(argv[2], "off")) { status = 0; int ret = write(fd, &status, 1); if(ret <= 0) { printf("app write device fialed %s",argv[2]); 返回-1; } else { printf("app write device %x", status); } } 返回 0; } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 01:27 , Processed in 0.505400 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1423
