本程序可以在Wirelesslink 88W8801 WiFi 上直接开发
问题,否则很容易引发HardFault,以及其他莫名的问题 文件管理器看到的文件列表,在FileZilla里面怎么找不到文件夹里面的 【BUG解析】 1.Windows文件管理器中往FTP里面复制的某个文件可能会失败。(这是Windows 系统本身的一个判断关系有 bug,跟 ftp 没有关系) 2. tcp_accept 函数没有对错。当内存不足时收到的 FTP 连接,程序连接卡。 解决办法请参见本文第【程序 运行截图】 1.使用Windows文件管理器通过计算机名服务器并上传文件(已FTP管理员用户,密码为123456) 的IPv6地址访问FTP服务器 【程序运行结果】 STM32F103RE SDIO 88W8801 SystemCoreClock=72000000 LSI is ready! [Clock] freq=400.0kHz, requested=400.0kHz, divider=178 RESPCMD63, RESP1_b0ff8000 RESPCMD63, RESP1_b0300000 Number of I/O Functions: 3 Memory Present: 0 Relative Card Address: 0x0001 Card selected! RESP1_00001e00 [Clock] freq=24000.0kHz, requested=25000.0kHz, divider=1 [CIS] func=0, ptr=0x00008000 Product Information: Marvell 802.11 SDIO ID: 48 Manufacturer Code: 0x02df Manufacturer Information: 0x9138 Card Function Code: 0x0c System Initialization Bit Mask: 0x00 Maximum Block Size: 256 Maximum Transfer Rate Code: 0x5a [CIS] func=1, ptr=0x00008080 Manufacturer Code: 0x02df Manufacturer Information: 0x9139 Card Function Code: 0x0c System Initialization Bit Mask: 0x00 Maximum Block Size: 512 [CIS] func=2, ptr=0x00008100 [CIS] func=3, ptr=0x00008180 Firmware is successfully downloaded! SPI Flash: M=0xef, ID=0x17 SPI Flash: M=0xef, ID=0x4018 Disk is mounted! CMDRESP 0x804d at 29ms MAC Addr: 20:32:33:3B:18:F3 IP_FORWARD is enabled! LWIP_IPV6_FORWARD is enabled! Join group FF02::1! bss=0x00 IPv6 link-local address: FE80::2232:33FF:FE3B:18F3 Join group FF02::1! bss=0x10 IPv6 link-local address for micro AP: FE80::2232:33FF:FE3B:18F3 IPv6 address for micro AP: FD20::1 Join group FF02::2! bss=0x10 [Send] len=86, bss=0x10, port=-1 [Send] len=86, bss=0x10, port=-1 CMDRESP 0x8006 at 439ms SSID '??WIFI', MAC 1C:D5:E2:72:98:60, RSSI 58, Channel 1 Timestamp 1048887879992, Beacon Interval 100, TSF timestamp: 212334 Capability: 0x0411 (Security: WPA2, Mode: Infrastructure) Rates: 1.0Mbps 2.0Mbps 5.5Mbps 11.0Mbps 6.0Mbps 9.0Mbps 12.0Mbps 18.0Mbps SSID 'ChinaNet-2jZu', MAC 18:52:07:03:0F:FE, RSSI 68, Channel 4 Timestamp 281568961, Beacon Interval 100, TSF timestamp: 533025 Capability: 0x0411 (Security: WPA2, Mode: Infrastructure) Rates: 1.0Mbps 2.0Mbps 5.5Mbps 11.0Mbps 18.0Mbps 24.0Mbps 36.0Mbps 54.0Mbps CMDRESP 0x8006 at 435ms SSID 'mi', MAC 78:11:DC:40:70:41, RSSI 80, Channel 6 Timestamp 1505121991463, Beacon Interval 100, TSF timestamp: 758319 Capability: 0x0c11 (Security: WPA2, Mode: Infrastructure) Rates: 1.0Mbps 2.0Mbps 5.5Mbps 11.0Mbps 9.0Mbps 18.0Mbps 36.0Mbps 54.0Mbps SSID 'CMCC-kx7H', MAC 8C:53:D2:47:38:CE, RSSI 48, Channel 8 Timestamp 1505118544330, Beacon Interval 100, TSF timestamp: 970318 Capability: 0x0431 (Security: WPA2, Mode: Infrastructure) Rates: 1.0Mbps 2.0Mbps 5.5Mbps 11.0Mbps 9.0Mbps 18.0Mbps 36.0Mbps 54.0Mbps CMDRESP 0x8006 at 432ms CMDRESP 0x8006 at 220ms Scan finished! CMDRESP 0x80b0 at 1ms [Event] code=0x002e, bss=0x10, size=85, reason=0, mac=20:32:33:3B:18:F3 AP is started! Packet forwarding mode: by host CMDRESP 0x80b1 at 6853ms AP is created! CMDRESP 0x8028 at 0ms CMDRESP 0x8006 at 1648ms CMDRESP 0x80c4 at 7633ms [Event] code=0x002e, bss=0x10, size=85, reason=0, mac=20:32:33:3B:18:F3 AP is started! Packet forwarding mode: by host CMDRESP 0x8012 at 31ms capability=0x0431, status_code=0x0000, aid=0xc003 Waiting for authentication! [Event] code=0x0017, bss=0x00, size=77 WMM status change event occurred! Synchronizing multicast filter! num=1 CMDRESP 0x8010 at 0ms Multicast filter is synchronized! num=1 [Event] code=0x002b, bss=0x00, size=10 Authenticated! [Send] len=350, bss=0x00, port=1 [Recv] len=60, bss=0x00, port=1 Join group FF02::1:FF3B:18F3! bss=0x00 [Send] len=86, bss=0x00, port=2 [Send] len=78, bss=0x00, port=3 Synchronizing multicast filter! num=2 CMDRESP 0x8010 at 0ms Multicast filter is synchronized! num=2 [Send] len=86, bss=0x00, port=4 [Send] len=86, bss=0x00, port=5 [Send] len=350, bss=0x00, port=6 [Recv] len=590, bss=0x00, port=2 [Send] len=350, bss=0x00, port=7 [Recv] len=590, bss=0x00, port=3 [Send] len=42, bss=0x00, port=8 [Send] len=42, bss=0x00, port=9 [Recv] len=92, bss=0x00, port=4 [Send] len=42, bss=0x00, port=10 [Send] len=70, bss=0x00, port=11 -- Packet port 1 released at 3162ms [Send] len=42, bss=0x00, port=1 DHCP supplied address! IP address: 192.168.1.5 Subnet mask: 255.255.255.0 Default gateway: 192.168.1.1 DNS Server: 192.168.1.1 -- Packet port 2 released at 3022ms [Send] len=42, bss=0x00, port=2 dns_test: IP of savannah.nongnu.org is not in cache! Time server IP: not in cache! Packet port 3 released at 3034ms Packet port 4 released at 2844ms Packet port 5 released at 2048ms Packet port 6 released at 1551ms Packet port 7 released at 1083ms Packet port 8 released at 887ms Packet port 9 released at 561ms [Recv] len=142, bss=0x00, port=5 [Send] len=86, bss=0x00, port=3 [Recv] len=42, bss=0x00, port=6 [Send] len=80, bss=0x00, port=4 [Recv] len=86, bss=0x00, port=7 [Recv] len=116, bss=0x00, port=8 [Recv] len=92, bss=0x00, port=9 [Send] len=42, bss=0x00, port=5 [Recv] len=42, bss=0x00, port=10 [Send] len=104, bss=0x00, port=6 [Recv] len=42, bss=0x00, port=11 [Send] len=42, bss=0x00, port=7 [Recv] len=66, bss=0x00, port=12 [Send] len=62, bss=0x00, port=8 [Recv] len=54, bss=0x00, port=13 FTPD accepted [192.168.1.4]:55859! 220 LwIP FTP Service [Send] len=76, bss=0x00, port=9 [Recv] len=64, bss=0x00, port=14 ftpd_sent: 22 bytes of response sent ftpd_recv: received 10 bytes AUTH TLS 530 Please login with USER and PASS. -- Packet port 10 released at 697ms [Send] len=92, bss=0x00, port=10 Packet port 1 released at 694ms Packet port 2 released at 677ms Packet port 3 released at 644ms Packet port 4 released at 640ms Packet port 5 released at 72ms Packet port 6 released at 68ms Packet port 7 released at 65ms Packet port 8 released at 61ms Packet port 11 released at 726ms [Recv] len=64, bss=0x00, port=15 ftpd_sent: 38 bytes of response sent ftpd_sent: processed 10 bytes ftpd_recv: received 10 bytes AUTH SSL 530 Please login with USER and PASS. [Send] len=92, bss=0x00, port=11 [Recv] len=66, bss=0x00, port=1 ftpd_sent: 38 bytes of response sent ftpd_sent: processed 10 bytes ftpd_recv: received 12 bytes USER admin 331 Please specify the password. [Send] len=88, bss=0x00, port=1 [Recv] len=67, bss=0x00, port=2 ftpd_sent: 34 bytes of response sent ftpd_sent: processed 12 bytes ftpd_recv: received 13 bytes PASS 123456 230 Login successful. [Send] len=77, bss=0x00, port=2 [Recv] len=61, bss=0x00, port=3 ftpd_sent: 23 bytes of response sent ftpd_sent: processed 13 bytes ftpd_recv: received 7 bytes CWD / 250 Directory successfully changed. [Send] len=91, bss=0x00, port=3 [Recv] len=59, bss=0x00, port=4 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 7 bytes ftpd_recv: received 5 bytes PWD 257 "/" is the current directory. [Send] len=89, bss=0x00, port=4 [Recv] len=62, bss=0x00, port=5 ftpd_sent: 35 bytes of response sent ftpd_sent: processed 5 bytes ftpd_recv: received 8 bytes TYPE I 200 Switching to Binary mode. [Send] len=85, bss=0x00, port=5 [Recv] len=60, bss=0x00, port=6 ftpd_sent: 31 bytes of response sent ftpd_sent: processed 8 bytes ftpd_recv: received 6 bytes PASV 227 Entering Passive Mode (192,168,1,5,225,204). [Send] len=104, bss=0x00, port=6 [Recv] len=60, bss=0x00, port=7 ftpd_sent: 50 bytes of response sent ftpd_sent: processed 6 bytes ftpd_recv: received 6 bytes LIST 150 Here comes the directory listing. [Send] len=93, bss=0x00, port=7 [Recv] len=66, bss=0x00, port=8 [Send] len=62, bss=0x00, port=8 [Recv] len=54, bss=0x00, port=9 FTPD data connection to [192.168.1.4]:55860 is established! 07-03-2020 11:30PM 3007503 ????.mp3 07-03-2020 11:27PM 07-03-2020 11:29PM 07-03-2020 11:31PM 1575040 ????.mp3 07-03-2020 11:31PM 1927296 ????.mp3 07-03-2020 11:32PM 3007503 j20.mp3 FTPD data connection [192.168.1.4]:55860 is shutdown by the server! -- Packet port 9 released at 286ms [Send] len=377, bss=0x00, port=9 [Recv] len=54, bss=0x00, port=10 [Recv] len=54, bss=0x00, port=11 FTPD data connection [192.168.1.4]:55860 is closed by the client! -- Packet port 10 released at 284ms [Send] len=54, bss=0x00, port=10 Packet port 1 released at 221ms Packet port 2 released at 204ms Packet port 3 released at 184ms Packet port 4 released at 168ms Packet port 5 released at 151ms Packet port 6 released at 132ms Packet port 7 released at 115ms Packet port 11 released at 264ms [Send] len=42, bss=0x00, port=11 [Send] len=99, bss=0x00, port=1 [Send] len=100, bss=0x00, port=2 [Send] len=78, bss=0x00, port=3 [Recv] len=115, bss=0x00, port=12 DNS Found IP of savannah.nongnu.org: 209.51.188.72 TCP socket is connecting to 209.51.188.72... [Send] len=62, bss=0x00, port=4 [Recv] len=116, bss=0x00, port=13 Time server IP: 128.138.140.44 Connecting to 128.138.140.44... [Send] len=62, bss=0x00, port=5 [Recv] len=54, bss=0x00, port=14 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 6 bytes 226 Directory send OK. [Send] len=78, bss=0x00, port=6 [Recv] len=62, bss=0x00, port=15 Connected! [Send] len=54, bss=0x00, port=7 Packet port 1 released at 285ms Packet port 2 released at 285ms Packet port 3 released at 285ms Packet port 4 released at 272ms Packet port 5 released at 261ms Packet port 6 released at 209ms Packet port 8 released at 422ms Packet port 9 released at 360ms Packet port 10 released at 343ms Packet port 11 released at 317ms [Recv] len=54, bss=0x00, port=1 ftpd_sent: 24 bytes of response sent [Recv] len=54, bss=0x00, port=2 [Send] len=54, bss=0x00, port=8 [Send] len=62, bss=0x00, port=9 [Recv] len=54, bss=0x00, port=3 [Send] len=54, bss=0x00, port=10 [Recv] len=58, bss=0x00, port=4 Time from network: 2020-07-03 23:43:07 RTC is updated from 2020-7-3 23:41:35 to 2020-7-3 23:43:07 (UTC+8)! Connection to the time server is closed! [Send] len=54, bss=0x00, port=11 [Recv] len=54, bss=0x00, port=5 [Send] len=42, bss=0x00, port=1 IPv6 address 1: 2409:8A62:362:1050:2232:33FF:FE3B:18F3 DNS Server: FE80::1 [Send] len=99, bss=0x00, port=2 dns_test: IP of savannah.nongnu.org is not in cache! [Recv] len=127, bss=0x00, port=6 DNS Found IP of savannah.nongnu.org: 2001:470:142::72 TCP socket is connecting to 2001:470:142::72... [Send] len=82, bss=0x00, port=3 [Send] len=86, bss=0x00, port=4 [Recv] len=86, bss=0x00, port=7 [Send] len=86, bss=0x00, port=5 [Recv] len=82, bss=0x00, port=8 TCP socket is connected! err=0 [Send] len=135, bss=0x00, port=6 Packet port 1 released at 408ms Packet port 2 released at 402ms Packet port 3 released at 382ms Packet port 4 released at 126ms Packet port 5 released at 27ms Packet port 7 released at 1121ms Packet port 8 released at 1051ms Packet port 9 released at 1052ms Packet port 10 released at 887ms Packet port 11 released at 869ms [Recv] len=74, bss=0x00, port=9 [Recv] len=1498, bss=0x00, port=10 1424 bytes received! [Recv] len=1498, bss=0x00, port=11 1424 bytes received! [Send] len=74, bss=0x00, port=7 [Recv] len=1498, bss=0x00, port=12 1424 bytes received! [Recv] len=1498, bss=0x00, port=13 1424 bytes received! [Send] len=74, bss=0x00, port=8 [Send] len=42, bss=0x00, port=9 [Recv] len=1498, bss=0x00, port=14 1424 bytes received! [Recv] len=1498, bss=0x00, port=15 1424 bytes received! [Send] len=74, bss=0x00, port=10 [Recv] len=1498, bss=0x00, port=1 1424 bytes received! [Recv] len=1498, bss=0x00, port=2 1424 bytes received! [Send] len=74, bss=0x00, port=11 [Recv] len=1498, bss=0x00, port=3 1424 bytes received! [Recv] len=1498, bss=0x00, port=4 1424 bytes received! [Send] len=74, bss=0x00, port=1 [Recv] len=1498, bss=0x00, port=5 1424 bytes received! [Recv] len=1498, bss=0x00, port=6 1424 bytes received! [Send] len=74, bss=0x00, port=2 [Recv] len=1498, bss=0x00, port=7 1424 bytes received! [Recv] len=1498, bss=0x00, port=8 1424 bytes received! [Send] len=74, bss=0x00, port=3 [Recv] len=1498, bss=0x00, port=9 1424 bytes received! [Recv] len=1498, bss=0x00, port=10 1424 bytes received! [Send] len=74, bss=0x00, port=4 [Send] len=62, bss=0x00, port=5 Packet port 1 released at 415ms Packet port 2 released at 394ms Packet port 3 released at 38ms Packet port 4 released at 16ms Packet port 6 released at 1614ms Packet port 7 released at 1209ms Packet port 8 released at 1197ms Packet port 9 released at 1028ms Packet port 10 released at 827ms Packet port 11 released at 807ms [Recv] len=1498, bss=0x00, port=11 1424 bytes received! [Recv] len=1498, bss=0x00, port=12 1424 bytes received! [Send] len=74, bss=0x00, port=6 [Recv] len=62, bss=0x00, port=13 TCP socket is connected! err=0 [Send] len=115, bss=0x00, port=7 [Recv] len=1498, bss=0x00, port=14 1424 bytes received! [Recv] len=1498, bss=0x00, port=15 1424 bytes received! [Send] len=74, bss=0x00, port=8 [Recv] len=1498, bss=0x00, port=1 1424 bytes received! [Recv] len=1498, bss=0x00, port=2 1424 bytes received! [Send] len=74, bss=0x00, port=9 [Recv] len=1498, bss=0x00, port=3 1424 bytes received! [Recv] len=522, bss=0x00, port=4 448 bytes received! [Send] len=74, bss=0x00, port=10 [Recv] len=86, bss=0x00, port=5 [Send] len=86, bss=0x00, port=11 [Recv] len=1448, bss=0x00, port=6 [Send] len=66, bss=0x00, port=1 [Recv] len=1448, bss=0x00, port=7 2788 bytes received! [Send] len=54, bss=0x00, port=2 [Recv] len=1448, bss=0x00, port=8 [Send] len=66, bss=0x00, port=3 [Recv] len=74, bss=0x00, port=9 TCP socket is closed! err=0, count=33200 [Send] len=74, bss=0x00, port=4 Packet port 1 released at 2177ms Packet port 2 released at 1768ms Packet port 3 released at 782ms Packet port 5 released at 3882ms Packet port 6 released at 3546ms Packet port 7 released at 3539ms Packet port 8 released at 3523ms Packet port 9 released at 3171ms Packet port 10 released at 3141ms Packet port 11 released at 2828ms [Send] len=86, bss=0x00, port=5 [Recv] len=78, bss=0x00, port=10 [Recv] len=74, bss=0x00, port=11 [Recv] len=1448, bss=0x00, port=12 [Send] len=66, bss=0x00, port=6 1394 bytes received! [Recv] len=42, bss=0x00, port=13 [Send] len=42, bss=0x00, port=7 [Recv] len=42, bss=0x00, port=14 [Send] len=42, bss=0x00, port=8 [Recv] len=42, bss=0x00, port=15 [Send] len=42, bss=0x00, port=9 [Recv] len=42, bss=0x00, port=1 [Send] len=42, bss=0x00, port=10 [Recv] len=42, bss=0x00, port=2 [Send] len=42, bss=0x00, port=11 [Recv] len=42, bss=0x00, port=3 [Send] len=42, bss=0x00, port=1 [Recv] len=42, bss=0x00, port=4 [Send] len=42, bss=0x00, port=2 [Recv] len=1448, bss=0x00, port=5 1394 bytes received! [Send] len=54, bss=0x00, port=3 Packet port 1 released at 3442ms Packet port 2 released at 3440ms Packet port 4 released at 62614ms Packet port 5 released at 62489ms Packet port 6 released at 61992ms Packet port 7 released at 61159ms Packet port 8 released at 3489ms Packet port 9 released at 3486ms Packet port 10 released at 3483ms Packet port 11 released at 3479ms [Recv] len=1448, bss=0x00, port=6 [Send] len=66, bss=0x00, port=4 [Recv] len=1448, bss=0x00, port=7 [Send] len=66, bss=0x00, port=5 [Recv] len=1448, bss=0x00, port=8 [Send] len=66, bss=0x00, port=6 1394 bytes received! [Recv] len=1448, bss=0x00, port=9 4182 bytes received! [Send] len=54, bss=0x00, port=7 [Recv] len=1448, bss=0x00, port=10 1394 bytes received! [Recv] len=1448, bss=0x00, port=11 1394 bytes received! [Send] len=54, bss=0x00, port=8 [Recv] len=1448, bss=0x00, port=12 [Send] len=66, bss=0x00, port=9 [Recv] len=1448, bss=0x00, port=13 [Send] len=66, bss=0x00, port=10 [Recv] len=1448, bss=0x00, port=14 [Send] len=66, bss=0x00, port=11 1394 bytes received! [Recv] len=1448, bss=0x00, port=15 4182 bytes received! [Send] len=54, bss=0x00, port=1 [Recv] len=1448, bss=0x00, port=1 1394 bytes received! [Recv] len=1448, bss=0x00, port=2 [Send] len=66, bss=0x00, port=2 Packet port 1 released at 338ms Packet port 3 released at 2492ms Packet port 4 released at 2167ms Packet port 5 released at 2163ms Packet port 6 released at 2008ms Packet port 7 released at 1681ms Packet port 8 released at 1349ms Packet port 9 released at 1025ms Packet port 10 released at 1022ms Packet port 11 released at 697ms [Recv] len=1448, bss=0x00, port=3 [Send] len=66, bss=0x00, port=3 [Recv] len=1448, bss=0x00, port=4 4182 bytes received! [Send] len=54, bss=0x00, port=4 [Recv] len=1448, bss=0x00, port=5 1394 bytes received! [Send] len=54, bss=0x00, port=5 [Recv] len=1448, bss=0x00, port=6 [Send] len=66, bss=0x00, port=6 [Recv] len=1448, bss=0x00, port=7 [Send] len=66, bss=0x00, port=7 [Recv] len=1448, bss=0x00, port=8 4182 bytes received! [Send] len=54, bss=0x00, port=8 [Recv] len=1448, bss=0x00, port=9 1394 bytes received! [Recv] len=1192, bss=0x00, port=10 1138 bytes received! TCP socket is closed! err=0, count=33200 [Send] len=54, bss=0x00, port=9 [Recv] len=42, bss=0x00, port=11 [Send] len=42, bss=0x00, port=10 [Recv] len=66, bss=0x00, port=12 ftpd_recv: received 12 bytes CWD public 250 Directory successfully changed. [Send] len=91, bss=0x00, port=11 [Recv] len=59, bss=0x00, port=13 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 12 bytes ftpd_recv: received 5 bytes PWD 257 "/public" is the current directory. [Send] len=95, bss=0x00, port=1 [Recv] len=60, bss=0x00, port=14 ftpd_sent: 41 bytes of response sent ftpd_sent: processed 5 bytes ftpd_recv: received 6 bytes PASV 227 Entering Passive Mode (192,168,1,5,225,208). -- Packet port 2 released at 10132ms [Send] len=104, bss=0x00, port=2 [Recv] len=60, bss=0x00, port=15 ftpd_sent: 50 bytes of response sent ftpd_sent: processed 6 bytes ftpd_recv: received 6 bytes LIST 150 Here comes the directory listing. -- Packet port 3 released at 9826ms [Send] len=93, bss=0x00, port=3 [Recv] len=66, bss=0x00, port=1 -- Packet port 4 released at 9424ms [Send] len=62, bss=0x00, port=4 Packet port 5 released at 2581ms Packet port 6 released at 2256ms Packet port 7 released at 1932ms Packet port 8 released at 1196ms Packet port 9 released at 859ms Packet port 10 released at 115ms Packet port 11 released at 103ms [Recv] len=54, bss=0x00, port=2 FTPD data connection to [192.168.1.4]:55874 is established! 07-03-2020 11:35PM 179 446clk.txt 07-03-2020 11:35PM 15870 446ze_board.ioc 07-03-2020 11:36PM 593640 DDB1??MCU????.docx FTPD data connection [192.168.1.4]:55874 is shutdown by the server! [Send] len=238, bss=0x00, port=5 [Recv] len=54, bss=0x00, port=3 [Recv] len=54, bss=0x00, port=4 FTPD data connection [192.168.1.4]:55874 is closed by the client! [Send] len=54, bss=0x00, port=6 [Recv] len=54, bss=0x00, port=5 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 6 bytes 226 Directory send OK. [Send] len=78, bss=0x00, port=7 [Recv] len=54, bss=0x00, port=6 ftpd_sent: 24 bytes of response sent [Recv] len=60, bss=0x00, port=7 ftpd_recv: received 6 bytes CDUP 500 Unknown command. [Send] len=76, bss=0x00, port=8 [Recv] len=62, bss=0x00, port=8 ftpd_sent: 22 bytes of response sent ftpd_sent: processed 6 bytes ftpd_recv: received 8 bytes CWD .. 250 Directory successfully changed. [Send] len=91, bss=0x00, port=9 [Recv] len=59, bss=0x00, port=9 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 8 bytes ftpd_recv: received 5 bytes PWD 257 "/" is the current directory. [Send] len=89, bss=0x00, port=10 [Recv] len=54, bss=0x00, port=10 ftpd_sent: 35 bytes of response sent ftpd_sent: processed 5 bytes [Recv] len=64, bss=0x00, port=11 ftpd_recv: received 10 bytes CWD test 250 Directory successfully changed. [Send] len=91, bss=0x00, port=11 [Recv] len=59, bss=0x00, port=12 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 10 bytes ftpd_recv: received 5 bytes PWD 257 "/test" is the current directory. -- Packet port 1 released at 1524ms [Send] len=93, bss=0x00, port=1 [Recv] len=60, bss=0x00, port=13 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 5 bytes ftpd_recv: received 6 bytes PASV 227 Entering Passive Mode (192,168,1,5,225,209). -- Packet port 2 released at 1523ms [Send] len=104, bss=0x00, port=2 [Recv] len=60, bss=0x00, port=14 ftpd_sent: 50 bytes of response sent ftpd_sent: processed 6 bytes ftpd_recv: received 6 bytes LIST 150 Here comes the directory listing. -- Packet port 3 released at 1523ms [Send] len=93, bss=0x00, port=3 [Recv] len=66, bss=0x00, port=15 -- Packet port 4 released at 1524ms [Send] len=62, bss=0x00, port=4 [Recv] len=54, bss=0x00, port=1 FTPD data connection to [192.168.1.4]:55875 is established! 07-03-2020 11:35PM 1141 cmdlist.txt 07-03-2020 11:35PM 10811 adt2001_pins_446ze.xlsx FTPD data connection [192.168.1.4]:55875 is shutdown by the server! -- Packet port 5 released at 1495ms [Send] len=174, bss=0x00, port=5 [Recv] len=54, bss=0x00, port=2 [Recv] len=54, bss=0x00, port=3 FTPD data connection [192.168.1.4]:55875 is closed by the client! -- Packet port 6 released at 1499ms [Send] len=54, bss=0x00, port=6 Packet port 7 released at 1393ms Packet port 8 released at 720ms Packet port 9 released at 703ms Packet port 10 released at 687ms [Recv] len=54, bss=0x00, port=4 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 6 bytes 226 Directory send OK. [Send] len=78, bss=0x00, port=7 [Recv] len=54, bss=0x00, port=5 ftpd_sent: 24 bytes of response sent [Recv] len=60, bss=0x00, port=6 ftpd_recv: received 6 bytes CDUP 500 Unknown command. [Send] len=76, bss=0x00, port=8 [Recv] len=62, bss=0x00, port=7 ftpd_sent: 22 bytes of response sent ftpd_sent: processed 6 bytes ftpd_recv: received 8 bytes CWD .. 250 Directory successfully changed. [Send] len=91, bss=0x00, port=9 [Recv] len=59, bss=0x00, port=8 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 8 bytes ftpd_recv: received 5 bytes PWD 257 "/" is the current directory. [Send] len=89, bss=0x00, port=10 Packet port 1 released at 1231ms Packet port 2 released at 1209ms Packet port 3 released at 1188ms Packet port 4 released at 1182ms Packet port 5 released at 1139ms Packet port 6 released at 1122ms Packet port 7 released at 991ms Packet port 8 released at 67ms Packet port 9 released at 50ms Packet port 11 released at 1285ms [Recv] len=54, bss=0x00, port=9 ftpd_sent: 35 bytes of response sent ftpd_sent: processed 5 bytes [Send] len=54, bss=0x00, port=11 [Recv] len=54, bss=0x00, port=10 [Recv] len=54, bss=0x00, port=11 [Send] len=54, bss=0x00, port=1 [Recv] len=42, bss=0x00, port=12 [Recv] len=42, bss=0x00, port=13 [Recv] len=42, bss=0x00, port=14 [Recv] len=92, bss=0x00, port=15 [Recv] len=92, bss=0x00, port=1 [Recv] len=92, bss=0x00, port=2 [Recv] len=42, bss=0x00, port=3 [Send] len=42, bss=0x00, port=2 [Recv] len=42, bss=0x00, port=4 [Send] len=42, bss=0x00, port=3 [Recv] len=42, bss=0x00, port=5 [Send] len=42, bss=0x00, port=4 [Recv] len=42, bss=0x00, port=6 [Send] len=42, bss=0x00, port=5 [Recv] len=54, bss=0x00, port=7 FTPD connection [192.168.1.4]:55859 is shutdown by the client! FTPD connection [192.168.1.4]:55859 is closed by the server! [Send] len=54, bss=0x00, port=6 [Recv] len=54, bss=0x00, port=8 [Recv] len=92, bss=0x00, port=9 [Recv] len=92, bss=0x00, port=10 [Recv] len=60, bss=0x00, port=11 [Send] len=54, bss=0x00, port=7 [Recv] len=66, bss=0x00, port=12 [Send] len=62, bss=0x00, port=8 [Recv] len=54, bss=0x00, port=13 FTPD accepted [192.168.1.4]:55879! 220 LwIP FTP Service [Send] len=76, bss=0x00, port=9 [Recv] len=54, bss=0x00, port=14 ftpd_sent: 22 bytes of response sent [Recv] len=66, bss=0x00, port=15 ftpd_recv: received 12 bytes USER admin 331 Please specify the password. -- Packet port 10 released at 88683ms [Send] len=88, bss=0x00, port=10 [Recv] len=54, bss=0x00, port=1 ftpd_sent: 34 bytes of response sent ftpd_sent: processed 12 bytes [Recv] len=67, bss=0x00, port=2 ftpd_recv: received 13 bytes PASS 123456 230 Login successful. -- Packet port 11 released at 88309ms [Send] len=77, bss=0x00, port=11 [Recv] len=54, bss=0x00, port=3 ftpd_sent: 23 bytes of response sent ftpd_sent: processed 13 bytes [Recv] len=68, bss=0x00, port=4 ftpd_recv: received 14 bytes opts utf8 on 200 Always in UTF8 mode. -- Packet port 1 released at 78645ms [Send] len=80, bss=0x00, port=1 [Recv] len=54, bss=0x00, port=5 ftpd_sent: 26 bytes of response sent ftpd_sent: processed 14 bytes [Recv] len=59, bss=0x00, port=6 ftpd_recv: received 5 bytes PWD 257 "/" is the current directory. -- Packet port 2 released at 34059ms [Send] len=89, bss=0x00, port=2 [Recv] len=54, bss=0x00, port=7 ftpd_sent: 35 bytes of response sent ftpd_sent: processed 5 bytes [Recv] len=61, bss=0x00, port=8 ftpd_recv: received 7 bytes CWD / 250 Directory successfully changed. -- Packet port 3 released at 34080ms [Send] len=91, bss=0x00, port=3 [Recv] len=54, bss=0x00, port=9 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 7 bytes [Recv] len=62, bss=0x00, port=10 ftpd_recv: received 8 bytes TYPE A 200 Switching to ASCII mode. -- Packet port 4 released at 34100ms [Send] len=84, bss=0x00, port=4 Packet port 5 released at 3434ms Packet port 6 released at 3419ms Packet port 7 released at 189ms Packet port 8 released at 186ms [Recv] len=54, bss=0x00, port=11 ftpd_sent: 30 bytes of response sent ftpd_sent: processed 8 bytes [Recv] len=60, bss=0x00, port=12 ftpd_recv: received 6 bytes PASV 227 Entering Passive Mode (192,168,1,5,225,210). [Send] len=104, bss=0x00, port=5 [Recv] len=54, bss=0x00, port=13 ftpd_sent: 50 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=66, bss=0x00, port=14 [Send] len=62, bss=0x00, port=6 [Recv] len=54, bss=0x00, port=15 FTPD data connection to [192.168.1.4]:55880 is established! [Recv] len=60, bss=0x00, port=1 ftpd_recv: received 6 bytes LIST 150 Here comes the directory listing. [Send] len=93, bss=0x00, port=7 [Recv] len=54, bss=0x00, port=2 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 6 bytes 07-03-2020 11:30PM 3007503 ????.mp3 07-03-2020 11:27PM 07-03-2020 11:29PM 07-03-2020 11:31PM 1575040 ????.mp3 07-03-2020 11:31PM 1927296 ????.mp3 07-03-2020 11:32PM 3007503 j20.mp3 FTPD data connection [192.168.1.4]:55880 is shutdown by the server! [Send] len=377, bss=0x00, port=8 226 Directory send OK. -- Packet port 9 released at 307ms [Send] len=78, bss=0x00, port=9 [Recv] len=54, bss=0x00, port=3 [Recv] len=54, bss=0x00, port=4 FTPD data connection [192.168.1.4]:55880 is closed by the client! -- Packet port 10 released at 301ms [Send] len=54, bss=0x00, port=10 [Recv] len=54, bss=0x00, port=5 ftpd_sent: 24 bytes of response sent Packet port 1 released at 261ms Packet port 2 released at 238ms Packet port 3 released at 214ms Packet port 4 released at 190ms Packet port 5 released at 155ms Packet port 6 released at 141ms Packet port 7 released at 121ms Packet port 11 released at 311ms [Recv] len=92, bss=0x00, port=6 [Recv] len=342, bss=0x00, port=7 [Recv] len=255, bss=0x00, port=8 [Recv] len=251, bss=0x00, port=9 [Recv] len=86, bss=0x00, port=10 [Send] len=86, bss=0x00, port=11 [Recv] len=86, bss=0x00, port=11 [Send] len=82, bss=0x00, port=1 [Recv] len=74, bss=0x00, port=12 FTPD accepted [2409:8A62:362:1050:883B:55B0:939C:EE8]:55887! 220 LwIP FTP Service [Send] len=96, bss=0x00, port=2 [Recv] len=74, bss=0x00, port=13 ftpd_sent: 22 bytes of response sent [Recv] len=90, bss=0x00, port=14 ftpd_recv: received 16 bytes USER anonymous 331 Anonymous access allowed, send identity (e-mail name) as password. [Send] len=146, bss=0x00, port=3 [Recv] len=74, bss=0x00, port=15 ftpd_sent: 72 bytes of response sent ftpd_sent: processed 16 bytes [Recv] len=88, bss=0x00, port=1 ftpd_recv: received 14 bytes PASS IEUser@ 230 Login successful. [Send] len=97, bss=0x00, port=4 [Recv] len=74, bss=0x00, port=2 ftpd_sent: 23 bytes of response sent ftpd_sent: processed 14 bytes [Recv] len=88, bss=0x00, port=3 ftpd_recv: received 14 bytes opts utf8 on 200 Always in UTF8 mode. [Send] len=100, bss=0x00, port=5 [Recv] len=74, bss=0x00, port=4 ftpd_sent: 26 bytes of response sent ftpd_sent: processed 14 bytes [Recv] len=80, bss=0x00, port=5 ftpd_recv: received 6 bytes syst 500 Unknown command. [Send] len=96, bss=0x00, port=6 [Recv] len=74, bss=0x00, port=6 ftpd_sent: 22 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=85, bss=0x00, port=7 ftpd_recv: received 11 bytes site help 500 Unknown command. [Send] len=96, bss=0x00, port=7 [Recv] len=74, bss=0x00, port=8 ftpd_sent: 22 bytes of response sent ftpd_sent: processed 11 bytes [Recv] len=79, bss=0x00, port=9 ftpd_recv: received 5 bytes PWD 257 "/" is the current directory. -- Packet port 8 released at 58254ms [Send] len=109, bss=0x00, port=8 [Recv] len=74, bss=0x00, port=10 ftpd_sent: 35 bytes of response sent ftpd_sent: processed 5 bytes Packet port 1 released at 173ms Packet port 2 released at 161ms Packet port 3 released at 139ms Packet port 4 released at 119ms Packet port 5 released at 99ms Packet port 6 released at 79ms Packet port 9 released at 58281ms Packet port 10 released at 58264ms Packet port 11 released at 206ms [Recv] len=80, bss=0x00, port=11 ftpd_recv: received 6 bytes noop 200 NOOP ok. [Send] len=88, bss=0x00, port=9 [Recv] len=74, bss=0x00, port=12 ftpd_sent: 14 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=81, bss=0x00, port=13 ftpd_recv: received 7 bytes CWD / 250 Directory successfully changed. [Send] len=111, bss=0x00, port=10 [Recv] len=74, bss=0x00, port=14 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 7 bytes [Recv] len=82, bss=0x00, port=15 ftpd_recv: received 8 bytes TYPE A 200 Switching to ASCII mode. [Send] len=104, bss=0x00, port=11 [Recv] len=74, bss=0x00, port=1 ftpd_sent: 30 bytes of response sent ftpd_sent: processed 8 bytes [Recv] len=80, bss=0x00, port=2 ftpd_recv: received 6 bytes EPSV 229 Entering Extended Passive Mode (|||57811|). [Send] len=123, bss=0x00, port=1 [Recv] len=80, bss=0x00, port=3 [Send] len=74, bss=0x00, port=2 [Send] len=123, bss=0x00, port=3 [Recv] len=74, bss=0x00, port=4 ftpd_sent: 49 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=86, bss=0x00, port=5 [Send] len=82, bss=0x00, port=4 [Recv] len=74, bss=0x00, port=6 FTPD data connection to [2409:8A62:362:1050:883B:55B0:939C:EE8]:55888 is established! [Recv] len=80, bss=0x00, port=7 ftpd_recv: received 6 bytes LIST 150 Here comes the directory listing. [Send] len=113, bss=0x00, port=5 [Recv] len=74, bss=0x00, port=8 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 6 bytes 07-03-2020 11:35PM 179 446clk.txt 07-03-2020 11:35PM 15870 446ze_board.ioc 07-03-2020 11:36PM 593640 DDB1??MCU????.docx FTPD data connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55888 is shutdown by the server! [Send] len=258, bss=0x00, port=6 226 Directory send OK. -- Packet port 7 released at 1622ms [Send] len=98, bss=0x00, port=7 [Recv] len=74, bss=0x00, port=9 [Recv] len=74, bss=0x00, port=10 FTPD data connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55888 is closed by the client! -- Packet port 8 released at 1618ms [Send] len=74, bss=0x00, port=8 [Recv] len=74, bss=0x00, port=11 ftpd_sent: 24 bytes of response sent Packet port 1 released at 1440ms Packet port 2 released at 1165ms Packet port 3 released at 185ms Packet port 4 released at 173ms Packet port 5 released at 107ms Packet port 9 released at 1532ms Packet port 10 released at 1511ms Packet port 11 released at 1488ms [Recv] len=92, bss=0x00, port=12 [Recv] len=92, bss=0x00, port=13 [Recv] len=92, bss=0x00, port=14 [Recv] len=86, bss=0x00, port=15 [Send] len=82, bss=0x00, port=9 [Recv] len=74, bss=0x00, port=1 FTPD accepted [2409:8A62:362:1050:883B:55B0:939C:EE8]:55889! 220 LwIP FTP Service [Send] len=96, bss=0x00, port=10 [Recv] len=74, bss=0x00, port=2 ftpd_sent: 22 bytes of response sent [Recv] len=86, bss=0x00, port=3 ftpd_recv: received 12 bytes USER admin 331 Please specify the password. [Send] len=108, bss=0x00, port=11 [Recv] len=74, bss=0x00, port=4 ftpd_sent: 34 bytes of response sent ftpd_sent: processed 12 bytes [Recv] len=87, bss=0x00, port=5 ftpd_recv: received 13 bytes PASS 123456 230 Login successful. [Send] len=97, bss=0x00, port=1 [Recv] len=74, bss=0x00, port=6 ftpd_sent: 23 bytes of response sent ftpd_sent: processed 13 bytes [Recv] len=88, bss=0x00, port=7 ftpd_recv: received 14 bytes opts utf8 on 200 Always in UTF8 mode. [Send] len=100, bss=0x00, port=2 [Recv] len=74, bss=0x00, port=8 ftpd_sent: 26 bytes of response sent ftpd_sent: processed 14 bytes [Recv] len=80, bss=0x00, port=9 ftpd_recv: received 6 bytes syst 500 Unknown command. [Send] len=96, bss=0x00, port=3 [Recv] len=74, bss=0x00, port=10 ftpd_sent: 22 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=85, bss=0x00, port=11 ftpd_recv: received 11 bytes site help 500 Unknown command. [Send] len=96, bss=0x00, port=4 [Recv] len=74, bss=0x00, port=12 ftpd_sent: 22 bytes of response sent ftpd_sent: processed 11 bytes [Recv] len=79, bss=0x00, port=13 ftpd_recv: received 5 bytes PWD 257 "/" is the current directory. [Send] len=109, bss=0x00, port=5 [Recv] len=74, bss=0x00, port=14 ftpd_sent: 35 bytes of response sent ftpd_sent: processed 5 bytes [Recv] len=82, bss=0x00, port=15 ftpd_recv: received 8 bytes TYPE A 200 Switching to ASCII mode. -- Packet port 6 released at 12869ms [Send] len=104, bss=0x00, port=6 [Recv] len=74, bss=0x00, port=1 ftpd_sent: 30 bytes of response sent ftpd_sent: processed 8 bytes [Recv] len=80, bss=0x00, port=2 ftpd_recv: received 6 bytes EPSV 229 Entering Extended Passive Mode (|||57812|). -- Packet port 7 released at 12889ms [Send] len=123, bss=0x00, port=7 Packet port 1 released at 179ms Packet port 2 released at 131ms Packet port 3 released at 112ms Packet port 4 released at 92ms Packet port 8 released at 12885ms Packet port 9 released at 254ms Packet port 10 released at 242ms Packet port 11 released at 224ms [Recv] len=74, bss=0x00, port=3 ftpd_sent: 49 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=86, bss=0x00, port=4 [Send] len=82, bss=0x00, port=8 [Recv] len=74, bss=0x00, port=5 FTPD data connection to [2409:8A62:362:1050:883B:55B0:939C:EE8]:55890 is established! [Recv] len=80, bss=0x00, port=6 ftpd_recv: received 6 bytes LIST 150 Here comes the directory listing. [Send] len=113, bss=0x00, port=9 [Recv] len=74, bss=0x00, port=7 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 6 bytes 07-03-2020 11:30PM 3007503 ????.mp3 07-03-2020 11:27PM 07-03-2020 11:29PM 07-03-2020 11:31PM 1575040 ????.mp3 07-03-2020 11:31PM 1927296 ????.mp3 07-03-2020 11:32PM 3007503 j20.mp3 FTPD data connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55890 is shutdown by the server! [Send] len=397, bss=0x00, port=10 226 Directory send OK. [Send] len=98, bss=0x00, port=11 [Recv] len=74, bss=0x00, port=8 [Recv] len=74, bss=0x00, port=9 FTPD data connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55890 is closed by the client! [Send] len=74, bss=0x00, port=1 [Recv] len=74, bss=0x00, port=10 ftpd_sent: 24 bytes of response sent [Recv] len=80, bss=0x00, port=11 ftpd_recv: received 6 bytes noop 200 NOOP ok. [Send] len=88, bss=0x00, port=2 [Recv] len=74, bss=0x00, port=12 ftpd_sent: 14 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=88, bss=0x00, port=13 ftpd_recv: received 14 bytes CWD /public/ 250 Directory successfully changed. [Send] len=111, bss=0x00, port=3 [Recv] len=74, bss=0x00, port=14 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 14 bytes [Recv] len=82, bss=0x00, port=15 ftpd_recv: received 8 bytes TYPE A 200 Switching to ASCII mode. [Send] len=104, bss=0x00, port=4 [Recv] len=74, bss=0x00, port=1 ftpd_sent: 30 bytes of response sent ftpd_sent: processed 8 bytes [Recv] len=80, bss=0x00, port=2 ftpd_recv: received 6 bytes EPSV 229 Entering Extended Passive Mode (|||57813|). -- Packet port 5 released at 8973ms [Send] len=123, bss=0x00, port=5 [Recv] len=74, bss=0x00, port=3 ftpd_sent: 49 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=86, bss=0x00, port=4 -- Packet port 6 released at 8967ms [Send] len=82, bss=0x00, port=6 [Recv] len=74, bss=0x00, port=5 FTPD data connection to [2409:8A62:362:1050:883B:55B0:939C:EE8]:55891 is established! [Recv] len=80, bss=0x00, port=6 ftpd_recv: received 6 bytes LIST 150 Here comes the directory listing. -- Packet port 7 released at 8968ms [Send] len=113, bss=0x00, port=7 [Recv] len=74, bss=0x00, port=7 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 6 bytes 07-03-2020 11:35PM 179 446clk.txt 07-03-2020 11:35PM 15870 446ze_board.ioc 07-03-2020 11:36PM 593640 DDB1??MCU????.docx FTPD data connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55891 is shutdown by the server! -- Packet port 8 released at 8980ms [Send] len=258, bss=0x00, port=8 226 Directory send OK. -- Packet port 9 released at 8964ms [Send] len=98, bss=0x00, port=9 [Recv] len=74, bss=0x00, port=8 [Recv] len=74, bss=0x00, port=9 FTPD data connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55891 is closed by the client! -- Packet port 10 released at 8921ms [Send] len=74, bss=0x00, port=10 [Recv] len=74, bss=0x00, port=10 ftpd_sent: 24 bytes of response sent Packet port 1 released at 8910ms Packet port 2 released at 227ms Packet port 3 released at 205ms Packet port 11 released at 8938ms [Recv] len=80, bss=0x00, port=11 ftpd_recv: received 6 bytes noop 200 NOOP ok. [Send] len=88, bss=0x00, port=11 [Recv] len=74, bss=0x00, port=12 ftpd_sent: 14 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=86, bss=0x00, port=13 ftpd_recv: received 12 bytes CWD /test/ 250 Directory successfully changed. [Send] len=111, bss=0x00, port=1 [Recv] len=74, bss=0x00, port=14 ftpd_sent: 37 bytes of response sent ftpd_sent: processed 12 bytes [Recv] len=82, bss=0x00, port=15 ftpd_recv: received 8 bytes TYPE A 200 Switching to ASCII mode. [Send] len=104, bss=0x00, port=2 [Recv] len=74, bss=0x00, port=1 ftpd_sent: 30 bytes of response sent ftpd_sent: processed 8 bytes [Recv] len=80, bss=0x00, port=2 ftpd_recv: received 6 bytes EPSV 229 Entering Extended Passive Mode (|||57814|). [Send] len=123, bss=0x00, port=3 [Recv] len=74, bss=0x00, port=3 ftpd_sent: 49 bytes of response sent ftpd_sent: processed 6 bytes [Recv] len=86, bss=0x00, port=4 -- Packet port 4 released at 3058ms [Send] len=82, bss=0x00, port=4 [Recv] len=74, bss=0x00, port=5 FTPD data connection to [2409:8A62:362:1050:883B:55B0:939C:EE8]:55892 is established! [Recv] len=80, bss=0x00, port=6 ftpd_recv: received 6 bytes LIST 150 Here comes the directory listing. -- Packet port 5 released at 3059ms [Send] len=113, bss=0x00, port=5 [Recv] len=74, bss=0x00, port=7 ftpd_sent: 39 bytes of response sent ftpd_sent: processed 6 bytes 07-03-2020 11:35PM 1141 cmdlist.txt 07-03-2020 11:35PM 10811 adt2001_pins_446ze.xlsx FTPD data connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55892 is shutdown by the server! -- Packet port 6 released at 3087ms [Send] len=194, bss=0x00, port=6 226 Directory send OK. -- Packet port 7 released at 3068ms [Send] len=98, bss=0x00, port=7 [Recv] len=74, bss=0x00, port=8 [Recv] len=74, bss=0x00, port=9 FTPD data connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55892 is closed by the client! -- Packet port 8 released at 3035ms [Send] len=74, bss=0x00, port=8 [Recv] len=74, bss=0x00, port=10 ftpd_sent: 24 bytes of response sent Packet port 1 released at 188ms Packet port 2 released at 169ms Packet port 9 released at 3046ms Packet port 10 released at 3027ms Packet port 11 released at 236ms [Recv] len=42, bss=0x00, port=11 [Send] len=42, bss=0x00, port=9 [Recv] len=74, bss=0x00, port=12 FTPD connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55887 is shutdown by the client! FTPD connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55887 is closed by the server! [Send] len=74, bss=0x00, port=10 [Recv] len=74, bss=0x00, port=13 FTPD connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55889 is shutdown by the client! FTPD connection [2409:8A62:362:1050:883B:55B0:939C:EE8]:55889 is closed by the server! [Send] len=74, bss=0x00, port=11 [Recv] len=54, bss=0x00, port=14 FTPD connection [192.168.1.4]:55879 is shutdown by the client! FTPD connection [192.168.1.4]:55879 is closed by the server! [Send] len=54, bss=0x00, port=1 [Recv] len=74, bss=0x00, port=15 [Recv] len=74, bss=0x00, port=1 [Recv] len=54, bss=0x00, port=2 [Recv] len=92, bss=0x00, port=3 [Recv] len=92, bss=0x00, port=4 [Recv] len=92, bss=0x00, port=5 [Recv] len=86, bss=0x00, port=6 [Send] len=86, bss=0x00, port=2 Packet port 1 released at 4829ms Packet port 3 released at 31630ms Packet port 4 released at 31613ms Packet port 5 released at 31586ms Packet port 6 released at 31542ms Packet port 7 released at 31536ms Packet port 8 released at 31517ms Packet port 9 released at 4920ms Packet port 10 released at 4899ms Packet port 11 released at 4879ms |
只有小组成员才能发言,加入小组>>
2071 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4792 浏览 0 评论
4273 浏览 9 评论
3863 浏览 16 评论
4433 浏览 1 评论
4261浏览 3评论
3435浏览 0评论
1203浏览 0评论
2888浏览 0评论
3952浏览 0评论
/9
GMT+8, 2025-12-14 17:00 , Processed in 0.943786 second(s), Total 75, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1157
