现象:
1.系统经常重启 2.系统LOGO-kernel之后卡住 3.android动画卡住,无限循环 4.修改SElinux权限之后无显示 RK3568devicerockchipcommonBoardConfig.mk -BOARD_SELINUX_ENFORCING ?= true +BOARD_SELINUX_ENFORCING ?= false 解决方法: rk3568kernelarcharm64bootdtsrockchiprk3568.dtsi dmc: dmc { compatible = "rockchip,rk3568-dmc"; ...... auto-min-freq = <324000>; - //auto-freq-en = <1>; + auto-freq-en = <0>; #cooling-cells = <2>; status = "disabled"; }; dmc_opp_table: dmc-opp-table { compatible = "operating-points-v2"; mbist-vmin = <825000 900000 950000>; nvmem-cells = <&log_leakage>, <&core_pvtm>, <&mbist_vmin>; nvmem-cell-names = "leakage", "pvtm", "mbist-vmin"; rockchip,temp-hysteresis = <5000>; rockchip,low-temp = <0>; rockchip,low-temp-adjust-volt = < /* MHz MHz uV */ -// 0 1560 25000 -// 0 1416 25000 + 0 1332 25000 >; rockchip,leakage-voltage-sel = < 1 80 0 81 254 1 >; + opp-1332000000 { + opp-hz = /bits/ 64 <1332000000>; + opp-microvolt = <900000>; + opp-microvolt-L0 = <900000>; + opp-microvolt-L1 = <850000>; + }; - /* opp-1416000000 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <900000>; - opp-microvolt-L0 = <900000>; - opp-microvolt-L1 = <850000>; - }; */ - - /* opp-1560000000 { - opp-hz = /bits/ 64 <1560000000>; - opp-microvolt = <900000>; - opp-microvolt-L0 = <900000>; - opp-microvolt-L1 = <850000>; - }; */ }; 然后就能进系统了! 如果还有问题: rkbinRKBOOTRK3568MINIALL.ini [CODE471_OPTION] NUM=1 +#Path1=bin/rk35/rk3568_ddr_1560MHz_v1.10.bin +Path1=bin/rk35/rk3568_ddr_1332MHz_v1.10.bin Sleep=1 [CODE472_OPTION] NUM=1 Path1=bin/rk35/rk356x_u***plug_v1.11.bin [LOADER_OPTION] NUM=2 LOADER1=FlashData LOADER2=FlashBoot +#FlashData=bin/rk35/rk3568_ddr_1560MHz_v1.10.bin +FlashData=bin/rk35/rk3568_ddr_1332MHz_v1.10.bin FlashBoot=bin/rk35/rk356x_spl_v1.11.bin DDR跑的几种频率在rkbinbinrk35rk3568_ddr_xxxxMHz_v1.10.bin可以用到, 528 630 780 920 1056 1184 1332 1560MHZ. 也可以从打印中看到: INFO: dfs DDR fsp_param[0].freq_mhz= 1332MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 07:55 , Processed in 0.588003 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1641
