diff --git a/frameworks/native/services/inputflinger/InputReader.cpp b/frameworks/native/services/inputflinger/InputReader.cpp
旧模式 100644 新模式 100755 索引 fa81a10..5dcf5f7 --- a/frameworks/ native/services/inputflinger/InputReader.cpp +++ b/frameworks/native/services/inputflinger/InputReader.cpp @@ -3500,7 +3500,27 @@ void TouchInputMapper::configureSurface(nsecs_t when, bool* outResetNeeded) { bool viewportChanged = mViewport != newViewport; if (viewportChanged) { mViewport = newViewport; - + char buffer_orientation[PROP_VALUE_MAX]; + memset(buffer_orientation, 0, sizeof(buffer_orientation)); + property_get(“persist.sys.rotation.einit”, buffer_orientation, “0”); + int cmpRet = atoi(buffer_orientation); + ALOGI(“persist.sys.rotation.einit~~~~~~~~~~~~~~ = %d”,cmpRet); + if (cmpRet == 0) + { + mViewport.orientation = DISPLAY_ORIENTATION_0; + } + else if(cmpRet == 1) + { + mViewport.orientation = DISPLAY_ORIENTATION_90; + } + else if(cmpRet == 2) + { + mViewport.orientation = DISPLAY_ORIENTATION_180; + } + else if(cmpRet == 3) + { + mViewport.orientation = DISPLAY_ORIENTATION_270; + } if (mDeviceMode == DEVICE_MODE_DIRECT || mDeviceMode == DEVICE_MODE_POINTER) { // 将旋转的视口转换为自然表面坐标。 int32_t naturalLogicalWidth, naturalLogicalHeight; diff --git a/device/rockchip/rk3288/system.prop b/device/rockchip/rk3288/system.prop index 2831458..eb319af 100755 --- a/device/rockchip/rk3288/system.prop +++ b /device/rockchip/rk3288/system.prop @@ -28,8 +28,7 @@ sys.wallpaper.rgb565=0 sf.power.control=2073600 sys.rkadb.root=0 ro.sf.fakerotation=false +ro.sf.hwrotation=90 ro.rk.MassStorage=false ro.rk.systembar.voiceicon=true ro.rk.systembar.tabletUI=false @@ -53,5 +52,4 @@ sys.hwc.device.extend=DSI ro.sys.rotation.sensor=false persist.sys.rotation.efull=true # 0-0 1-90 2-180 3-270 +persist.sys.rotation.einit =1 文件末尾没有换行符 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 04:55 , Processed in 0.678365 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3247
