很多时候需要在里面开一个,为某些应用程序在里面提供特殊的支持。所以今天要
记下在里面添加服务器的基本套路以后做参考。 代码,但是记不起来,在哪里参考的。 diff --git a/frameworks/base/Android.mk b/frameworks/base/Android.mk index 3018c4e..555267d 100755 --- a/frameworks/base/Android.mk +++ b/frameworks/base/Android.mk @@ -558,6 +558,7 @@ LOCAL_SRC_FILES += packages/services/Proxy/com/android/net/IProxyPortListener.aidl core/java/android/service/quicksettings/IQSService.aidl core/java/android/service/quicksettings/IQSTileService.aidl + core/java/android/security/ISecurityServer.aidl # The following are native binders that need to go with the native component # at system/update_engine/binder_bindings/. Use relative path to refer to them. diff --git a/frameworks/base/api/current.txt b/frameworks/base/api/current.txt index b212b70..a9bec71 100644 --- a/frameworks/base/api/current.txt +++ b/frameworks/base/api/current.txt @@ -36789,6 +36789,22 @@ package android.sax { package android.security { + public class CnbotSecurityManager { + ctor public CnbotSecurityManager(android.security.ISecurityServer); + method public java.lang.String runCmd(java.lang.String); + } + + public abstract interface ISecurityServer implements android.os.IInterface { + method public abstract java.lang.String runCmd(java.lang.String) throws android.os.RemoteException; + } + + public static abstract class ISecurityServer.Stub extends android.os.Binder implements android.security.ISecurityServer { + ctor public ISecurityServer.Stub(); + method public android.os.IBinder asBinder(); + method public static android.security.ISecurityServer asInterface(android.os.IBinder); + method public boolean onTransact(int, android.os.Parcel, android.os.Parcel, int) throws android.os.RemoteException; + } + public final class KeyChain { ctor public KeyChain(); method public static void choosePrivateKeyAlias(android.app.Activity, android.security.KeyChainAliasCallback, java.lang.String[], java.security.Principal[], java.lang.String, int, java.lang.String); diff --git a/frameworks/base/api/system-current.txt b/frameworks/base/api/system-current.txt index cd46c4c..0cedf26 100644 --- a/frameworks/base/api/system-current.txt +++ b/frameworks/base/api/system-current.txt @@ -39866,6 +39866,22 @@ package android.sax { package android.security { + public class CnbotSecurityManager { + ctor public CnbotSecurityManager(android.security.ISecurityServer); + method public java.lang.String runCmd(java.lang.String); + } + + public abstract interface ISecurityServer implements android.os.IInterface { + method public abstract java.lang.String runCmd(java.lang.String) throws android.os.RemoteException; + } + + public static abstract class ISecurityServer.Stub extends android.os.Binder implements android.security.ISecurityServer { + ctor public ISecurityServer.Stub(); + method public android.os.IBinder asBinder(); + method public static android.security.ISecurityServer asInterface(android.os.IBinder); + method public boolean onTransact(int, android.os.Parcel, android.os.Parcel, int) throws android.os.RemoteException; + } + public final class KeyChain { ctor public KeyChain(); method public static void choosePrivateKeyAlias(android.app.Activity, android.security.KeyChainAliasCallback, java.lang.String[], java.security.Principal[], java.lang.String, int, java.lang.String); diff --git a/frameworks/base/api/test-current.txt b/frameworks/base/api/test-current.txt index f366576..ab40834 100644 --- a/frameworks/base/api/test-current.txt +++ b/frameworks/base/api/test-current.txt @@ -36986,6 +36986,22 @@ package android.sax { package android.security { + public class CnbotSecurityManager { + ctor public CnbotSecurityManager(android.security.ISecurityServer); + method public java.lang.String runCmd(java.lang.String); + } + + public abstract interface ISecurityServer implements android.os.IInterface { + method public abstract java.lang.String runCmd(java.lang.String) throws android.os.RemoteException; + } + + public static abstract class ISecurityServer.Stub extends android.os.Binder implements android.security.ISecurityServer { + ctor public ISecurityServer.Stub(); + method public android.os.IBinder asBinder(); + method public static android.security.ISecurityServer asInterface(android.os.IBinder); + method public boolean onTransact(int, android.os.Parcel, android.os.Parcel, int) throws android.os.RemoteException; + } + public final class KeyChain { ctor public KeyChain(); method public static void choosePrivateKeyAlias(android.app.Activity, android.security.KeyChainAliasCallback, java.lang.String[], java.security.Principal[], java.lang.String, int, java.lang.String); diff --git a/frameworks/base/core/java/android/app/SystemServiceRegistry.java b/frameworks/base/core/java/android/app/SystemServiceRegistry.java index e695936..657c059 100755 --- a/frameworks/base/core/java/android/app/SystemServiceRegistry.java +++ b/frameworks/base/core/java/android/app/SystemServiceRegistry.java @@ -904,10 +904,19 @@ final class SystemServiceRegistry { registerService(Context.TIME_ZONE_RULES_MANAGER_SERVICE, RulesManager.class, new CachedServiceFetcher - @Override + @Override public RulesManager createService(ContextImpl ctx) { return new RulesManager(ctx.getOuterContext()); }}); + //添加Cnbot服务 + registerService("cnbot_service", android.security.CnbotSecurityManager.class, + new CachedServiceFetcher + @Override + public android.security.CnbotSecurityManager createService(ContextImpl ctx) { + IBinder b = ServiceManager.getService("cnbot_service"); + return new android.security.CnbotSecurityManager(android.security.ISecurityServer.Stub.asInterface(b)); + } + }); } /** diff --git a/frameworks/base/core/java/android/security/CnbotSecurityManager.java b/frameworks/base/core/java/android/security/CnbotSecurityManager.java new file mode 100644 index 0000000..9dfffa5 --- /dev/null +++ b/frameworks/base/core/java/android/security/CnbotSecurityManager.java @@ -0,0 +1,25 @@ + +package android.security; + +//import java.io.Exception; +import android.util.Log; + +public class CnbotSecurityManager{ + private final ISecurityServer mService; + public CnbotSecurityManager(ISecurityServer service){ + mService = service; + } + + public String runCmd(String cmd){ + Log.d("CnbotSecurityManager","接到指令:"+cmd); + try{ + return mService.runCmd(cmd); + }catch(Exception e){ + Log.d("CnbotSecurityManager","runCmd faild"); + return "error"; + } + } + + + +} diff --git a/frameworks/base/core/java/android/security/ISecurityServer.aidl b/frameworks/base/core/java/android/security/ISecurityServer.aidl new file mode 100644 index 0000000..42ac465 --- /dev/null +++ b/frameworks/base/core/java/android/security/ISecurityServer.aidl @@ -0,0 +1,5 @@ +package android.security; + +interface ISecurityServer { + String runCmd(String cmd); +} diff --git a/frameworks/base/services/core/java/com/android/server/ProcessModel.java b/frameworks/base/services/core/java/com/android/server/ProcessModel.java new file mode 100755 index 0000000..e5df6df --- /dev/null +++ b/frameworks/base/services/core/java/com/android/server/ProcessModel.java @@ -0,0 +1,199 @@ +package com.android.server; + +import java.io.BufferedReader; +import java.io.IOException; +import java.io.InputStream; +import java.io.InputStreamReader; +import java.io.OutputStream; + +/** + * Create By Qiujuer + * 2014-07-26 + * + * 执行命令行语句静态方法封装 + */ +public class ProcessModel { + //换行符 + private static final String BREAK_LINE; + //执行退出命令 + private static final byte[] COMMAND_EXIT; + //错误缓冲 + private static byte[] BUFFER; + + /** + * 静态变量初始化 + */ + static { + BREAK_LINE = "n"; + COMMAND_EXIT = "nexitn".getBytes(); + BUFFER = new byte[32]; + } + + + /** + * 执行命令 + * + * @param params 命令参数 + * eg: "/system/bin/ping", "-c", "4", "-s", "100","www.qiujuer.net" + * @return 执行结果 + */ + public static String execute(String... params) { + Process process = null; + StringBuilder ***Reader = null; + + BufferedReader bReader = null; + InputStreamReader isReader = null; + + InputStream in = null; + InputStream err = null; + OutputStream out = null; + + try { + process = new ProcessBuilder() + .command(params) + .start(); + out = process.getOutputStream(); + in = process.getInputStream(); + err = process.getErrorStream(); + + out.write(COMMAND_EXIT); + out.flush(); + + process.waitFor(); + + isReader = new InputStreamReader(in); + bReader = new BufferedReader(isReader); + + String s; + ***Reader = new StringBuilder(); + if ((s = bReader.readLine()) != null) { + ***Reader.append(s); + ***Reader.append(BREAK_LINE); + while ((s = bReader.readLine()) != null) { + ***Reader.append(s); + ***Reader.append(BREAK_LINE); + } + } + + while ((err.read(BUFFER)) > 0) { + ***Reader.append(new String(BUFFER)); + } + } catch (IOException e) { + e.printStackTrace(); + } catch (Exception e) { + e.printStackTrace(); + } finally { + closeAllStream(out, err, in, isReader, bReader); + + if (process != null) { + processDestroy(process); + process = null; + } + } + + if (***Reader == null) + return null; + else + return ***Reader.toString(); + } + + /** + * 关闭所有流 + * + * @param out 输出流 + * @param err 错误流 + * @param in 输入流 + * @param isReader 输入流封装 + * @param bReader 输入流封装 + */ + private static void closeAllStream(OutputStream out, InputStream err, InputStream in, InputStreamReader isReader, BufferedReader bReader) { + if (out != null) + try { + out.close(); + } catch (IOException e) { + e.printStackTrace(); + } + if (err != null) + try { + err.close(); + } catch (IOException e) { + e.printStackTrace(); + } + if (in != null) + try { + in.close(); + } catch (IOException e) { + e.printStackTrace(); + } + if (isReader != null) + try { + isReader.close(); + } catch (IOException e) { + e.printStackTrace(); + } + if (bReader != null) + try { + bReader.close(); + } catch (IOException e) { + e.printStackTrace(); + } + } + + + /** + * 通过Android底层实现进程关闭 + * + * @param process 进程 + */ + private static void killProcess(Process process) { + int pid = getProcessId(process); + if (pid != 0) { + try { + //android kill process + android.os.Process.killProcess(pid); + } catch (Exception e) { + try { + process.destroy(); + } catch (Exception ex) { + } + } + } + } + + /** + * 获取进程的ID + * + * @param process 进程 + * @return + */ + private static int getProcessId(Process process) { + String str = process.toString(); + try { + int i = str.indexOf("=") + 1; + int j = str.indexOf("]"); + str = str.substring(i, j); + return Integer.parseInt(str); + } catch (Exception e) { + return 0; + } + } + + /** + * 销毁进程 + * + * @param process 进程 + */ + private static void processDestroy(Process process) { + if (process != null) { + try { + //判断是否正常退出 + if (process.exitValue() != 0) { + killProcess(process); + } + } catch (IllegalThreadStateException e) { + killProcess(process); + } + } + } +} + diff --git a/frameworks/base/services/core/java/com/android/server/SecurityServer.java b/frameworks/base/services/core/java/com/android/server/SecurityServer.java new file mode 100644 index 0000000..d321531 --- /dev/null +++ b/frameworks/base/services/core/java/com/android/server/SecurityServer.java @@ -0,0 +1,41 @@ +package com.android.server; + +import android.security.ISecurityServer; +import android.util.Log; +import java.io.File; +import java.io.FileNotFoundException; +import java.io.IOException; +import android.os.Handler; + +public class SecurityServer extends ISecurityServer.Stub{ + + Handler handler = new Handler(); + @Override + public String runCmd(String cmd) { + Runnable runnable = new Runnable() { + @Override + public void run() { + try{ + Log.d("SecurityServer",ProcessModel.execute(cmd.split(" "))); + }catch(Exception e){ + e.printStackTrace(); + } + + } + }; + handler.post(runnable); + //new Thread(runnable).start(); + //checkPermission(cmd); + try { + Thread.sleep(500); + } catch (InterruptedException e) { + e.printStackTrace(); + } + return "hello word"; + } + + + + +} + diff --git a/frameworks/base/services/java/com/android/server/SystemServer.java b/frameworks/base/services/java/com/android/server/SystemServer.java index 0ea9f17..d03c1f8 100755 --- a/frameworks/base/services/java/com/android/server/SystemServer.java +++ b/frameworks/base/services/java/com/android/server/SystemServer.java @@ -880,6 +880,9 @@ public final class SystemServer { mSystemServiceManager.startService(IpConnectivityMetrics.class); traceEnd(); + SecurityServer securityServer = new SecurityServer(); + ServiceManager.addService("cnbot_service", securityServer); + traceBeginAndSlog("PinnerService"); mSystemServiceManager.startService(PinnerService.class); traceEnd(); |
diff --git a/system/sepolicy/prebuilts/api/26.0/nonplat_sepolicy.cil b/system/sepolicy/prebuilts/api/26.0/nonplat_sepolicy.cil
index 2ed4efa..567ec49 100644 --- a/system/sepolicy/prebuilts/api/26.0/nonplat_sepolicy.cil +++ b/system/sepolicy/prebuilts/api/26.0/nonplat_sepolicy.cil @@ -17,11 +17,11 @@ (typeattributeset property_type (asan_reboot_prop_26_0 audio_prop_26_0 boottime_prop_26_0 bluetooth_prop_26_0 config_prop_26_0 cppreopt_prop_26_0 ctl_bootanim_prop_26_0 ctl_bugreport_prop_26_0 ctl_console_prop_26_0 ctl_default_prop_26_0 ctl_dumpstate_prop_26_0 ctl_fuse_prop_26_0 ctl_mdnsd_prop_26_0 ctl_rildaemon_prop_26_0 dalvik_prop_26_0 debuggerd_prop_26_0 debug_prop_26_0 default_prop_26_0 device_logging_prop_26_0 dhcp_prop_26_0 dumpstate_options_prop_26_0 dumpstate_prop_26_0 ffs_prop_26_0 fingerprint_prop_26_0 firstboot_prop_26_0 hwservicemanager_prop_26_0 logd_prop_26_0 logpersistd_logging_prop_26_0 log_prop_26_0 log_tag_prop_26_0 mmc_prop_26_0 net_dns_prop_26_0 net_radio_prop_26_0 nfc_prop_26_0 overlay_prop_26_0 pan_result_prop_26_0 persist_debug_prop_26_0 persistent_properties_ready_prop_26_0 powerctl_prop_26_0 radio_prop_26_0 restorecon_prop_26_0 safemode_prop_26_0 serialno_prop_26_0 shell_prop_26_0 system_prop_26_0 system_radio_prop_26_0 vold_prop_26_0 wifi_log_prop_26_0 wifi_prop_26_0)) (typeattributeset core_property_type (audio_prop_26_0 config_prop_26_0 cppreopt_prop_26_0 dalvik_prop_26_0 debuggerd_prop_26_0 debug_prop_26_0 default_prop_26_0 dhcp_prop_26_0 dumpstate_prop_26_0 ffs_prop_26_0 fingerprint_prop_26_0 logd_prop_26_0 net_radio_prop_26_0 nfc_prop_26_0 pan_result_prop_26_0 persist_debug_prop_26_0 powerctl_prop_26_0 radio_prop_26_0 restorecon_prop_26_0 shell_prop_26_0 system_prop_26_0 system_radio_prop_26_0 vold_prop_26_0)) (typeattributeset log_property_type (log_prop_26_0 log_tag_prop_26_0 wifi_log_prop_26_0)) -(typeattributeset system_server_service (accessibility_service_26_0 account_service_26_0 activity_service_26_0 alarm_service_26_0 appops_service_26_0 appwidget_service_26_0 assetatlas_service_26_0 audio_service_26_0 autofill_service_26_0 backup_service_26_0 batterystats_service_26_0 battery_service_26_0 bluetooth_manager_service_26_0 cameraproxy_service_26_0 clipboard_service_26_0 contexthub_service_26_0 IProxyService_service_26_0 commontime_management_service_26_0 companion_device_service_26_0 connectivity_service_26_0 connmetrics_service_26_0 consumer_ir_service_26_0 content_service_26_0 country_detector_service_26_0 coverage_service_26_0 cpuinfo_service_26_0 dbinfo_service_26_0 device_policy_service_26_0 deviceidle_service_26_0 device_identifiers_service_26_0 devicestoragemonitor_service_26_0 diskstats_service_26_0 display_service_26_0 font_service_26_0 netd_listener_service_26_0 DockObserver_service_26_0 dreams_service_26_0 dropbox_service_26_0 ethernet_service_26_0 fingerprint_service_26_0 gfxinfo_service_26_0 graphicsstats_service_26_0 hardware_service_26_0 hardware_properties_service_26_0 hdmi_control_service_26_0 input_method_service_26_0 input_service_26_0 imms_service_26_0 ipsec_service_26_0 jobscheduler_service_26_0 launcherapps_service_26_0 location_service_26_0 lock_settings_service_26_0 media_projection_service_26_0 media_router_service_26_0 media_session_service_26_0 meminfo_service_26_0 midi_service_26_0 mount_service_26_0 netpolicy_service_26_0 netstats_service_26_0 network_management_service_26_0 network_score_service_26_0 network_time_update_service_26_0 notification_service_26_0 oem_lock_service_26_0 otadexopt_service_26_0 overlay_service_26_0 package_service_26_0 permission_service_26_0 persistent_data_block_service_26_0 pinner_service_26_0 power_service_26_0 print_service_26_0 processinfo_service_26_0 procstats_service_26_0 recovery_service_26_0 registry_service_26_0 restrictions_service_26_0 rttmanager_service_26_0 samplingprofiler_service_26_0 scheduling_policy_service_26_0 search_service_26_0 sec_key_att_app_id_provider_service_26_0 sensorservice_service_26_0 serial_service_26_0 servicediscovery_service_26_0 settings_service_26_0 shortcut_service_26_0 statu***ar_service_26_0 storagestats_service_26_0 task_service_26_0 textclassification_service_26_0 textservices_service_26_0 telecom_service_26_0 trust_service_26_0 tv_input_service_26_0 uimode_service_26_0 updatelock_service_26_0 usagestats_service_26_0 u***_service_26_0 user_service_26_0 vibrator_service_26_0 voiceinteraction_service_26_0 vr_manager_service_26_0 wallpaper_service_26_0 webviewupdate_service_26_0 wifip2p_service_26_0 wifiscanner_service_26_0 wifi_service_26_0 wifiaware_service_26_0 window_service_26_0)) -(typeattributeset app_api_service (batteryproperties_service_26_0 gatekeeper_service_26_0 accessibility_service_26_0 account_service_26_0 activity_service_26_0 alarm_service_26_0 appops_service_26_0 appwidget_service_26_0 assetatlas_service_26_0 audio_service_26_0 autofill_service_26_0 backup_service_26_0 batterystats_service_26_0 bluetooth_manager_service_26_0 clipboard_service_26_0 contexthub_service_26_0 IProxyService_service_26_0 companion_device_service_26_0 connectivity_service_26_0 connmetrics_service_26_0 consumer_ir_service_26_0 content_service_26_0 country_detector_service_26_0 device_policy_service_26_0 deviceidle_service_26_0 device_identifiers_service_26_0 display_service_26_0 font_service_26_0 dreams_service_26_0 dropbox_service_26_0 ethernet_service_26_0 fingerprint_service_26_0 graphicsstats_service_26_0 hardware_properties_service_26_0 input_method_service_26_0 input_service_26_0 imms_service_26_0 ipsec_service_26_0 jobscheduler_service_26_0 launcherapps_service_26_0 location_service_26_0 media_projection_service_26_0 media_router_service_26_0 media_session_service_26_0 midi_service_26_0 mount_service_26_0 netpolicy_service_26_0 netstats_service_26_0 network_management_service_26_0 notification_service_26_0 package_service_26_0 permission_service_26_0 power_service_26_0 print_service_26_0 procstats_service_26_0 registry_service_26_0 restrictions_service_26_0 rttmanager_service_26_0 search_service_26_0 sec_key_att_app_id_provider_service_26_0 sensorservice_service_26_0 servicediscovery_service_26_0 settings_service_26_0 shortcut_service_26_0 statu***ar_service_26_0 storagestats_service_26_0 textclassification_service_26_0 textservices_service_26_0 telecom_service_26_0 trust_service_26_0 tv_input_service_26_0 uimode_service_26_0 usagestats_service_26_0 u***_service_26_0 user_service_26_0 vibrator_service_26_0 voiceinteraction_service_26_0 wallpaper_service_26_0 webviewupdate_service_26_0 wifip2p_service_26_0 wifi_service_26_0 wifiaware_service_26_0)) -(typeattributeset ephemeral_app_api_service (batteryproperties_service_26_0 accessibility_service_26_0 account_service_26_0 activity_service_26_0 alarm_service_26_0 appops_service_26_0 appwidget_service_26_0 assetatlas_service_26_0 audio_service_26_0 autofill_service_26_0 backup_service_26_0 batterystats_service_26_0 bluetooth_manager_service_26_0 clipboard_service_26_0 IProxyService_service_26_0 companion_device_service_26_0 connectivity_service_26_0 connmetrics_service_26_0 consumer_ir_service_26_0 content_service_26_0 country_detector_service_26_0 deviceidle_service_26_0 device_identifiers_service_26_0 display_service_26_0 font_service_26_0 dreams_service_26_0 dropbox_service_26_0 graphicsstats_service_26_0 hardware_properties_service_26_0 input_method_service_26_0 input_service_26_0 imms_service_26_0 ipsec_service_26_0 jobscheduler_service_26_0 launcherapps_service_26_0 location_service_26_0 media_projection_service_26_0 media_router_service_26_0 media_session_service_26_0 midi_service_26_0 mount_service_26_0 netpolicy_service_26_0 netstats_service_26_0 network_management_service_26_0 notification_service_26_0 package_service_26_0 permission_service_26_0 power_service_26_0 print_service_26_0 procstats_service_26_0 registry_service_26_0 restrictions_service_26_0 rttmanager_service_26_0 search_service_26_0 sensorservice_service_26_0 servicediscovery_service_26_0 settings_service_26_0 statu***ar_service_26_0 storagestats_service_26_0 textclassification_service_26_0 textservices_service_26_0 telecom_service_26_0 tv_input_service_26_0 uimode_service_26_0 usagestats_service_26_0 user_service_26_0 vibrator_service_26_0 voiceinteraction_service_26_0 webviewupdate_service_26_0)) +(typeattributeset system_server_service (accessibility_service_26_0 account_service_26_0 activity_service_26_0 alarm_service_26_0 appops_service_26_0 appwidget_service_26_0 assetatlas_service_26_0 audio_service_26_0 autofill_service_26_0 backup_service_26_0 batterystats_service_26_0 battery_service_26_0 bluetooth_manager_service_26_0 cameraproxy_service_26_0 clipboard_service_26_0 contexthub_service_26_0 IProxyService_service_26_0 commontime_management_service_26_0 companion_device_service_26_0 connectivity_service_26_0 connmetrics_service_26_0 consumer_ir_service_26_0 content_service_26_0 country_detector_service_26_0 coverage_service_26_0 cpuinfo_service_26_0 dbinfo_service_26_0 device_policy_service_26_0 deviceidle_service_26_0 device_identifiers_service_26_0 devicestoragemonitor_service_26_0 diskstats_service_26_0 display_service_26_0 font_service_26_0 netd_listener_service_26_0 DockObserver_service_26_0 dreams_service_26_0 dropbox_service_26_0 ethernet_service_26_0 fingerprint_service_26_0 gfxinfo_service_26_0 graphicsstats_service_26_0 hardware_service_26_0 hardware_properties_service_26_0 hdmi_control_service_26_0 input_method_service_26_0 input_service_26_0 imms_service_26_0 ipsec_service_26_0 jobscheduler_service_26_0 launcherapps_service_26_0 location_service_26_0 lock_settings_service_26_0 media_projection_service_26_0 media_router_service_26_0 media_session_service_26_0 meminfo_service_26_0 midi_service_26_0 mount_service_26_0 netpolicy_service_26_0 netstats_service_26_0 network_management_service_26_0 network_score_service_26_0 network_time_update_service_26_0 notification_service_26_0 oem_lock_service_26_0 otadexopt_service_26_0 overlay_service_26_0 package_service_26_0 permission_service_26_0 persistent_data_block_service_26_0 pinner_service_26_0 power_service_26_0 print_service_26_0 processinfo_service_26_0 procstats_service_26_0 recovery_service_26_0 registry_service_26_0 restrictions_service_26_0 rttmanager_service_26_0 samplingprofiler_service_26_0 scheduling_policy_service_26_0 search_service_26_0 sec_key_att_app_id_provider_service_26_0 sensorservice_service_26_0 serial_service_26_0 servicediscovery_service_26_0 settings_service_26_0 shortcut_service_26_0 statu***ar_service_26_0 storagestats_service_26_0 task_service_26_0 textclassification_service_26_0 textservices_service_26_0 telecom_service_26_0 trust_service_26_0 tv_input_service_26_0 uimode_service_26_0 updatelock_service_26_0 usagestats_service_26_0 u***_service_26_0 user_service_26_0 vibrator_service_26_0 voiceinteraction_service_26_0 vr_manager_service_26_0 wallpaper_service_26_0 webviewupdate_service_26_0 wifip2p_service_26_0 wifiscanner_service_26_0 wifi_service_26_0 wifiaware_service_26_0 window_service_26_0 cnbot_service_26_0)) +(typeattributeset app_api_service (batteryproperties_service_26_0 gatekeeper_service_26_0 accessibility_service_26_0 account_service_26_0 activity_service_26_0 alarm_service_26_0 appops_service_26_0 appwidget_service_26_0 assetatlas_service_26_0 audio_service_26_0 autofill_service_26_0 backup_service_26_0 batterystats_service_26_0 bluetooth_manager_service_26_0 clipboard_service_26_0 contexthub_service_26_0 IProxyService_service_26_0 companion_device_service_26_0 connectivity_service_26_0 connmetrics_service_26_0 consumer_ir_service_26_0 content_service_26_0 country_detector_service_26_0 device_policy_service_26_0 deviceidle_service_26_0 device_identifiers_service_26_0 display_service_26_0 font_service_26_0 dreams_service_26_0 dropbox_service_26_0 ethernet_service_26_0 fingerprint_service_26_0 graphicsstats_service_26_0 hardware_properties_service_26_0 input_method_service_26_0 input_service_26_0 imms_service_26_0 ipsec_service_26_0 jobscheduler_service_26_0 launcherapps_service_26_0 location_service_26_0 media_projection_service_26_0 media_router_service_26_0 media_session_service_26_0 midi_service_26_0 mount_service_26_0 netpolicy_service_26_0 netstats_service_26_0 network_management_service_26_0 notification_service_26_0 package_service_26_0 permission_service_26_0 power_service_26_0 print_service_26_0 procstats_service_26_0 registry_service_26_0 restrictions_service_26_0 rttmanager_service_26_0 search_service_26_0 sec_key_att_app_id_provider_service_26_0 sensorservice_service_26_0 servicediscovery_service_26_0 settings_service_26_0 shortcut_service_26_0 statu***ar_service_26_0 storagestats_service_26_0 textclassification_service_26_0 textservices_service_26_0 telecom_service_26_0 trust_service_26_0 tv_input_service_26_0 uimode_service_26_0 usagestats_service_26_0 u***_service_26_0 user_service_26_0 vibrator_service_26_0 voiceinteraction_service_26_0 wallpaper_service_26_0 webviewupdate_service_26_0 wifip2p_service_26_0 wifi_service_26_0 wifiaware_service_26_0 cnbot_service_26_0)) +(typeattributeset ephemeral_app_api_service (batteryproperties_service_26_0 accessibility_service_26_0 account_service_26_0 activity_service_26_0 alarm_service_26_0 appops_service_26_0 appwidget_service_26_0 assetatlas_service_26_0 audio_service_26_0 autofill_service_26_0 backup_service_26_0 batterystats_service_26_0 bluetooth_manager_service_26_0 clipboard_service_26_0 IProxyService_service_26_0 companion_device_service_26_0 connectivity_service_26_0 connmetrics_service_26_0 consumer_ir_service_26_0 content_service_26_0 country_detector_service_26_0 deviceidle_service_26_0 device_identifiers_service_26_0 display_service_26_0 font_service_26_0 dreams_service_26_0 dropbox_service_26_0 graphicsstats_service_26_0 hardware_properties_service_26_0 input_method_service_26_0 input_service_26_0 imms_service_26_0 ipsec_service_26_0 jobscheduler_service_26_0 launcherapps_service_26_0 location_service_26_0 media_projection_service_26_0 media_router_service_26_0 media_session_service_26_0 midi_service_26_0 mount_service_26_0 netpolicy_service_26_0 netstats_service_26_0 network_management_service_26_0 notification_service_26_0 package_service_26_0 permission_service_26_0 power_service_26_0 print_service_26_0 procstats_service_26_0 registry_service_26_0 restrictions_service_26_0 rttmanager_service_26_0 search_service_26_0 sensorservice_service_26_0 servicediscovery_service_26_0 settings_service_26_0 statu***ar_service_26_0 storagestats_service_26_0 textclassification_service_26_0 textservices_service_26_0 telecom_service_26_0 tv_input_service_26_0 uimode_service_26_0 usagestats_service_26_0 user_service_26_0 vibrator_service_26_0 voiceinteraction_service_26_0 webviewupdate_service_26_0 cnbot_service_26_0)) (typeattributeset system_api_service (cpuinfo_service_26_0 dbinfo_service_26_0 diskstats_service_26_0 gfxinfo_service_26_0 hdmi_control_service_26_0 lock_settings_service_26_0 meminfo_service_26_0 network_score_service_26_0 oem_lock_service_26_0 persistent_data_block_service_26_0 serial_service_26_0 updatelock_service_26_0 wifiscanner_service_26_0 window_service_26_0)) -(typeattributeset service_manager_type (audioserver_service_26_0 batteryproperties_service_26_0 bluetooth_service_26_0 cameraserver_service_26_0 default_android_service_26_0 drmserver_service_26_0 dumpstate_service_26_0 fingerprintd_service_26_0 hal_fingerprint_service_26_0 gatekeeper_service_26_0 gpu_service_26_0 inputflinger_service_26_0 incident_service_26_0 installd_service_26_0 keystore_service_26_0 mediaserver_service_26_0 mediametrics_service_26_0 mediaextractor_service_26_0 mediacodec_service_26_0 mediadrmserver_service_26_0 mediacasserver_service_26_0 netd_service_26_0 nfc_service_26_0 radio_service_26_0 storaged_service_26_0 surfaceflinger_service_26_0 system_app_service_26_0 update_engine_service_26_0 virtual_touchpad_service_26_0 vr_hwc_service_26_0 accessibility_service_26_0 account_service_26_0 activity_service_26_0 alarm_service_26_0 appops_service_26_0 appwidget_service_26_0 assetatlas_service_26_0 audio_service_26_0 autofill_service_26_0 backup_service_26_0 batterystats_service_26_0 battery_service_26_0 bluetooth_manager_service_26_0 cameraproxy_service_26_0 clipboard_service_26_0 contexthub_service_26_0 IProxyService_service_26_0 commontime_management_service_26_0 companion_device_service_26_0 connectivity_service_26_0 connmetrics_service_26_0 consumer_ir_service_26_0 content_service_26_0 country_detector_service_26_0 coverage_service_26_0 cpuinfo_service_26_0 dbinfo_service_26_0 device_policy_service_26_0 deviceidle_service_26_0 device_identifiers_service_26_0 devicestoragemonitor_service_26_0 diskstats_service_26_0 display_service_26_0 font_service_26_0 netd_listener_service_26_0 DockObserver_service_26_0 dreams_service_26_0 dropbox_service_26_0 ethernet_service_26_0 fingerprint_service_26_0 gfxinfo_service_26_0 graphicsstats_service_26_0 hardware_service_26_0 hardware_properties_service_26_0 hdmi_control_service_26_0 input_method_service_26_0 input_service_26_0 imms_service_26_0 ipsec_service_26_0 jobscheduler_service_26_0 launcherapps_service_26_0 location_service_26_0 lock_settings_service_26_0 media_projection_service_26_0 media_router_service_26_0 media_session_service_26_0 meminfo_service_26_0 midi_service_26_0 mount_service_26_0 netpolicy_service_26_0 netstats_service_26_0 network_management_service_26_0 network_score_service_26_0 network_time_update_service_26_0 notification_service_26_0 oem_lock_service_26_0 otadexopt_service_26_0 overlay_service_26_0 package_service_26_0 permission_service_26_0 persistent_data_block_service_26_0 pinner_service_26_0 power_service_26_0 print_service_26_0 processinfo_service_26_0 procstats_service_26_0 recovery_service_26_0 registry_service_26_0 restrictions_service_26_0 rttmanager_service_26_0 samplingprofiler_service_26_0 scheduling_policy_service_26_0 search_service_26_0 sec_key_att_app_id_provider_service_26_0 sensorservice_service_26_0 serial_service_26_0 servicediscovery_service_26_0 settings_service_26_0 shortcut_service_26_0 statu***ar_service_26_0 storagestats_service_26_0 task_service_26_0 textclassification_service_26_0 textservices_service_26_0 telecom_service_26_0 trust_service_26_0 tv_input_service_26_0 uimode_service_26_0 updatelock_service_26_0 usagestats_service_26_0 u***_service_26_0 user_service_26_0 vibrator_service_26_0 voiceinteraction_service_26_0 vr_manager_service_26_0 wallpaper_service_26_0 webviewupdate_service_26_0 wifip2p_service_26_0 wifiscanner_service_26_0 wifi_service_26_0 wificond_service_26_0 wifiaware_service_26_0 window_service_26_0)) +(typeattributeset service_manager_type (audioserver_service_26_0 batteryproperties_service_26_0 bluetooth_service_26_0 cameraserver_service_26_0 default_android_service_26_0 drmserver_service_26_0 dumpstate_service_26_0 fingerprintd_service_26_0 hal_fingerprint_service_26_0 gatekeeper_service_26_0 gpu_service_26_0 inputflinger_service_26_0 incident_service_26_0 installd_service_26_0 keystore_service_26_0 mediaserver_service_26_0 mediametrics_service_26_0 mediaextractor_service_26_0 mediacodec_service_26_0 mediadrmserver_service_26_0 mediacasserver_service_26_0 netd_service_26_0 nfc_service_26_0 radio_service_26_0 storaged_service_26_0 surfaceflinger_service_26_0 system_app_service_26_0 update_engine_service_26_0 virtual_touchpad_service_26_0 vr_hwc_service_26_0 accessibility_service_26_0 account_service_26_0 activity_service_26_0 alarm_service_26_0 appops_service_26_0 appwidget_service_26_0 assetatlas_service_26_0 audio_service_26_0 autofill_service_26_0 backup_service_26_0 batterystats_service_26_0 battery_service_26_0 bluetooth_manager_service_26_0 cameraproxy_service_26_0 clipboard_service_26_0 contexthub_service_26_0 IProxyService_service_26_0 commontime_management_service_26_0 companion_device_service_26_0 connectivity_service_26_0 connmetrics_service_26_0 consumer_ir_service_26_0 content_service_26_0 country_detector_service_26_0 coverage_service_26_0 cpuinfo_service_26_0 dbinfo_service_26_0 device_policy_service_26_0 deviceidle_service_26_0 device_identifiers_service_26_0 devicestoragemonitor_service_26_0 diskstats_service_26_0 display_service_26_0 font_service_26_0 netd_listener_service_26_0 DockObserver_service_26_0 dreams_service_26_0 dropbox_service_26_0 ethernet_service_26_0 fingerprint_service_26_0 gfxinfo_service_26_0 graphicsstats_service_26_0 hardware_service_26_0 hardware_properties_service_26_0 hdmi_control_service_26_0 input_method_service_26_0 input_service_26_0 imms_service_26_0 ipsec_service_26_0 jobscheduler_service_26_0 launcherapps_service_26_0 location_service_26_0 lock_settings_service_26_0 media_projection_service_26_0 media_router_service_26_0 media_session_service_26_0 meminfo_service_26_0 midi_service_26_0 mount_service_26_0 netpolicy_service_26_0 netstats_service_26_0 network_management_service_26_0 network_score_service_26_0 network_time_update_service_26_0 notification_service_26_0 oem_lock_service_26_0 otadexopt_service_26_0 overlay_service_26_0 package_service_26_0 permission_service_26_0 persistent_data_block_service_26_0 pinner_service_26_0 power_service_26_0 print_service_26_0 processinfo_service_26_0 procstats_service_26_0 recovery_service_26_0 registry_service_26_0 restrictions_service_26_0 rttmanager_service_26_0 samplingprofiler_service_26_0 scheduling_policy_service_26_0 search_service_26_0 sec_key_att_app_id_provider_service_26_0 sensorservice_service_26_0 serial_service_26_0 servicediscovery_service_26_0 settings_service_26_0 shortcut_service_26_0 statu***ar_service_26_0 storagestats_service_26_0 task_service_26_0 textclassification_service_26_0 textservices_service_26_0 telecom_service_26_0 trust_service_26_0 tv_input_service_26_0 uimode_service_26_0 updatelock_service_26_0 usagestats_service_26_0 u***_service_26_0 user_service_26_0 vibrator_service_26_0 voiceinteraction_service_26_0 vr_manager_service_26_0 wallpaper_service_26_0 webviewupdate_service_26_0 wifip2p_service_26_0 wifiscanner_service_26_0 wifi_service_26_0 wificond_service_26_0 wifiaware_service_26_0 window_service_26_0 cnbot_service_26_0)) (typeattributeset hwservice_manager_type (default_android_hwservice_26_0 fwk_display_hwservice_26_0 fwk_scheduler_hwservice_26_0 fwk_sensor_hwservice_26_0 hal_audio_hwservice_26_0 hal_bluetooth_hwservice_26_0 hal_bootctl_hwservice_26_0 hal_camera_hwservice_26_0 hal_configstore_ISurfaceFlingerConfigs_26_0 hal_contexthub_hwservice_26_0 hal_drm_hwservice_26_0 hal_dumpstate_hwservice_26_0 hal_fingerprint_hwservice_26_0 hal_gatekeeper_hwservice_26_0 hal_gnss_hwservice_26_0 hal_graphics_allocator_hwservice_26_0 hal_graphics_composer_hwservice_26_0 hal_graphics_mapper_hwservice_26_0 hal_health_hwservice_26_0 hal_ir_hwservice_26_0 hal_keymaster_hwservice_26_0 hal_light_hwservice_26_0 hal_memtrack_hwservice_26_0 hal_nfc_hwservice_26_0 hal_oemlock_hwservice_26_0 hal_omx_hwservice_26_0 hal_power_hwservice_26_0 hal_renderscript_hwservice_26_0 hal_sensors_hwservice_26_0 hal_telephony_hwservice_26_0 hal_thermal_hwservice_26_0 hal_tv_cec_hwservice_26_0 hal_tv_input_hwservice_26_0 hal_u***_hwservice_26_0 hal_vibrator_hwservice_26_0 hal_vr_hwservice_26_0 hal_weaver_hwservice_26_0 hal_wifi_hwservice_26_0 hal_wifi_supplicant_hwservice_26_0 hidl_allocator_hwservice_26_0 hidl_base_hwservice_26_0 hidl_manager_hwservice_26_0 hidl_memory_hwservice_26_0 hidl_token_hwservice_26_0 system_wifi_keystore_hwservice_26_0)) (typeattributeset same_process_hwservice (hal_graphics_mapper_hwservice_26_0 hal_renderscript_hwservice_26_0)) (typeattributeset coredomain_hwservice (fwk_display_hwservice_26_0 fwk_scheduler_hwservice_26_0 fwk_sensor_hwservice_26_0 hidl_allocator_hwservice_26_0 hidl_manager_hwservice_26_0 hidl_memory_hwservice_26_0 hidl_token_hwservice_26_0 system_wifi_keystore_hwservice_26_0)) @@ -1518,6 +1518,8 @@ (typeattribute zygote_26_0) (roletype object_r zygote_26_0) (typeattribute zygote_exec_26_0) +(roletype object_r cnbot_service_26_0) +(typeattribute cnbot_service_26_0) (roletype object_r zygote_exec_26_0) (type hostapd_socket) (roletype object_r hostapd_socket) diff --git a/system/sepolicy/prebuilts/api/26.0/private/service_contexts b/system/sepolicy/prebuilts/api/26.0/private/service_contexts index dc77cb9..cf0dec9 100644 --- a/system/sepolicy/prebuilts/api/26.0/private/service_contexts +++ b/system/sepolicy/prebuilts/api/26.0/private/service_contexts @@ -169,4 +169,5 @@ wifi u:object_r:wifi_service:s0 wificond u:object_r:wificond_service:s0 wifiaware u:object_r:wifiaware_service:s0 window u:object_r:window_service:s0 +cnbot u:object_r:cnbot_service:s0 * u:object_r:default_android_service:s0 diff --git a/system/sepolicy/prebuilts/api/26.0/public/service.te b/system/sepolicy/prebuilts/api/26.0/public/service.te index da540db..e96bdbf 100644 --- a/system/sepolicy/prebuilts/api/26.0/public/service.te +++ b/system/sepolicy/prebuilts/api/26.0/public/service.te @@ -145,3 +145,4 @@ type wifi_service, app_api_service, system_server_service, service_manager_type; type wificond_service, service_manager_type; type wifiaware_service, app_api_service, system_server_service, service_manager_type; type window_service, system_api_service, system_server_service, service_manager_type; +type cnbot_service,app_api_service, ephemeral_app_api_service, system_server_service, service_manager_type; diff --git a/system/sepolicy/private/compat/26.0/26.0.cil b/system/sepolicy/private/compat/26.0/26.0.cil index 40bec84..2813737 100644 --- a/system/sepolicy/private/compat/26.0/26.0.cil +++ b/system/sepolicy/private/compat/26.0/26.0.cil @@ -706,3 +706,4 @@ (typeattributeset zygote_26_0 (zygote)) (typeattributeset zygote_exec_26_0 (zygote_exec)) (typeattributeset zygote_socket_26_0 (zygote_socket)) +(typeattributeset cnbot_service_26_0 (cnbot_service)) diff --git a/system/sepolicy/private/service_contexts b/system/sepolicy/private/service_contexts index a82243f..e7a1ce0 100644 --- a/system/sepolicy/private/service_contexts +++ b/system/sepolicy/private/service_contexts @@ -171,4 +171,5 @@ wifi u:object_r:wifi_service:s0 wificond u:object_r:wificond_service:s0 wifiaware u:object_r:wifiaware_service:s0 window u:object_r:window_service:s0 +cnbot u:object_r:cnbot_service:s0 * u:object_r:default_android_service:s0 diff --git a/system/sepolicy/public/service.te b/system/sepolicy/public/service.te index e97b864..df51a95 100644 --- a/system/sepolicy/public/service.te +++ b/system/sepolicy/public/service.te @@ -148,3 +148,4 @@ type wifi_service, app_api_service, system_server_service, service_manager_type; type wificond_service, service_manager_type; type wifiaware_service, app_api_service, system_server_service, service_manager_type; type window_service, system_api_service, system_server_service, service_manager_type; +type cnbot_service,app_api_service, ephemeral_app_api_service, system_server_service, service_manager_type; |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 05:39 , Processed in 0.753598 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3017
