第一步:打开电源 路径:kernelarcharm64bootdtsrockchiprk3568-evb1-ddr4-v10.dtsi pcie30_avdd0v9: pcie30-avdd0v9 { compatible = "regulator-fixed"; regulator-name = "pcie30_avdd0v9"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <900000>; regulator-max-microvolt = <900000>; vin-supply = <&vcc3v3_sys>; }; pcie30_avdd1v8: pcie30-avdd1v8 { compatible = "regulator-fixed"; regulator-name = "pcie30_avdd1v8"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; vin-supply = <&vcc3v3_sys>; }; vcc3v3_pcie: gpio-regulator { compatible = "regulator-fixed"; regulator-name = "vcc3v3_pcie"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; enable-active-high; gpio = <&gpio0 RK_PD4 GPIO_ACTIVE_LOW>; //控制电源引脚 startup-delay-us = <5000>; vin-supply = <&dc_12v>; regulator-always-on; regulator-boot-on; }; vcc3v3_bu: vcc3v3-bu { compatible = "regulator-fixed"; regulator-name = "vcc3v3_bu"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; vin-supply = <&vcc5v0_sys>; }; 第二步:打开DTS节点 路径:kernelarcharm64bootdtsrockchiprk3568-evb1-ddr4-v10.dtsi; &pcie30phy { status = "okay"; }; 第三步:查看设备节点是否生成(插入M.2固态硬盘) |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1133 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1367 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
7082 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2170 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2715 浏览 0 评论
/9
GMT+8, 2025-12-14 16:59 , Processed in 0.633573 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3918
