CPU:RK3288 系统:Android 5.1 注:系统中自带的模块没有AP6212,相近的只有AP6210,设置为AP6210,直接添加固件也可以正常使用。 此文是手动添加AP6212的例程。 1、在设备树中修改 wifi 芯片为 ap6212, kernel/arch/arm/boot/dts/rk3288-tb_8846.dts diff --git a/kernel/arch/arm/boot/dts/rk3288-tb_8846.dts b/kernel/arch/arm/boot/dts/rk3288-tb_8846.dts index 6a65163..aa5480d 100755--- a/kernel/arch/arm/boot/dts/rk3288-tb_8846.dts+++ b/kernel/arch/arm/boot/dts/rk3288-tb_8846.dts @@ -42,7 +42,7 @@ * rtl8188eu, rtl8723bs, rtl8723bu * esp8089 */ - wifi_chip_type = "ap6330";+ wifi_chip_type = "ap6212"; sdio_vref = <1800>; //1800mv or 3300mv 2、在 Kconfig 文件中增加 AP6212 选项。 /kernel/drivers/net/wireless/Kconfig diff --git a/kernel/drivers/net/wireless/Kconfig b/kernel/drivers/net/wireless/Kconfig index 544aa86..3e1026d 100755--- a/kernel/drivers/net/wireless/Kconfig+++ b/kernel/drivers/net/wireless/Kconfig @@ -84,6 +84,10 @@ choice config AP6210 bool "AP6210" depends on RKWIFI+ + config AP6212+ bool "AP6212"+ depends on RKWIFI config AP6234 bool "AP6234" 3、在配置文件 rockchip_defconfig 中屏蔽旧 wifi 芯片,增加新的 wifi 芯片 kernel/arch/arm/configs/rockchip_defconfig diff --git a/kernel/arch/arm/configs/rockchip_defconfig b/kernel/arch/arm/configs/rockchip_defconfig index e7c697a..5199ec0 100755--- a/kernel/arch/arm/configs/rockchip_defconfig+++ b/kernel/arch/arm/configs/rockchip_defconfig @@ -299,7 +299,7 @@ CONFIG_USB_SIERRA_NET=y CONFIG_RTL8188EU=y CONFIG_ESP8089=y CONFIG_RKWIFI=y-CONFIG_AP6335=y+# CONFIG_AP6335 is not set+CONFIG_AP6212=y # CONFIG_INPUT_MOUSEDEV is not set CONFIG_INPUT_EVDEV=y CONFIG_INPUT_KEYRESET=y 4、此时串口打印中会出现打开文件 fw_bcm43438a1.bin 失败,需要更新 wifi 模块固件。 [ 18.686420] dhdsdio_download_code_file: Open firmware file failed /system/etc/firmware/fw_bcm43438a1.bin [ 18.686430] _dhdsdio_download_firmware: dongle image file download failed WiFI 固件路径:/external/wlan_loader/firmware 将模块供应商提供的固件文件拷贝到此目录下,然后编译烧录。 external/wlan_loader/firmware/fw_bcm43438a1.bin external/wlan_loader/firmware/fw_bcm43438a1_apsta.bin external/wlan_loader/firmware/fw_bcm43438a1_p2p.bin external/wlan_loader/firmware/nvram_ap6212.txt 编译后,系统会将模块固件拷贝到 out/target/product/rk3288/system/etc//firmware/ 目录下 如果只是调试,可以通过 adb 将固件 push 到 /system/etc//firmware/ 目录下,然后重启。 kernel/drivers/net/wireless/rockchip_wlan/rkwifi/rk_wifi_config.c wifi 驱动路径:kernel/net/rfkill/rfkill-wlan.c 如果器件升级,比如器件为AP6212A,供应商给的文件问 nvram_ap6212a.txt,则需要修改下面文件。(直接用以前的 nvram_ap6212.txt 也可以用,但文件不一样,不清楚) 路径:kerneldriversnetwirelessrockchip_wlanrkwifibcmdhddhd_config.c diff --git a/kernel/drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/dhd_config.c b/kernel/drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/dhd_config.c index 39641e1..91d7925 100755--- a/kernel/drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/dhd_config.c+++ b/kernel/drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/dhd_config.c @@ -477,7 +477,7 @@ dhd_conf_set_fw_name_by_chip(dhd_pub_t *dhd, char *fw_path, char *nv_path) strcpy(&fw_path[i+1], bcm43438a0_fw_name[fw_type]); else if (chiprev == BCM43430A1_CHIP_REV) strcpy(&fw_path[i+1], bcm43438a1_fw_name[fw_type]);- strcpy(&nv_path[j+1], "nvram_ap6212.txt");+ strcpy(&nv_path[j+1], "nvram_ap6212a.txt");break; case BCM43340_CHIP_ID: if (chiprev == BCM43340B0_CHIP_REV) 5、BT 驱动中增添代码,支持 AP6212 BT 驱动路径:kernel/net/rfkill/rfkill-bt.c diff --git a/kernel/net/rfkill/rfkill-bt.c b/kernel/net/rfkill/rfkill-bt.c index a1a156c..3070080 100755--- a/kernel/net/rfkill/rfkill-bt.c+++ b/kernel/net/rfkill/rfkill-bt.c @@ -95,6 +95,8 @@ static const char bt_name[] = #else "ap6210_24M" #endif+#elif defined(CONFIG_AP6212) + "ap6212" #elif defined(CONFIG_AP6330) "ap6330" #elif defined(CONFIG_AP6476)@@ -266,7 +268,7 @@ static int rfkill_rk_set_power(void *data, bool blocked) struct rfkill_rk_data *rfkill = data; struct rfkill_rk_gpio *poweron = &rfkill->pdata->poweron_gpio; struct rfkill_rk_gpio *reset = &rfkill->pdata->reset_gpio;-#if defined(CONFIG_AP6210) || defined(CONFIG_AP6335) +#if defined(CONFIG_AP6210) || defined(CONFIG_AP6212) || defined(CONFIG_AP6335) struct rfkill_rk_gpio* rts = &rfkill->pdata->rts_gpio; struct pinctrl *pinctrl = rfkill->pdata->pinctrl; #endif@@ -307,7 +309,7 @@ static int rfkill_rk_set_power(void *data, bool blocked) msleep(20); gpio_direction_output(reset->io, reset->enable); }-#if defined(CONFIG_AP6210) || defined(CONFIG_AP6335) +#if defined(CONFIG_AP6210) || defined(CONFIG_AP6212) || defined(CONFIG_AP6335) if (pinctrl != NULL && gpio_is_valid(rts->io)) { pinctrl_select_state(pinctrl, rts->gpio_state); 到此 AP6212 就可以正常使用了,但是不知道供应商提供的 BT 固件应该拷贝到哪里。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1265 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
6401 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2076 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2616 浏览 0 评论
2615 浏览 0 评论
/9
GMT+8, 2025-12-12 00:07 , Processed in 1.155090 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3960
