电子发烧友论坛扫一扫,分享给好友
论坛发帖太分散了,在此记录一下我开发STM32F750 uClinux开发板的进程,这是第一篇,发表于2018年12月。
前段时间ST推出了Value Line的STM32F750和H750两个系列,看了一下选型表,F750有LQFP144封装,正好适合我的STM32 linux板子。 于是,双十一买了几片。同时,我对我的linux板做了小幅改版:将SPI Flash容量扩大到32MB并连接到F750的QSPI BANK1,添加了CAN收发器和接口,增加了两个I2C外设(温湿度传感器和气压传感器)。板子做回来后先焊了一片,调试过程还算比较顺利,现在u-boot和Linux都工作起来了,下面是系统启动log,F750速度还是相当快的(427.62 BogoMIPS,F429跑Linux只有35.84 BogoMIPS),QSPI的加载速度也很给力。下一步我准备多测试几种STM32外设的Linux driver,emcraft现在的SDK比两三年前多了不少外设驱动,可以都试试看。 U-Boot 2010.03 (Nov 26 2018 - 21:30:21) CPU : STM32F7 (Cortex-M7) Freqs: SYSCLK=216MHz,HCLK=216MHz,PCLK1=54MHz,PCLK2=108MHz Board: STM32F750 Rev 1.0, www.emcraft.com DRAM: 64 MB In: serial Out: serial Err: serial QSPI: 32 MB mapped at 0x90000000 Net: miiphy_register done. eth hw init done. STM32_MAC Hit any key to stop autoboot: 0 Booting from QSPI ## Booting kernel from Legacy Image at c0007fc0 ... Image Name: Linux-4.2.0 Image Type: ARM Linux Multi-File Image (uncompressed) Data Size: 7496295 Bytes = 7.1 MB Load Address: c0008000 Entry Point: c0008001 Contents: Image 0: 7471388 Bytes = 7.1 MB Image 1: 24895 Bytes = 24.3 kB Verifying Checksum ... OK ## Flattened Device Tree from multi component Image at C0007FC0 Booting using the fdt at 0xc0728128 Loading Multi-File Image ... OK OK WARNING: legacy format multi component image overwritten Loading Device Tree to c3ff6000, end c3fff13e ... OK Starting kernel ... Booting Linux on physical CPU 0x0 Linux version 4.2.0 (hw@localhost.localdomain) (gcc version 4.4.1 (Sourcery G++ Lite 2010 q1-189) ) #90 Tue Dec 4 03:32:33 EST 2018 CPU: ARMv7-M [410fc271] revision 1 (ARMv7M), cr=00000000 CPU: WBA data cache, WBA instruction cache Machine model: EmCraft Systems STM32F7-SOM board Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: stm32_platform=stm32f7-disco console=ttyS0,115200 panic=10 ip=169.25 4.1.10:169.254.1.2:::stm32f7-disco:eth0:off PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 56432K/65536K available (2523K kernel code, 181K rwdata, 588K rodata, 4000K init, 111K bss, 9104K reserved, 0K cma-reserved) Virtual kernel memory layout: vector : 0x00000000 - 0x00001000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0x00000000 - 0xffffffff (4095 MB) lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) .text : 0xc0008000 - 0xc0312000 (3112 kB) .init : 0xc0312000 - 0xc06fa000 (4000 kB) .data : 0xc06fa000 - 0xc07277c0 ( 182 kB) .bss : 0xc072811c - 0xc0743e84 ( 112 kB) NR_IRQS:16 nr_irqs:16 16 /interrupt-controller@40013c00: 24 External IRQs detected clocksource: arm_system_timer: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 27651335 8 ns ARM System timer initialized as clocksource /soc/timer@40000000: STM32 clockevent driver initialized (32 bits) sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 21474836475000000ns Calibrating delay loop... 427.62 BogoMIPS (lpj=2138112) pid_max: default: 4096 minimum: 301 Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) devtmpfs: initialized clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 0000 ns pinctrl core: initialized pinctrl subsystem NET: Registered protocol family 16 stm32-pinctrl pin-controller: nbanks = 11 stm32-pinctrl pin-controller: nfunctions = 20 stm32-pinctrl pin-controller: ngroups = 23 stm32-pinctrl pin-controller: GPIOA bank added. stm32-pinctrl pin-controller: GPIOB bank added. stm32-pinctrl pin-controller: GPIOC bank added. stm32-pinctrl pin-controller: GPIOD bank added. stm32-pinctrl pin-controller: GPIOE bank added. stm32-pinctrl pin-controller: GPIOF bank added. stm32-pinctrl pin-controller: GPIOG bank added. stm32-pinctrl pin-controller: GPIOH bank added. stm32-pinctrl pin-controller: GPIOI bank added. stm32-pinctrl pin-controller: GPIOJ bank added. stm32-pinctrl pin-controller: GPIOK bank added. stm32-pinctrl pin-controller: Function[0 name:i2c_1, groups:1] stm32-pinctrl pin-controller: Function[1 name:i2c_2, groups:1] stm32-pinctrl pin-controller: Function[2 name:i2c_3, groups:1] stm32-pinctrl pin-controller: Function[3 name:mac, groups:2] stm32-pinctrl pin-controller: Function[4 name:sdio, groups:1] stm32-pinctrl pin-controller: Function[5 name:spi_2, groups:1] stm32-pinctrl pin-controller: Function[6 name:spi_4, groups:1] stm32-pinctrl pin-controller: Function[7 name:spi_5, groups:1] stm32-pinctrl pin-controller: Function[8 name:usart1, groups:1] stm32-pinctrl pin-controller: Function[9 name:usart6, groups:1] stm32-pinctrl pin-controller: Function[10 name:usart7, groups:1] stm32-pinctrl pin-controller: Function[11 name:u***_fs, groups:1] stm32-pinctrl pin-controller: Function[12 name:u***_hs, groups:1] stm32-pinctrl pin-controller: Function[13 name:can_1, groups:1] stm32-pinctrl pin-controller: Function[14 name:adc1_in0_pin, groups:1] stm32-pinctrl pin-controller: Function[15 name:dac_out2_pin, groups:1] stm32-pinctrl pin-controller: Function[16 name:ltdc, groups:1] stm32-pinctrl pin-controller: Function[17 name:sai_2, groups:1] stm32-pinctrl pin-controller: Function[18 name:i2c_4, groups:1] stm32-pinctrl pin-controller: Function[19 name:gpio, groups:3] stm32-dma 40026000.dma: STM32 DMA driver registered stm32-dma 40026400.dma: STM32 DMA driver registered SCSI subsystem initialized u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** soc:phy_hs supply vcc not found, using dummy regulator soc:phy_fs supply vcc not found, using dummy regulator pps_core: LinuxPPS API ver. 1 registered pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> PTP clock support registered Advanced Linux Sound Architecture Driver Initialized. Bluetooth: Core ver 2.20 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized clocksource: Switched to clocksource arm_system_timer NET: Registered protocol family 2 TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Power Management for STM32 futex hash table entries: 16 (order: -5, 192 bytes) jffs2: version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc. fuse init (API version 7.23) Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250) io scheduler noop registered io scheduler cfq registered (default) stm32-pinctrl pin-controller: maps: function gpio group pwms num 2 stm32-pwm pwm0: basing on TIM3.1(x16) stm32-pinctrl pin-controller: maps: function ltdc group ltdc-0 num 29 stm32_lcdfb 40016800.ltdc: fb0: fb device registered successfully STM32 USART driver initialized stm32-pinctrl pin-controller: maps: function usart1 group usart1-0 num 3 40011000.serial: ttyS0 at MMIO 0x40011000 (irq = 34, base_baud = 6750000) is a stm32-usar t console [ttyS0] enabled stm32-pinctrl pin-controller: maps: function usart6 group usart6-0 num 3 40011400.serial: ttyS5 at MMIO 0x40011400 (irq = 35, base_baud = 6750000) is a stm32-usar t nbd: registered device at major 43 stm32-pinctrl pin-controller: maps: function dac_out2_pin group dac-0 num 2 stm32_dac 40007400.dac: dac1: no timer assigned, DMA functionality is not available stm32_dac 40007400.dac: created 1 character devices with MAJOR 248 2 ofpart partitions found on MTD device physmap-stm-flash.0 Creating 2 MTD partitions on "physmap-stm-flash.0": 0x000000000000-0x000000020000 : "stm_flash_uboot" 0x000000040000-0x000000100000 : "stm_flash_unused" stm32-pinctrl pin-controller: maps: function spi_5 group spi_5-0 num 4 stm32-spi 40015000.spi: SPI Controller 4 at 40015000,irq=38,hz=108000000 CAN device driver interface stm32-pinctrl pin-controller: maps: function can_1 group can_1-0 num 3 stm32-can 40006400.can: device registered (reg=40006400, irq=31) stm32-pinctrl pin-controller: maps: function mac group mac_rmii num 10 stmmac - user ID: 0x10, Synopsys ID: 0x35 Ring mode enabled DMA HW capability register supported Enhanced/Alternate descriptors Enabled extended descriptors RX Checksum Offload Engine supported (type 2) TX Checksum insertion supported Wake-Up On Lan supported Enable RX Mitigation via HW Watchdog Timer stm32-dwmac 40028000.ethernet eth0: No MDIO subnode found libphy: stmmac: probed eth0: PHY ID 0007c0f1 at 0 IRQ POLL (stmmac-0:00) active PPP generic driver version 2.4.2 PPP BSD Compression module registered PPP Deflate Compression module registered u***core: registered new interface driver rt2800u*** stm32-pinctrl pin-controller: maps: function u***_hs group u***_hs-0 num 3 dwc2 40040000.u***: DWC OTG Controller dwc2 40040000.u***: new USB bus registered, assigned bus number 1 dwc2 40040000.u***: irq 56, io mem 0x00000000 u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***1: Product: DWC OTG Controller u*** u***1: Manufacturer: Linux 4.2.0 dwc2_hsotg u*** u***1: SerialNumber: 40040000.u*** hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected stm32-pinctrl pin-controller: maps: function u***_fs group u***_fs-0 num 3 50000000.u*** supply vu***_d not found, using dummy regulator 50000000.u*** supply vu***_a not found, using dummy regulator dwc2 50000000.u***: EPs: 6, dedicated fifos, 512 entries in SPRAM dwc2 50000000.u***: DCFG=0x08200000, DCTL=0x00000002, DIEPMSK=0000000b dwc2 50000000.u***: GAHBCFG=0x00000000, GHWCFG1=0x00000000 dwc2 50000000.u***: GRXFSIZ=0x000000a0, GNPTXFSIZ=0x004000a0 dwc2 50000000.u***: DPTx[1] FSize=32, StAddr=0x000000e0 dwc2 50000000.u***: DPTx[2] FSize=64, StAddr=0x00000100 dwc2 50000000.u***: DPTx[3] FSize=512, StAddr=0x00000800 dwc2 50000000.u***: DPTx[4] FSize=512, StAddr=0x00000a00 dwc2 50000000.u***: DPTx[5] FSize=512, StAddr=0x00000c00 dwc2 50000000.u***: ep0-in: EPCTL=0x00008000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep0-out: EPCTL=0x00008000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep1-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep1-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep2-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep2-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep3-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep3-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep4-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep4-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep5-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: ep5-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb dwc2 50000000.u***: DVBUSDIS=0x000017d7, DVBUSPULSE=000005b8 u***core: registered new interface driver cdc_acm cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters u***core: registered new interface driver uas u***core: registered new interface driver u***-storage g_serial gadget: Gadget Serial v2.4 g_serial gadget: g_serial ready dwc2 50000000.u***: bound driver g_serial i2c /dev entries driver stm32-pinctrl pin-controller: maps: function i2c_4 group i2c_4-0 num 3 bmp085 3-0077: Successfully initialized bmp085! stm32f7-i2c 40006000.i2c: I2C Controller i2c-3 at 40006000,irq=58 Driver for 1-wire Dallas network protocol. u***core: registered new interface driver btu*** stm32-pinctrl pin-controller: maps: function sdio group sdio-0 num 7 mmci-pl18x 40012c00.sdi: Got CD GPIO mmci-pl18x 40012c00.sdi: mmc0: PL180 manf 80 rev4 at 0x40012c00 irq 37,0 (pio) stm32-dma 40026400.dma: stm32_dma_of_xlate: unable to get channel 3 - was already request ed mmci-pl18x 40012c00.sdi: DMA channels RX dma1chan3, TX dma1chan3 stm32_gpio_to_irq: Event line 3 now points to fire interrupts from bank G stm32-pinctrl pin-controller: maps: function gpio group outs num 2 hidraw: raw HID events driver (C) Jiri Kosina u***core: registered new interface driver u***hid u***hid: USB HID core driver stm32-pinctrl pin-controller: maps: function adc1_in0_pin group adc1-0 num 2 stm32f4-adc 40012000.adc: registered stm32-pinctrl pin-controller: maps: function sai_2 group sai_2-0 num 5 stm32-dma 40026400.dma: stm32_dma_of_xlate: unable to get channel 4 - was already request ed stm32-asoc-card sound: failed to find codec platform device stm32-asoc-card: probe of sound failed with error -22 NET: Registered protocol family 17 can: controller area network core (rev 20120528 abi 9) NET: Registered protocol family 29 can: raw protocol (rev 20120528) can: broadcast manager protocol (rev 20120528 t) can: netlink gateway (rev 20130117) max_hops=1 Bluetooth: RFCOMM TTY layer initialized Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 hctosys: unable to open rtc device (rtc0) vmmc: disabling ALSA device list: No soundcards found. Freeing unused kernel memory: 4000K (c0312000 - c06fa000) init started: BusyBox v1.24.2 (2018-11-22 20:35:58 EST) / # amixer: Mixer attach default error: No such file or directory stm32-dwmac 40028000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx / # free total used free shared buffers cached Mem: 60432 8140 52292 0 0 4792 -/+ buffers/cache: 3348 57084 / # |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4191 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3255 浏览 1 评论
2787 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2219 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15105 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3158浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1933浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2103浏览 3评论
2014浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2206浏览 3评论
/9
GMT+8, 2025-12-11 04:46 , Processed in 1.160250 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
579
