Platform: RK3288 OS: Android 7.1 Kernel: v4.4.83 现象: 手动去设置里面配置静态IP,保存后掉电开机,偶发无法进入系统的情况。 Log: 01-24 14:47:55.696 518 518 I EthernetServiceImpl: Creating EthernetConfigStore 01-24 14:47:55.697 518 518 E IpConfigStore: Bad version on IP configuration file, ignore read 01-24 14:47:55.697 518 518 E System : ****************************************** 01-24 14:47:55.698 518 518 E System : ************ Failure starting system services 01-24 14:47:55.698 518 518 E System : java.lang.RuntimeException: Failed to create service com.android.server.ethernet.EthernetService: service constructor threw an exception 01-24 14:47:55.698 518 518 E System : at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:104) 01-24 14:47:55.698 518 518 E System : at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:67) 01-24 14:47:55.698 518 518 E System : at com.android.server.SystemServer.startOtherServices(SystemServer.java:880) 01-24 14:47:55.698 518 518 E System : at com.android.server.SystemServer.run(SystemServer.java:343) 01-24 14:47:55.698 518 518 E System : at com.android.server.SystemServer.main(SystemServer.java:225) 01-24 14:47:55.698 518 518 E System : at java.lang.reflect.Method.invoke(Native Method) 01-24 14:47:55.698 518 518 E System : at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:912) 01-24 14:47:55.698 518 518 E System : at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:802) 01-24 14:47:55.698 518 518 E System : Caused by: java.lang.reflect.InvocationTargetException 01-24 14:47:55.698 518 518 E System : at java.lang.reflect.Constructor.newInstance0(Native Method) 01-24 14:47:55.698 518 518 E System : at java.lang.reflect.Constructor.newInstance(Constructor.java:430) 01-24 14:47:55.698 518 518 E System : at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:93) 01-24 14:47:55.698 518 518 E System : ... 7 more 01-24 14:47:55.698 518 518 E System : Caused by: java.lang.NullPointerException: Attempt to invoke virtual method 'int android.util.SparseArray.size()' on a null object reference 01-24 14:47:55.698 518 518 E System : at com.android.server.ethernet.EthernetConfigStore.readIpAndProxyConfigurations(EthernetConfigStore.java:44) 01-24 14:47:55.698 518 518 E System : at com.android.server.ethernet.EthernetServiceImpl.(EthernetServiceImpl.java:64) 01-24 14:47:55.698 518 518 E System : at com.android.server.ethernet.EthernetService.(EthernetService.java:30) 01-24 14:47:55.698 518 518 E System : ... 10 more 01-24 14:47:55.698 518 518 D AndroidRuntime: Shutting down VM 原因: 不能开机是因为以太网服务读到的ipconfig.txt文件异常而一直重启服务,导致系统卡住。 而ipconfig.txt异常是因为系统对文件缓存引起,掉电的时候文件内容还没有完全刷到文件中。 临时方案: kris@eco:~/rk3288/frameworks/base diff --git a/services/core/java/com/android/server/net/IpConfigStore.java b/services/core/java/com/an index a1f12f4..ebad5ff 100644 --- a/services/core/java/com/android/server/net/IpConfigStore.java +++ b/services/core/java/com/android/server/net/IpConfigStore.java @@ -186,7 +186,8 @@ public class IpConfigStore { int version = in.readInt(); if (version != 2 && version != 1) { loge("Bad version on IP configuration file, ignore read"); - return null; + return networks; } 此方法只能临时解决无法开机的问题,但是ip的缓存问题还需要更好的方法去解决。 关于缓存: 参考: 文件系统FAQ.pdf |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 00:12 , Processed in 0.640136 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1744
