1、首先定位播放音频文件大概位置 2、确认播放音频为 WirelessChargingStarted.ogg 3、根据WirelessChargingStarted名称关键字找到frameworksbaseservicescorejavacomandroidserverpowerNotifier.java 4、修改 diff --git a/frameworks/base/packages/SettingsProvider/res/values/defaults.xml b/frameworks/base/packages/SettingsProvider/res/values/defaults.xml index 3083f55..2b4c759 100755 --- a/frameworks/base/packages/SettingsProvider/res/values/defaults.xml +++ b/frameworks/base/packages/SettingsProvider/res/values/defaults.xml @@ -66,7 +66,8 @@ + diff --git a/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java b/frameworks/base/packages/SettingsProvider/src/com/android/pr oviders/settings/DatabaseHelper.java index f6b3d06..ed1e338 100755 --- a/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java +++ b/frameworks/base/packages/SettingsProvider/src/com/android/providers/settings/DatabaseHelper.java @@ -2548,6 +2548,11 @@ class DatabaseHelper extends SQLiteOpenHelper { loadIntegerSetting(stmt, Settings.Secure.SLEEP_TIMEOUT, R.integer.def_sleep_timeout); @@ -2676,6 +2681,8 @@ class DatabaseHelper extends SQLiteOpenHelper { R.string.def_trusted_sound); loadIntegerSetting(stmt, Settings.Global.POWER_SOUNDS_ENABLED, R.integer.def_power_sounds_enabled); + loadIntegerSetting(stmt, Settings.Global.CHARGING_SOUNDS_ENABLED, + R.integer.def_charging_sounds_enabled); loadStringSetting(stmt, Settings.Global.LOW_BATTERY_SOUND, R.string.def_low_battery_sound); loadIntegerSetting(stmt, Settings.Global.DOCK_SOUNDS_ENABLED, |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 10:52 , Processed in 0.679960 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1148
