1.驱动篇
Android系统的内核从8.0开始就进入5时代。大量的平台都采用了最新的kernel5.0以上的版本。kernel5.0开始跟4.0的差距比较大,很多原来的写法已经不再适用了。 首先在kernel中的/arch/arm64/configs/firefly_defconfig中添加 # hello mod by sommerjiang CONFIG_HELLO=y 再在/drivers/misc/下面的Kconfig添加一下的内容: source "drivers/misc/hello/Kconfig" Makefile中添加 obj-$(CONFIG_HELLO) += hello/ 再在/drivers/misc/添加hello文件夹,并添加hello.c hello.h Kconfig Makefile四个文件,内容分别为 hello.c #include #include #include #include #include #include #include #include #include "hello.h" //#define use_proc_hello /*主设备和从设备号变量*/ static int hello_major = 0; static int hello_minor = 0; /*设备类别和设备变量*/ static struct class* hello_class = NULL; static struct hello_android_dev* hello_dev = NULL; /*传统的设备文件操作方法*/ static int hello_open(struct inode* inode, struct file* filp); static int hello_release(struct inode* inode, struct file* filp); static ssize_t hello_read(struct file* filp, char __user *buf, size_t count, loff_t* f_pos); static ssize_t hello_write(struct file* filp, const char __user *buf, size_t count, loff_t* f_pos); /*设备文件操作方法表*/ static struct file_operations hello_fops = { .owner = THIS_MODULE, .open = hello_open, .release = hello_release, .read = hello_read, .write = hello_write, }; ; /*访问设置属性方法*/ static ssize_t hello_val_show(struct device* dev, struct device_attribute* attr, char* buf); static ssize_t hello_val_store(struct device* dev, struct device_attribute* attr, const char* buf, size_t count); /*定义设备属性*/ //sys/class/hello static DEVICE_ATTR(val, S_IRUGO | S_IWUSR, hello_val_show, hello_val_store); /*打开设备方法*/ static int hello_open(struct inode* inode, struct file* filp) { struct hello_android_dev* dev; /*将自定义设备结构体保存在文件指针的私有数据域中,以便访问设备时拿来用*/ dev = container_of(inode->i_cdev, struct hello_android_dev, dev); filp->private_data = dev; return 0; } /*设备文件释放时调用,空实现*/ static int hello_release(struct inode* inode, struct file* filp) { return 0; } /*读取设备的寄存器val的值*/ static ssize_t hello_read(struct file* filp, char __user *buf, size_t count, loff_t* f_pos) { ssize_t err = 0; struct hello_android_dev* dev = filp->private_data; /*同步访问*/ /*if(down_interruptible(&(dev->sem))) { return -ERESTARTSYS; } */ if(count < sizeof(dev->val)) { goto out; } /*将寄存器val的值拷贝到用户提供的缓冲区*/ if(copy_to_user(buf, &(dev->val), sizeof(dev->val))) { err = -EFAULT; goto out; } err = sizeof(dev->val); out: //up(&(dev->sem)); return err; } /*写设备的寄存器值val*/ static ssize_t hello_write(struct file* filp, const char __user *buf, size_t count, loff_t* f_pos) { struct hello_android_dev* dev = filp->private_data; ssize_t err = 0; /*同步访问*/ /* ly if(down_interruptible(&(dev->sem))) { return -ERESTARTSYS; } */ if(count != sizeof(dev->val)) { goto out; } /*将用户提供的缓冲区的值写到设备寄存器去*/ if(copy_from_user(&(dev->val), buf, count)) { err = -EFAULT; goto out; } err = sizeof(dev->val); out: //ly up(&(dev->sem)); return err; } /*读取寄存器val的值到缓冲区buf中,内部使用*/ static ssize_t __hello_get_val(struct hello_android_dev* dev, char* buf) { int val = 0; /*同步访问*/ /*ly if(down_interruptible(&(dev->sem))) { return -ERESTARTSYS; } */ val = dev->val; //lyup(&(dev->sem)); return snprintf(buf, PAGE_SIZE, "%dn", val); } /*把缓冲区buf的值写到设备寄存器val中去,内部使用*/ static ssize_t __hello_set_val(struct hello_android_dev* dev, const char* buf, size_t count) { int val = 0; /*将字符串转换成数字*/ val = simple_strtol(buf, NULL, 10); /*同步访问*/ /* ly if(down_interruptible(&(dev->sem))) { return -ERESTARTSYS; } */ dev->val = val; // ly up(&(dev->sem)); return count; } /*读取设备属性val*/ static ssize_t hello_val_show(struct device* dev, struct device_attribute* attr, char* buf) { struct hello_android_dev* hdev = (struct hello_android_dev*)dev_get_drvdata(dev); return __hello_get_val(hdev, buf); } /*写设备属性val*/ static ssize_t hello_val_store(struct device* dev, struct device_attribute* attr, const char* buf, size_t count) { struct hello_android_dev* hdev = (struct hello_android_dev*)dev_get_drvdata(dev); return __hello_set_val(hdev, buf, count); } //old method for proc #if 0 /*读取设备寄存器val的值,保存在page缓冲区中*/ static ssize_t hello_proc_read(char* page, char** start, off_t off, int count, int* eof, void* data) { if(off > 0) { *eof = 1; return 0; } return __hello_get_val(hello_dev, page); } /*把缓冲区的值buff保存到设备寄存器val中去*/ static ssize_t hello_proc_write(struct file* filp, const char __user *buff, unsigned long len, void* data) { int err = 0; char* page = NULL; if(len > PAGE_SIZE) { printk(KERN_ALERT"The buff is too large: %lu.n", len); return -EFAULT; } page = (char*)__get_free_page(GFP_KERNEL); if(!page) { printk(KERN_ALERT"Failed to alloc page.n"); return -ENOMEM; } /*先把用户提供的缓冲区值拷贝到内核缓冲区中去*/ if(copy_from_user(page, buff, len)) { printk(KERN_ALERT"Failed to copy buff from user.n"); err = -EFAULT; goto out; } err = __hello_set_val(hello_dev, page, len); out: free_page((unsigned long)page); return err; } #endif /*创建/proc/hello文件*/ #ifdef use_proc_hello static void hello_create_proc(void) { //struct proc_dir_entry* entry; //entry = create_proc_entry(HELLO_DEVICE_PROC_NAME, 0, NULL); //proc_create(HELLO_DEVICE_PROC_NAME, 0, NULL, &hello_fops); if(!proc_create(HELLO_DEVICE_PROC_NAME, 0666, NULL, &hello_fops)) { printk("error "); } } #endif /*删除/proc/hello文件*/ static void hello_remove_proc(void) { remove_proc_entry(HELLO_DEVICE_PROC_NAME, NULL); } /*初始化设备*/ static int __hello_setup_dev(struct hello_android_dev* dev) { int err; dev_t devno = MKDEV(hello_major, hello_minor); //jiang zhu memset(dev, 0, sizeof(struct hello_android_dev)); cdev_init(&(dev->dev), &hello_fops); dev->dev.owner = THIS_MODULE; dev->dev.ops = &hello_fops; /*注册字符设备*/ err = cdev_add(&(dev->dev),devno, 1); if(err) { return err; } /*初始化信号量和寄存器val的值*/ //init_MUTEX(&(dev->sem)); // ly sema_init(&(dev->sem),1); dev->val = 0; return 0; } /*模块加载方法*/ static int __init hello_init(void){ int err = -1; dev_t dev = 0; struct device* temp = NULL; printk(KERN_ALERT"Initializing hello device.n"); /*动态分配主设备和从设备号*/ err = alloc_chrdev_region(&dev, 0, 1, HELLO_DEVICE_NODE_NAME); if(err < 0) { printk(KERN_ALERT"Failed to alloc char dev region.n"); goto fail; } hello_major = MAJOR(dev); hello_minor = MINOR(dev); /*分配helo设备结构体变量*/ hello_dev = kmalloc(sizeof(struct hello_android_dev), GFP_KERNEL); if(!hello_dev) { err = -ENOMEM; printk(KERN_ALERT"Failed to alloc hello_dev.n"); goto unregister; } /*初始化设备*/ err = __hello_setup_dev(hello_dev); if(err) { printk(KERN_ALERT"Failed to setup dev: %d.n", err); goto cleanup; } /*在/sys/class/目录下创建设备类别目录hello*/ hello_class = class_create(THIS_MODULE, HELLO_DEVICE_CLASS_NAME); if(IS_ERR(hello_class)) { err = PTR_ERR(hello_class); printk(KERN_ALERT"Failed to create hello class.n"); goto destroy_cdev; } /*在/dev/目录和/sys/class/hello目录下分别创建设备文件hello*/ temp = device_create(hello_class, NULL, dev, "%s", HELLO_DEVICE_FILE_NAME); if(IS_ERR(temp)) { err = PTR_ERR(temp); printk(KERN_ALERT"Failed to create hello device."); goto destroy_class; } /*在/sys/class/hello/hello目录下创建属性文件val*/ err = device_create_file(temp, &dev_attr_val); if(err < 0) { printk(KERN_ALERT"Failed to create attribute val."); goto destroy_device; } dev_set_drvdata(temp, hello_dev); #ifdef use_proc_hello /*创建/proc/hello文件*/ hello_create_proc(); #endif printk(KERN_ALERT"Succedded to initialize hello device.n"); return 0; destroy_device: device_destroy(hello_class, dev); destroy_class: class_destroy(hello_class); destroy_cdev: cdev_del(&(hello_dev->dev)); cleanup: kfree(hello_dev); unregister: unregister_chrdev_region(MKDEV(hello_major, hello_minor), 1); fail: return err; } /*模块卸载方法*/ static void __exit hello_exit(void) { dev_t devno = MKDEV(hello_major, hello_minor); printk(KERN_ALERT"Destroy hello device.n"); /*删除/proc/hello文件*/ hello_remove_proc(); /*销毁设备类别和设备*/ if(hello_class) { device_destroy(hello_class, MKDEV(hello_major, hello_minor)); class_destroy(hello_class); } /*删除字符设备和释放设备内存*/ if(hello_dev) { cdev_del(&(hello_dev->dev)); kfree(hello_dev); } /*释放设备号*/ unregister_chrdev_region(devno, 1); } MODULE_LICENSE("GPL"); MODULE_DESCRIPTION("First Android Driver"); module_init(hello_init); module_exit(hello_exit); hello.h #ifndef _HELLO_ANDROID_H_ #define _HELLO_ANDROID_H_ #include #include #define HELLO_DEVICE_NODE_NAME "hello" #define HELLO_DEVICE_FILE_NAME "hello" #define HELLO_DEVICE_PROC_NAME "hello" struct semaphore sem; struct cdev dev; }; #endif Kconfig config HELLO tristate "First Android Driver" default n help This is the first android driver. Makefile obj-$(CONFIG_HELLO) += hello.o 这样编译完后就可以烧录到内核里面。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1101 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1348 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
6943 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2151 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2698 浏览 0 评论
/9
GMT+8, 2025-12-14 12:49 , Processed in 0.928378 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2311
