Platform: Rockchip
OS: Android 6.0 Kernel: 3.10.92 系统默认使用的是12小时制时间格式. 当触摸设置的24小时格式时,会有如下调用: packages/apps/Settings/src/com/android/ettings/DateTimeSettings.java onPreferenceTreeClick -> mTime24Pref.isChecked //触摸选择后返回true set24Hour -> //设置24小时格式 Settings.System.putString(...,Settings.System.TIME_12_24,is24Hour? HOURS_24 : HOURS_12); Settings.System.TIME_12_24的值是"time_12_24"; 所以本质上就是设置database了, 6.0设置的是xml了. root@rk3288:/data/system/users/0 # busybox cat settings_system.xml | grep time_12_24 < 判断是否是12/24小时制其实也是从xml文件里获取: is24Hour -> DateFormat.is24HourFormat -> is24HourFormat -> DataFormat.java Settings.System.getStringForUser(...,Settings.System.TIME_12_24,...); 解决方法: [kris@:~/rk3288/frameworks/base/packages/SettingsProvider]$ g df diff --git a/packages/SettingsProvider/res/values/defaults.xml b/packages/SettingsProvider/res/values/defaults.xml index f8b85c3..dcb6e97 100755 --- a/packages/SettingsProvider/res/values/defaults.xml +++ b/packages/SettingsProvider/res/values/defaults.xml @@ -220,4 +220,7 @@ com.sohu.inputmethod.sogou/.SogouIME + + 24 + diff --git a/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java b/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java index 657af87..908520e 100755 --- a/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java +++ b/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java @@ -2395,6 +2395,10 @@ class DatabaseHelper extends SQLiteOpenHelper { loadIntegerSetting(stmt, Settings.System.POINTER_SPEED, R.integer.def_pointer_speed); //加在loadSystemSettings()中~ + /*Kris, 170418, Use 24-hour format by default.*/ + loadStringSetting(stmt, Settings.System.TIME_12_24, R.string.time_12_24); + /* * IMPORTANT: Do not add any more upgrade steps here as the global, * secure, and system settings are no longer stored in a database |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
304 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4374 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1798 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2354 浏览 0 评论
2356 浏览 0 评论
/9
GMT+8, 2025-12-1 18:47 , Processed in 0.771399 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1744
