我想移植一个芯片的驱动。需要设置一个管脚(PD22)为外部中断,但是在下载的资料包里面没有芯片相关的寄存器资料,所以不知道对应的中断号是什么,如何配置。开发板为T507
你好,我想使用SPI1设备,在设备树上面将修改了,status也改为okay了,但是在运行的系统中找到不对应的SPI1设备。我新增的其他设备可以在/proc/devices-tree中找到,spi相关的设备都找不到,请问要怎么解决? 我在board.dts中的修改如下: spi1: spi@05011000 { pinctrl-0 = <&spi1_pins_a &spi1_pins_b>; pinctrl-1 = <&spi1_pins_c>; spi_slave_mode = <1>; status = "okay"; spi_board1 { device_type = "spi_board1"; compatible = "rohm,dh2228fv"; spi-max-frequency = <0x5f5e100>; reg = <0x0>; spi-rx-bus-width = <0x1>; spi-tx-bus-width = <0x1>; status = "okay"; }; spi_test{ compatible = "wkmic,wk2124spi_cs0"; reg = <0x0>; spi-max-frequency = <10000000>; irq_gpio = <&pio PD 22 6 0xffffffff 0xffffffff 0>; status = "okay"; }; }; 在/sys/bus/spi/drivers里面能找到新增的驱动,但是没有在/dev出现SPI相关的设备是什么导致的?还是配置有别的问题? |
4个回答
您可以参考这个(kernel/linux-4.9/arch/arm64/boot/dts/sunxi/OKT507-C-Common.dtsi),您参考这个例子写中断
twi4: twi@0x05003000{ clock-frequency = <200000>; status = "okay"; gt911: gt911_ts@5d { compatible = "goodix,gt911"; reg = <0x5D>; goodix,irq-gpio = <&pio PE 13 6 0xffffffff 0xffffffff 0>; goodix,rst-gpio = <&pio PE 14 1 0xffffffff 0xffffffff 1>; goodix,panel-width = <1024>; status = "okay"; }; gt928: gt928_ts@14 { compatible = "goodix,gt928"; reg = <0x14>; goodix,irq-gpio = <&pio PE 13 6 0xffffffff 0xffffffff 0>; goodix,rst-gpio = <&pio PE 14 1 0xffffffff 0xffffffff 1>; status = "disabled"; }; tsc2007: tsc2007@48 { compatible = "ti,tsc2007"; reg = <0x48>; interrupt-parent = <&pio>; interrupts = gpios = <&pio PE 12 6 0xffffffff 0xffffffff 0>; ti,x-plate-ohms = <180>; status = "disabled"; }; }; |
kernel/linux-4.9/arch/arm64/boot/dts/sunxi/OKT507-C-Common.dtsi里边参考spi0添加spi1,状态是okay
名称复制kernel/linux-4.9/arch/arm64/boot/dts/sunxi/sun50iw9p1.dtsi里的内容 |
您在spi里应该注册类似spidev1_cs0的设备吧,您写的设备调的是什么驱动啊
这个是A40i上的例子,参考一下吧 spidev1_cs0:spi1_cs0@0{ #address-cells=<1>; #size-cells=<1>; compatible = "spidev"; spi-max-frequency = <33000000>; reg = <0>; mode=<0>; }; |
我这里是移植一个SPI扩展串口的芯片。匹配了compatible字符串也还是没有出现对应的TTY设备。而且我内核中开启了spidev,/dev中也没有spidev设备。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
431 浏览 0 评论
524 浏览 1 评论
1789 浏览 1 评论
3043 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
3771 浏览 1 评论
GMT+8, 2024-12-19 17:46 , Processed in 0.592855 second(s), Total 48, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
