【平台信息】
CPU:RK3288 Android:7.1 Linux:4.4 WIFI&BT:AP6255 【硬件连接】 1、芯片介绍 【代码梳理】 1、内核配置: cd kernel;make ARCH=arm menuconfig Device Drivers —> [] Network device support —> [] Wireless LAN —> 生成配置文件: kernel/arch/arm/configs/rockchip_defconfig CONFIG_WLAN=y CONFIG_WIFI_LOAD_DRIVER_WHEN_KERNEL_BOOTUP=y CONFIG_RKWIFI=y CONFIG_AP6210=y CONFIG_RKWIFI_26M=y 2、Dts配置 1) arch/arm/boot/dts/rk3288.dtsi sdio: rksdmmc@ff0d0000 { compatible = "rockchip,rk_mmc", "rockchip,rk32xx-sdmmc"; reg = <0xff0d0000 0x4000>; interrupts = #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default","idle"; pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>; pinctrl-1 = <&sdio0_gpio>; clocks = <&clk_sdio0>, <&clk_gates8 4>; clock-names = "clk_mmc", "hclk_mmc"; num-slots = <1>; fifo-depth = <0x100>; bus-width = <4>; /* 4线模式 */ tune_reg***ase = <0x208>; cru_reg***ase = <0x1d8>; cru_reset_offset = <1>; }; 2) arch/arm/boot/dts/rk3288-n1904.dts wireless-wlan { compatible = "wlan-platdata"; /* wifi_chip_type - wifi chip define * bcmwifi ==> like ap6xxx, rk90x; * rtkwifi ==> like rtl8188xx, rtl8723xx,rtl8812auv; * esp8089 ==> esp8089; * other ==> for other wifi; */ wifi_chip_type = "ap6212"; /* 海华和正基模组兼容,realtek需要按实际修改 */ sdio_vref = <1800>; //1800mv or 3300mv,支持SDIO3.0的模组IO一定要接1.8V,SDIO2.0 1.8V/3.3V都可以 //需要根据实际硬件连接设置对应的电压 //keep_wifi_power_on; //power_ctrl_by_pmu; power_pmu_regulator = "act_ldo3"; power_pmu_enable_level = <1>; //1->HIGH, 0->LOW //vref_ctrl_enable; //vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>; vref_pmu_regulator = "act_ldo3"; vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW WIFI,poweren_gpio = <&gpio4 GPIO_D4 GPIO_ACTIVE_HIGH>; //WL_REG_ON,wifi模组pin12 WIFI,host_wake_irq = <&gpio4 GPIO_D6 GPIO_ACTIVE_HIGH>; //WL_HOST_WAKE,wifi模组pin13 //WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>; status = "okay"; }; &sdio { clock-frequency = <50000000>; clock-freq-min-max = <200000 50000000>; supports-highspeed; supports-sdio; ignore-pm-notify; keep-power-in-suspend; //cap-sdio-irq; status = "okay"; }; 3) arch/arm/boot/dts/rk3288-pinctrl.dts pinctrl: pinctrl@ff770000 { gpio4_sdio0 { // SDIO四线接口配置 sdio0_clk: sdio0_clk { rockchip,pins = rockchip,pull = rockchip,drive = //rockchip,tristate = }; sdio0_cmd: sdio0_cmd { rockchip,pins = rockchip,pull = rockchip,drive = //rockchip,tristate = }; sdio0_bus4: sdio0-bus-width4 { rockchip,pins = rockchip,pull = rockchip,drive = //rockchip,tristate = }; //连接wifi模组pin12(WL_REG_ON) sdio0_pwr: sdio0-pwren{ //rock3288-rk3288.h #define SDIO0_PWREN 0x4d41(bank4、offset:c1、func1) rockchip,pins = rockchip,pull = rockchip,drive = //rockchip,tristate = }; //连接wifi模组pin13(WL_HOST_WAKE) sdio0_intn: sdio0-intn{ //rock3288-rk3288.h #define SDIO0_INTN 0x4d61(bank4、offset:d6、func1) rockchip,pins = rockchip,pull = rockchip,drive = //rockchip,tristate = }; RK808 PMU芯片的RTC CLK32KOUT2信号接到AP6212芯片SUSCLK_IN脚输入时钟 2、驱动介绍 kernel/.config文件CONFIG_AP6210=y wifi 驱动路径:kernel/net/rfkill/rfkill-wlan.c wifi驱动代码:drivers/net/wireless/rockchip_wlan/ 【调试过程】 查看芯片 /sys/bus/sdio/devices/mmc1:0001:3 $ dmesg | grep “card at address” 查看Wifi芯片型号 rk3288:/ $ cat /sys/class/rkwifi/chip [ 267.558874] Current WiFi chip is AP6255. 查看Wifi日志打印 logcat | grep WifiHW |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
304 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4374 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1798 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2354 浏览 0 评论
2356 浏览 0 评论
/9
GMT+8, 2025-12-1 20:28 , Processed in 0.554957 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1483
