扫一扫,分享给好友
修改默认时区语言
文件路径 device/rockchip/rk356x/device.mk 在 PRODUCT_PROPERTY_OVERRIDES下增加以下内容 persist.sys.language=zh persist.sys.country=CN persist.sys.localevar= "" persist.sys.timezone=Asia/Shanghai ro.product.locale.language=zh ro.product.locale.region=CN 修改导航栏、状态栏 导航栏路径 frameworks/base/packages/SystemUI/src/com/android/systemui/statu***ar/phone/NavigationBarFragment.java 修改函数为 prepareNavigationBarView,在函数最后加上 volumeAddButton.setVisibility(View.GONE); volumeSubButton.setVisibility(View.GONE); screenshotButton.setVisibility(View.GONE); poweroffButton.setVisibility(View.GONE); rotationButton.setVisibility(View.GONE); hideBarButton.setVisibility(View.GONE); 状态栏路径 frameworks/base/core/res/res/values/dimens.xml 修改status_bar_height_portrait的值为0dp 修改安装应用的权限 文件路径 frameworks/base/services/core/java/com/android/server/pm/permission/PermissionManagerService.java 函数 private void restorePermissionState(@NonNull AndroidPackage pkg, boolean replace, @Nullable String packageOfInterest, @Nullable PermissionCallback callback) 部分代码修改为: if (bp.isNormal()) { // For all apps normal permissions are install time ones. grant = GRANT_INSTALL; } else if (bp.isRuntime()) { if (origPermissions.hasInstallPermission(bp.getName()) || upgradedActivityRecognitionPermission != null) { // Before Q we represented some runtime permissions as install permissions, // in Q we cannot do this anymore. Hence upgrade them all. grant = GRANT_UPGRADE; } else { // For modern apps keep runtime permissions unchanged. // grant = GRANT_RUNTIME; grant = GRANT_INSTALL; } } else if (bp.isSignature()) { // For all apps signature permissions are install time ones. allowedSig = grantSignaturePermission(perm, pkg, ps, bp, origPermissions); if (allowedSig) { grant = GRANT_INSTALL; } grant = GRANT_INSTALL; } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
304 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4374 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1798 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2354 浏览 0 评论
2356 浏览 0 评论
/9
GMT+8, 2025-12-1 17:47 , Processed in 0.663974 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1752
