电子发烧友论坛|
uint8_t UART4_Rx_buffer[512],UART4_Rx_num; void UART4_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; DMA_InitTypeDef DMA_InitStructure; // NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); //选择NVIC优先级分组0 RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE); //串口4所使用管脚输出输入定义 //定义UART4 Tx (PC.10)脚为复用推挽输出 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //IO口的第2脚 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //IO口复用推挽输出 GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化串口1输出IO口 //定义 UART4 Rx (PC.11)为悬空输入 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //IO口的第3脚 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//IO口悬空输入 GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化串口1输入IO口 //串口4参数初始化定义部分,串口1参数为9600 , 8 ,1 ,N 接收中断方式 USART_InitStructure.USART_BaudRate = 9600; //设定传输速率 USART_InitStructure.USART_WordLength = USART_WordLength_8b; //设定传输数据位数 USART_InitStructure.USART_StopBits = USART_StopBits_1; //设定停止位个数 USART_InitStructure.USART_Parity = USART_Parity_No ; //不用校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不用流量控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //使用接收和发送功能 USART_Init(UART4, &USART_InitStructure); //初始化串口4 USART_ITConfig(UART4, USART_IT_IDLE,ENABLE); //使能串口4接收中断 USART_Cmd(UART4, ENABLE); //使能串口4 USART_ClearFlag(UART4, USART_FLAG_TC); // 清标志(后增加) DMA_DeInit(DMA2_Channel3); //重置DMA 2通道配置 DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40004C04; //外设地址 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)UART4_Rx_buffer; //内存地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //外设作为数据目的地 DMA_InitStructure.DMA_BufferSize = 512; //DMA缓存大小:BufferSize DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; // DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //外设数据宽度为8位 DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte; //内存数据宽度为8位 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在正常缓存模式 DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; //设置DMA通道优先级为高 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //禁止DMA通道设置为内存至内存传输 DMA_Init(DMA2_Channel3, &DMA_InitStructure); //初始化 DMA_ITConfig(DMA2_Channel3, DMA_IT_TC, ENABLE); DMA_ITConfig(DMA2_Channel3, DMA_IT_TE, ENABLE); USART_DMACmd(UART4, USART_DMAReq_Rx, ENABLE); DMA_Cmd(DMA2_Channel3, ENABLE); //使能串口4中断 NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = DMA2_Channel3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } void UART4_IRQHandler(void) { uint16_t i; uint16_t Data_Len; if(USART_GetITStatus(UART4, USART_IT_IDLE) != RESET) //如果为中断 { DMA_Cmd(DMA2_Channel3, DISABLE); Data_Len=512-DMA_GetCurrDataCounter(DMA2_Channel3); USART_PutStr(USART1,UART4_Rx_buffer,Data_Len); UART4_Rx_num=0; DMA_ClearFlag(DMA2_FLAG_GL3 | DMA2_FLAG_TC3 | DMA2_FLAG_TE3 | DMA2_FLAG_HT3); //清标志 DMA2_Channel3->CNDTR = 512; //重装填 DMA_Cmd(DMA2_Channel3, ENABLE); //处理完,重开DMA //读SR后读DR清除IDLE i = UART4->SR; i = UART4->DR; if(i) i=0; if(Data_Len) Data_Len=0; } } if(USART_GetITStatus(UART4, USART_IT_PE | USART_IT_FE | USART_IT_NE) != RESET) { //出错 USART_ClearITPendingBit(UART4, USART_IT_PE | USART_IT_FE | USART_IT_NE); USART_ClearITPendingBit(UART4, USART_IT_TC); USART_ClearITPendingBit(UART4, USART_IT_IDLE); void DMA2_Channel3_IRQHandler(void) USART_PutStr(USART1," DMA23:rn",9); DMA_ClearITPendingBit(DMA2_IT_TC3); DMA_ClearITPendingBit(DMA2_IT_TE3); DMA_Cmd(DMA2_Channel3, DISABLE); //关闭DMA,防止处理其间有数据 DMA2_Channel3->CNDTR = 512; //重装填 DMA_Cmd(DMA2_Channel3, ENABLE); //处理完,重开DMA } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 22:02 , Processed in 0.559118 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1730
