电子发烧友论坛|
本次串口调试过程中遇到两个问题:
1、发送数据出现死循环: 具体表现为: 程序卡死在 while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET); 无数据输出。TXD线上只是低电平,发送端口指示灯常亮。 注:串口1的引脚定义是PA.09,PA.10 解决问题: 串口初始化时:USART1 和USART6 要使用 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USARTx, ENABLE);而 USART2, USART3, UART4 , UART5要使用 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USARTx, ENABLE) ;问题得以解决。 typedef struct _UART_CFG { USART_TypeDef* UartNo; PIN_CFG Tx; PIN_CFG RX; uint32_t BaudRate; }UART_CFG; void Comm_Port_Init(void) { UART_CFG uart_comm; uart_comm.UartNo = UART_COM; uart_comm.Tx.Pin= GPIO_Pin_9; uart_comm.Tx.Port = GPIOA; uart_comm.RX.Pin = GPIO_Pin_10; uart_comm.RX.Port = GPIOA; uart_comm.BaudRate = BAUD_COM; Uart_Init(uart_comm); } void Uart_Init(UART_CFG uart) { uint8_t Uart_IRQChannel_No; uint32_t RCC_APB1Periph; GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; NVIC_InitTypeDef NVIC_InitStructure; if(uart.UartNo == USART1) { Uart_IRQChannel_No = USART1_IRQn; RCC_APB1Periph = RCC_APB2Periph_USART1; RCC_APB2PeriphClockCmd(RCC_APB1Periph, ENABLE); } else if(uart.UartNo == USART2) { Uart_IRQChannel_No = USART2_IRQn; RCC_APB1Periph = RCC_APB1Periph_USART2; RCC_APB1PeriphClockCmd(RCC_APB1Periph, ENABLE); } else if(uart.UartNo == USART3) { Uart_IRQChannel_No = USART3_IRQn; RCC_APB1Periph = RCC_APB1Periph_USART3; RCC_APB1PeriphClockCmd(RCC_APB1Periph, ENABLE); } else if(uart.UartNo == UART4) { Uart_IRQChannel_No = UART4_IRQn; RCC_APB1Periph = RCC_APB1Periph_UART4; RCC_APB1PeriphClockCmd(RCC_APB1Periph, ENABLE); } else { Uart_IRQChannel_No = UART5_IRQn; RCC_APB1Periph = RCC_APB1Periph_UART5; RCC_APB1PeriphClockCmd(RCC_APB1Periph, ENABLE); } GPIO_InitStructure.GPIO_Pin = uart.Tx.Pin; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(uart.Tx.Port, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = uart.RX.Pin; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(uart.RX.Port, &GPIO_InitStructure); USART_InitStructure.USART_BaudRate = uart.BaudRate; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(uart.UartNo, &USART_InitStructure);//初始化外设 USARTx 寄存器 USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(uart.UartNo, &USART_ClockInitStructure); USART_Cmd(uart.UartNo, ENABLE); USART_ITConfig(uart.UartNo,USART_IT_RXNE,ENABLE);//ENABLE-DISABLE//使能或者失能指定的 USART 中断 NVIC_InitStructure.NVIC_IRQChannel = Uart_IRQChannel_No; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } 2、接收数据中断出现死循环: 具体表现:收到数据程序会不断进入中断,USART_GetITStatus 检查又没有中断发生。本函数一退出就重新再进入,就这样死循环了。源代码如下: void USART2_IRQHandler(void) { BYTE Data = 0; OSIntEnter(); if(USART_GetITStatus(USART1,USART_IT_RXNE) != RESET) //检查指定的usart是否发生了中断 { Data = USART_ReceiveData(USART2); // do something at this; 处理数据 USART_ClearFlag(USART2,USART_FLAG_TC ); //清除中断标志 } else { USART_ClearFlag(UART_COM, USART_IT_ORE); } OSIntExit(); } 解决办法: 进入中断后必须第一时间清零RXNE,如没及时清零,下一帧数据过来时就会产生Overrun error! 更改为如下代码就OK了。 void USART2_IRQHandler(void) { BYTE Data = 0; OSIntEnter(); if(USART_GetITStatus(USART1,USART_IT_RXNE) != RESET) //检查指定的usart是否发生了中断 { Data = USART_ReceiveData(USART2); USART_ClearFlag(USART2,USART_FLAG_TC ); //清除中断标志 // do something at this; 处理数据 } else { USART_ClearFlag(UART_COM, USART_IT_ORE); } OSIntExit(); } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2166浏览 3评论
/9
GMT+8, 2025-12-2 04:15 , Processed in 0.489824 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1974
