电子发烧友论坛|
闲来无聊,恰好公司又经常用CAN数据的传输,自己觉得要是用无线传送多好,然后,就是一个奇想,就想做一个无线数据的透传,恰好身边又有NRF24L01,那就行动吧! 下面是NRF24L01 SPI1 的初始化程序: void NRF24L01_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA, ENABLE); //使能PB,G端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //PB12上拉 防止W25X的干扰 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化指定IO GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //PG8 7 推挽 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化指定IO GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PG6 输入 GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_ResetBits(GPIOA,GPIO_Pin_4);//PA4上拉 GPIO_ResetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5);//PC4,5上拉 SPI1_Init(); //初始化SPI SPI_Cmd(SPI1, DISABLE); // SPI外设不使能 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //SPI主机 SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //时钟悬空低 SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //数据捕获于第1个时钟沿 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由软件控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16; //定义波特率预分频的值:波特率预分频值为16 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 SPI_Cmd(SPI1, ENABLE); //使能SPI外设 NRF24L01_CE=0; //使能24L01 NRF24L01_CSN=1; //SPI片选取消 } 这里是NRF24L01数据读取 /检测24L01是否存在 //返回值:0,成功;1,失败 u8 NRF24L01_Check(void) { u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5}; u8 i; SPI1_SetSpeed(SPI_BaudRatePrescaler_4); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址. NRF24L01_Read_Buf(TX_ADDR,buf,5); //读出写入的地址 for(i=0;i<5;i++)if(buf!=0XA5)break; if(i!=5)return 1;//检测24L01错误 return 0; //检测到24L01 } //SPI写寄存器 //reg:指定寄存器地址 //value:写入的值 u8 NRF24L01_Write_Reg(u8 reg,u8 value) { u8 status; NRF24L01_CSN=0; //使能SPI传输 status =SPI1_ReadWriteByte(reg);//发送寄存器号 SPI1_ReadWriteByte(value); //写入寄存器的值 NRF24L01_CSN=1; //禁止SPI传输 return(status); //返回状态值 } //读取SPI寄存器值 //reg:要读的寄存器 u8 NRF24L01_Read_Reg(u8 reg) { u8 reg_val; NRF24L01_CSN = 0; //使能SPI传输 SPI1_ReadWriteByte(reg); //发送寄存器号 reg_val=SPI1_ReadWriteByte(0XFF);//读取寄存器内容 NRF24L01_CSN = 1; //禁止SPI传输 return(reg_val); //返回状态值 } //在指定位置读出指定长度的数据 //reg:寄存器(位置) //*pBuf:数据指针 //len:数据长度 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len) { u8 status,u8_ctr; NRF24L01_CSN = 0; //使能SPI传输 status=SPI1_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 for(u8_ctr=0;u8_ctr return status; //返回读到的状态值 } //在指定位置写指定长度的数据 //reg:寄存器(位置) //*pBuf:数据指针 //len:数据长度 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len) { u8 status,u8_ctr; NRF24L01_CSN = 0; //使能SPI传输 status = SPI1_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 for(u8_ctr=0; u8_ctr return status; //返回读到的状态值 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:发送完成状况 u8 NRF24L01_TxPacket(u8 *txbuf) { u8 sta; SPI1_SetSpeed(SPI_BaudRatePrescaler_8);//spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) NRF24L01_CE=0; NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF 32个字节 NRF24L01_CE=1;//启动发送 while(NRF24L01_IRQ!=0);//等待发送完成 sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志 if(sta&MAX_TX)//达到最大重发次数 { NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器 return MAX_TX; } if(sta&TX_OK)//发送完成 { return TX_OK; } return 0xff;//其他原因发送失败 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:0,接收完成;其他,错误代码 u8 NRF24L01_RxPacket(u8 *rxbuf) { u8 sta; SPI1_SetSpeed(SPI_BaudRatePrescaler_8); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志 if(sta&RX_OK)//接收到数据 { NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//读取数据 NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器 return 0; } return 1;//没收到任何数据 } //该函数初始化NRF24L01到RX模式 //设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR //当CE变高后,即进入RX模式,并可以接收数据了 void NRF24L01_RX_Mode(void) { NRF24L01_CE=0; NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通信频率 NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//选择通道0的有效数据宽度 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);//设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f);//配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式 NRF24L01_CE = 1; //CE为高,进入接收模式 } //该函数初始化NRF24L01到TX模式 //设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据,选择RF频道,波特率和LNA HCURR //PWR_UP,CRC使能 //当CE变高后,即进入RX模式,并可以接收数据了 //CE为高大于10us,则启动发送. void NRF24L01_TX_Mode(void) { NRF24L01_CE=0; NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//写TX节点地址 NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址 NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通道为40 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断 NRF24L01_CE=1;//CE为高, 这里是关于stm32can程序: /******************** 鑫盛电子工作室 ******************** * 文件名 :can.c * 描述 :CAN测试应用函数库。 * 实验平台:MINI STM32开发板 基于STM32F103C8T6 * 硬件连接:----------------- * | | | PB8-CAN-RX | * | PB9-CAN-TX | * | | * ----------------- * 库版本 :ST3.0.0 * 淘宝店:http://shop66177872.taobao.com *********************************************************/ #include "can.h" //#include "led.h" #include "stdio.h" #include "sys.h" #include "stm32f10x_can.h" #include "24l01.h" //#include "os.h" typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus; /* 在中断处理函数中返回 */ __IO uint32_t ret = 0; uint8_t CAN_RX_BUFF[17]; volatile TestStatus TestRx; static void CAN1_NVIC_Config(void) { NVIC_InitTypeDef NVIC_InitStructure; /* 使能接收的中断和中断优先级 */ NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE); //FIFO0消息挂号中断允许. } /**************************************************************************** * Function Name : CAN1_Config * Description : 初始化CAN,波特率设置为450K * Input : mode:用来选择要使用的工作模式:主要有四种工作模式:1、正常 * * 模式:CAN_Mode_Normal;2、CAN_Mode_Silent :静默模式;3、环 * * 回模式:CAN_Mode_LoopBack;4、静默环回模式:CAN_Mode_Silent * * _LoopBack。 * Output : None * Return : None ****************************************************************************/ void CAN1_Config(uint8_t mode) { GPIO_InitTypeDef GPIO_InitStructure; CAN_InitTypeDef CAN_InitStructure; /* 初始化IO口 */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //PA12 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //PA11 GPIO_Init(GPIOA, &GPIO_InitStructure); /***************************************************************************/ /********************* CAN设置和初始化 *************************************/ /***************************************************************************/ /* 打开时钟使能 */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE); /* 初始化CAN的参数 */ CAN_DeInit(CAN1); CAN_StructInit(&CAN_InitStructure); /* CAN 参数初始化 */ CAN_InitStructure.CAN_TTCM = DISABLE; //失能时间触发模式 CAN_InitStructure.CAN_ABOM = ENABLE; //自动离线管理 CAN_InitStructure.CAN_AWUM = DISABLE; //失能睡眠模式通过软件唤醒 CAN_InitStructure.CAN_NART = DISABLE; //失能非自动重传输模式(也就是会自动重传输) CAN_InitStructure.CAN_RFLM = DISABLE; //失能接收FIFO锁定模式,新数据会覆盖旧数据 CAN_InitStructure.CAN_TXFP = DISABLE; //优先级由报文标识符决定 CAN_InitStructure.CAN_Mode = mode; //有普通模式和拓展模式 CAN_InitStructure.CAN_SJW = CAN_SJW_1tq; //重新同步跳跃宽度 1 个时间单位 /* 波特率设置, 当APB1的时钟频率是36MHZ的时候。 波特率的公式为: */ /* 波特率(Kpbs) = 36M / ((CAN_BS1 + CAN_BS2 + 1) * CAN_Prescaler) */ CAN_InitStructure.CAN_BS1 = CAN_BS1_9tq; //时间段 1 为8 个时间单位 CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq; //时间段 2 为7 个时间单位 CAN_InitStructure.CAN_Prescaler = 4;//5; 波特率改为了100K 20=100k 5=400k CAN_Init(CAN1, &CAN_InitStructure); #ifdef CAN_RX0_INT_ENABLE CAN1_NVIC_Config(); #endif } /**************************************************************************** * Function Name : CAN1_SendMesg * Description : 发送一个报文 * Input : id:发送的ID。 * * len:发送的数据长度(注意发送数据长度不能超过8个字节) * * dat:存放数据的指针 * Output : None * Return : None ****************************************************************************/ void CAN1_SendMesg(uint32_t id, uint8_t len, uint8_t *dat) { uint16_t i = 0; CanTxMsg TxMessage; /* 一次发送只能发送8个字节 */ if(len > 8) { return ; } /* 配置邮箱:设置标识符,数据长度和待发送数据 */ TxMessage.StdId = (id & 0x7FF); //标准帧ID11位 TxMessage.ExtId = (id ); //设置扩展标示符(拓展标示符有29位1本来是TxMessage.ExtId = (id >> 11); TxMessage.RTR = CAN_RTR_DATA; //设置为数据帧(或远程帧为CAN_RTR_Remote) if((id & 0x7FF) == 0x7FF) //检测是标准帧还是拓展帧(拓展帧大于11位) { TxMessage.IDE = CAN_ID_STD; //拓展ID } else { TxMessage.IDE = CAN_ID_EXT; //标准ID } TxMessage.DLC = len; //发送的数据长度 /* 将数据放入到邮箱中 */ for(i=0; i TxMessage.Data = *dat; dat++; } /* 开始传送数据 */ CAN_Transmit(CAN1, &TxMessage); } /**************************************************************************** * Function Name : CAN1_Config16BitFilter * Description : 设置CAN接收16两个标准ID(设置ID位数全部相同才能够通过) * Input : id1:要接收的一个ID * * id2:要接收的一个ID * Output : None * Return : None ****************************************************************************/ void CAN1_Config16BitFilter(uint16_t id1, uint16_t id2) { CAN_FilterInitTypeDef CAN_FilterInitStructure; uint16_t mask = 0xFFFF; /* CAN filter init 屏蔽寄存器初始化 */ CAN_FilterInitStructure.CAN_FilterNumber = 1; //过滤器1 CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;//ID模式 /* 寄存器组设置为16位 */ CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_16bit; CAN_FilterInitStructure.CAN_FilterIdHigh = (id1 << 5); //要接收的ID标示符1 CAN_FilterInitStructure.CAN_FilterIdLow = (id2 << 5); //要接收的ID标示符2 /* 设置为所有ID位都要相同才接收 */ CAN_FilterInitStructure.CAN_FilterMaskIdHigh = (mask << 5); //MASK CAN_FilterInitStructure.CAN_FilterMaskIdLow = (mask << 5); CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_Filter_FIFO0; //FIFO0 CAN_FilterInitStructure.CAN_FilterActivation = ENABLE; //使能过滤器1 CAN_FilterInit(&CAN_FilterInitStructure); } /**************************************************************************** * Function Name : CAN1_Config32BitFilter * Description : 设置一个拓展ID的接收 * Input : id:要接收的ID * Output : None * Return : None ****************************************************************************/ void CAN1_Config32BitFilter(uint32_t id) { // uint32_t mask = 0x000006D1;//0xFFFFFFFF; //发送0x00000601 接收0x000006D1 CAN_FilterInitTypeDef CAN_FilterInitStructure; /* CAN filter init 屏蔽寄存器初始化 */ CAN_FilterInitStructure.CAN_FilterNumber = 1; //过滤器1 CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;//ID模式 /* 寄存器组设置为32位 */ CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit; CAN_FilterInitStructure.CAN_FilterIdHigh =0x0000;// (id >> 13); //要接收的ID标示符1 CAN_FilterInitStructure.CAN_FilterIdLow =0x0000;// (id << 3 ) | 4;//要接收的ID标示符2 /* 设置为所有ID位都要相同才接收 */ CAN_FilterInitStructure.CAN_FilterMaskIdHigh =0x0000;// mask >> 13; //MASK CAN_FilterInitStructure.CAN_FilterMaskIdLow =0x0000;// (mask << 3) | 4; CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_Filter_FIFO0; //FIFO0 CAN_FilterInitStructure.CAN_FilterActivation = ENABLE; //使能过滤器1 CAN_FilterInit(&CAN_FilterInitStructure); } /**************************************************************************** * Function Name : CAN1_ReceiveMesg * Description : 接收一个报文 * Input : receiveBuff:接收数据的数组指针 * Output : None * Return : None ****************************************************************************/ void CAN1_ReceiveMesg(uint8_t *receiveBuff) { uint8_t i = 0; CanRxMsg RxMessage; //设置接收邮箱 if((CAN_MessagePending(CAN1, CAN_FIFO0) != 0)) //检查FIFO0里面是否有数据 { CAN_Receive(CAN1,CAN_FIFO0,&RxMessage); //读取FIFO0里面的数据 for(i=0; i *receiveBuff = RxMessage.Data; receiveBuff++; } } } /* 发送两个字节的数据*/ void can_tx(u8 Data1,u8 Data2,u8 Data3,u8 Data4,u8 Data5,u8 Data6,u8 Data7,u8 Data8) { CanTxMsg TxMessage; TxMessage.StdId=0x0023; //标准标识符为0x00 TxMessage.ExtId=0x001C; //扩展标识符0x0000 TxMessage.IDE=CAN_ID_STD;//使用标准标识符 TxMessage.RTR=CAN_RTR_DATA;//为数据帧 TxMessage.DLC=8; // 消息的数据长度为8个字节 TxMessage.Data[0]=Data1; //第一个字节数据 TxMessage.Data[1]=Data2; //第二个字节数据 TxMessage.Data[2]=Data3; //第三个字节数据 TxMessage.Data[3]=Data4; //第一个字节数据 TxMessage.Data[4]=Data5; //第二个字节数据 TxMessage.Data[5]=Data6; //第三个字节数据 TxMessage.Data[6]=Data7; //第一个字节数据 TxMessage.Data[7]=Data8; //第二个字节数据 CAN_Transmit(CAN1,&TxMessage); //发送数据 } void can_tx1(u8 Data1,u8 Data2,u8 Data3,u8 Data4,u8 Data5,u8 Data6,u8 Data7,u8 Data8) { CanTxMsg TxMessage; TxMessage.StdId=0x22; //标准标识符为0x00 TxMessage.ExtId=0x18DADDF1; //扩展标识符0x0000 TxMessage.IDE=CAN_ID_STD;//使用标准标识符 TxMessage.RTR=CAN_RTR_DATA;//为数据帧 TxMessage.DLC=8; // 消息的数据长度为8个字节 TxMessage.Data[0]=Data1; //第一个字节数据 TxMessage.Data[1]=Data2; //第二个字节数据 TxMessage.Data[2]=Data3; //第三个字节数据 TxMessage.Data[3]=Data4; //第一个字节数据 TxMessage.Data[4]=Data5; //第二个字节数据 TxMessage.Data[5]=Data6; //第三个字节数据 TxMessage.Data[6]=Data7; //第一个字节数据 TxMessage.Data[7]=Data8; //第二个字节数据 CAN_Transmit(CAN1,&TxMessage); //发送数据 } /* USB中断和CAN接收中断服务程序,USB跟CAN公用I/O,这里只用到CAN的中断。 */ void USB_LP_CAN1_RX0_IRQHandler(void) { CanRxMsg RxMessage; RxMessage.StdId=0x00; RxMessage.ExtId=0x00; RxMessage.IDE=0; RxMessage.DLC=0; RxMessage.FMI=0; RxMessage.Data[0]=0x00; RxMessage.Data[1]=0x00; CAN_Receive(CAN1,CAN_FIFO0, &RxMessage); //接收FIFO0中的数据 CAN_RX_BUFF[0]=((RxMessage.StdId)&0x0000ff00)>>8; CAN_RX_BUFF[1]=(RxMessage.StdId)&0x000000ff; //标注0-7ff CAN_RX_BUFF[2]=((RxMessage.ExtId)&0xff000000)>>24; CAN_RX_BUFF[3]=((RxMessage.ExtId)&0x00ff0000)>>16; CAN_RX_BUFF[4]=((RxMessage.ExtId)&0x0000ff00)>>8; CAN_RX_BUFF[5]=((RxMessage.ExtId)&0x000000ff); CAN_RX_BUFF[6]=RxMessage.IDE; CAN_RX_BUFF[7]=RxMessage.DLC; CAN_RX_BUFF[8]=RxMessage.RTR; CAN_RX_BUFF[9]=RxMessage.Data[0]; CAN_RX_BUFF[10]=RxMessage.Data[1]; CAN_RX_BUFF[11]=RxMessage.Data[2]; CAN_RX_BUFF[12]=RxMessage.Data[3]; CAN_RX_BUFF[13]=RxMessage.Data[4]; CAN_RX_BUFF[14]=RxMessage.Data[5]; CAN_RX_BUFF[15]=RxMessage.Data[6]; CAN_RX_BUFF[16]=RxMessage.Data[7]; NRF24L01_TxPacket((u8*)(CAN_RX_BUFF)); } 最后得到的实验现象: can数据的接收,出现大量数据接收时,数据发送方大概每0.005s一个数据发送,而接收数据未0.05s一个数据,但由于数据量比较大时,数据的丢包比较明显,所以该无线程序可以使用在数据量比较小时的数据透传; |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4138 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2752 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14980 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3086浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1896浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2066浏览 3评论
1979浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2168浏览 3评论
/9
GMT+8, 2025-12-2 07:05 , Processed in 0.484188 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1249
