电子发烧友论坛扫一扫,分享给好友
STM32F103共有五个串口,有时候在项目中,其他的引脚已经配置用了,重新改太麻烦
STM32串口3 映射和完全重映射 PB10 PB11 PD8 PD9 PC10 PC11 所有本次实验 使用了串口3的映射端口,配置和普通的类似 只是注意要使用映射使能说明 GPIO_PinRemapConfig(GPIO_FullRemap_USART3 , ENABLE); void USART3_Configuration(u32 bound) { //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; #if 1 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //remap时钟|RCC_APB2Periph_AFIO //开启GPIOB时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//这里要分开打开 //USART3时钟 来自APB1 #endif #if 0 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//开启GPIOB和USART3时钟 //USART3_TX GPIOB.10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //PB.10 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOA.10 //USART3_RX GPIOB.11初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;//PB11 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB.11 #endif #if 0 //重映射 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //remap时钟|RCC_APB2Periph_AFIO //开启GPIOB时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//这里要分开打开 //USART3时钟 来自APB1 //GPIO_PartialRemap_USART3 部分重映射 GPIOC_10 GPIOC_11 GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE); //USART3_TX GPIOC.10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化 //USART3_RX GPIOC.11初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOC, &GPIO_InitStructure);//初始 #endif #if 1 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //remap时钟|RCC_APB2Periph_AFIO //开启GPIOB时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//这里要分开打开 //USART3时钟 来自APB1 //GPIO_FullRemap_USART3 完全重映射 D8 D9 GPIO_PinRemapConfig(GPIO_FullRemap_USART3,ENABLE); //USART3_TX GPIOD8 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化 //USART3_RX GPIOD9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOD, &GPIO_InitStructure);//初始 #endif //Usart3 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1 ;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 //USART 初始化设置 USART_InitStructure.USART_BaudRate = bound;//串口波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART3, &USART_InitStructure); //初始化串口3 USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);//开启串口接受中断 USART_Cmd(USART3, ENABLE); //使能串口3 } #include "sys.h" #include "usart.h" #include "timer.h" #include "stdint.h" u8 checkdata[8]; //检测串口1接收的特定数据数据 //发送上位机的数据 // uint32_t crc16_data1[] = { 0x00,0x00, 0x00 };//饮水机数据 uint32_t crc16_data2[] = { 0x00,0x00, 0x00 };// uint32_t crc16_data3[] = { 0x00,0x00, 0x00 };// uint32_t crc16_data4[] = { 0x00,0x00, 0x00 };// uint32_t crc16_data5[] = { 0x00,0x00, 0x00 };// uint32_t crc16_data6[] = { 0x00,0x00, 0x00 };// uint32_t crc16_data7[] = { 0x00,0x00, 0x00 };// uint32_t crc16_data8[] = { 0x00,0x00, 0x00 };// uint32_t crc16_data9[] = { 0x00,0x00, 0x00 };// uint32_t crc16_data10[]= { 0x00,0x00, 0x00 };// //串口1队列定义 u8 UART1SendBuff[UART1BuffSize]; //发送数据 u8 UART1ReceBuff[UART1BuffSize]; //接收数据? u16 UART1ReceIn = 0;//接收状态标记数据位 u8 UART1ReceFullFlag = 0;//接收完数据标志位 //串口3队列定义 u8 UART3SendBuff[UART3BuffSize]; //发送数据 u8 UART3ReceBuff[UART3BuffSize]; //接收数据? u16 UART3ReceIn = 0;//接收状态标记数据位 u8 UART3ReceFullFlag = 0;//接收完数据标志位 void USART1_Configuration(u32 bound){ //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA时钟 //USART1_TX GPIOA.9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9 //USART1_RX GPIOA.10初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10 //Usart1 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2 ;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 //USART 初始化设置 USART_InitStructure.USART_BaudRate = bound;//串口波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口1 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断 USART_Cmd(USART1, ENABLE); //使能串口1 } void USART3_Configuration(u32 bound) { //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; #if 1 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //remap时钟|RCC_APB2Periph_AFIO //开启GPIOB时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//这里要分开打开 //USART3时钟 来自APB1 #endif #if 0 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//开启GPIOB和USART3时钟 //USART3_TX GPIOB.10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //PB.10 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOA.10 //USART3_RX GPIOB.11初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;//PB11 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB.11 #endif #if 0 //重映射 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //remap时钟|RCC_APB2Periph_AFIO //开启GPIOB时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//这里要分开打开 //USART3时钟 来自APB1 //GPIO_PartialRemap_USART3 部分重映射 GPIOC_10 GPIOC_11 GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE); //USART3_TX GPIOC.10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化 //USART3_RX GPIOC.11初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOC, &GPIO_InitStructure);//初始 #endif #if 1 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //remap时钟|RCC_APB2Periph_AFIO //开启GPIOB时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//这里要分开打开 //USART3时钟 来自APB1 //GPIO_FullRemap_USART3 完全重映射 D8 D9 GPIO_PinRemapConfig(GPIO_FullRemap_USART3,ENABLE); //USART3_TX GPIOD8 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化 //USART3_RX GPIOD9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOD, &GPIO_InitStructure);//初始 #endif //Usart3 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1 ;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 //USART 初始化设置 USART_InitStructure.USART_BaudRate = bound;//串口波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART3, &USART_InitStructure); //初始化串口3 USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);//开启串口接受中断 USART_Cmd(USART3, ENABLE); //使能串口3 } //串口1发送一帧数据 void USART1_SendOneData(uint32_t SendOneData) { USART_SendData(USART1, SendOneData); while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET) {} } //串口2发送一帧数据 void USART2_SendOneData(uint32_t SendOneData) { USART_SendData(USART2, SendOneData); while (USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET) {} } //串口3发送一帧数据 void USART3_SendOneData(uint32_t SendOneData) { USART_SendData(USART3, SendOneData); while (USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET) {} } //串口1发送一列数据 void USART1_SendUnfixedData(uint32_t *Buffer, uint8_t Length) { uint8_t i; for(i=0;i USART1_SendOneData(*Buffer++); } } //串口2发送一列数据 void USART2_SendUnfixedData(uint32_t *Buffer, uint8_t Length) { uint8_t i; for(i=0;i USART2_SendOneData(*Buffer++); } } //串口3发送一列数据 void USART3_SendUnfixedData(uint32_t *Buffer, uint8_t Length) { uint8_t i; for(i=0;i USART3_SendOneData(*Buffer++); } } //串口1中断服务函数 void USART1_IRQHandler(void) { u8 Res;//数据暂存 if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断 { Res =USART_ReceiveData(USART1); //读取接收到的数据 switch(UART1ReceIn)//读取接收到的数据有几位 每一位对应的数据协议校验 { case 0: if(Res==0xFE) UART1ReceBuff[UART1ReceIn++] = Res; else UART1ReceIn = 0; break; case 1: if(Res==0xFE) UART1ReceBuff[UART1ReceIn++] = Res; else UART1ReceIn = 0; break; case 2://此处为判断数据的位置 正反转 // if(Res==0x02)//在其他位置判断数据 // {UART1ReceBuff[UART1ReceIn++] = Res; // checkdata[0]=UART1ReceBuff[2];} {UART1ReceBuff[UART1ReceIn++] = Res; checkdata[0]=UART1ReceBuff[2]; } break; case 3://此处为判断数据的位置 旋转角度 // if(Res==0x02)//在其他位置判断数据 // {UART1ReceBuff[UART1ReceIn++] = Res; // checkdata[0]=UART1ReceBuff[2];} {UART1ReceBuff[UART1ReceIn++] = Res; checkdata[1]=UART1ReceBuff[3]; //接收到的角度数据和实际齿轮数据不一致 } break; case 4: if(Res==0xFD) UART1ReceBuff[UART1ReceIn++] = Res; else UART1ReceIn = 0; break; case 5: if(Res==0xFD) UART1ReceBuff[UART1ReceIn++] = Res; else UART1ReceIn = 0; break; default: UART1ReceBuff[UART1ReceIn++] = Res; break; } if(UART1ReceIn >= 5) { UART1ReceFullFlag = 1; //数据完整接受完 UART1ReceIn = 0; timer8flag=0; } // USART_ClearFlag(USART1, USART_IT_RXNE);//清除相对应的中断位 清除中断预处理位USART_ClearITPendingBit左移八位是USART_ClearFlag USART_ClearITPendingBit(USART1, USART_IT_RXNE);//清除相对应的中断位 清除中断预处理位USART_ClearITPendingBit左移八位是USART_ClearFlag // } if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET) // 发送中断 USART_GetITStatus { // USART_ClearFlag(USART1, USART_IT_TXE); // clear interrupt 清除中断预处理位 USART_ClearITPendingBit(USART1, USART_IT_TXE); // clear interrupt 清除中断预处理位 } // if(USART_GetFlagStatus(USART1, USART_FLAG_ORE) != RESET) // { // USART_ClearFlag(USART1, USART_FLAG_ORE); // } } //串口3中断服务函数 void USART3_IRQHandler(void) { u8 Res;//数据暂存 if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET) //接收中断 { Res =USART_ReceiveData(USART3); //读取接收到的数据 USART_ReceiveData USART_SendData(USART1,Res);//将读取到的数据通过串口1发送 switch(UART3ReceIn)//读取接收到的数据有几位 每一位对应的数据协议校验 { case 0: if(Res==0XFE) UART3ReceBuff[UART3ReceIn++] = Res; else UART3ReceIn = 0; break; case 10: if(Res==0xFF) UART3ReceBuff[UART3ReceIn++] = Res; else UART3ReceIn = 0; break; default: UART3ReceBuff[UART3ReceIn++] = Res; break; } if(UART3ReceIn >= 11) { UART3ReceFullFlag = 1; //数据完整接受完 } USART_ClearITPendingBit(USART3, USART_IT_RXNE);//清除相对应的中断位 清除中断预处理位USART_ClearITPendingBit左移八位是USART_ClearFlag } else if(USART_GetITStatus(USART3, USART_IT_TXE) != RESET) // 发送中断 USART_GetITStatus { USART_ClearITPendingBit(USART3, USART_IT_TXE); // clear interrupt 清除中断预处理位 } } void send_data() { //刷新位置信息 if(timer8flag100ms==1) { timer8flag100ms=0; //发送协议头 FE FE D1 USART_SendData(USART1,0xFA);//向串口1发送数据 while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 USART_SendData(USART1,0xFC); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容1 USART1_SendUnfixedData(crc16_data1,1);//空开1 while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容2 USART1_SendUnfixedData(crc16_data2,1);//空开2 while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容3 USART1_SendUnfixedData(crc16_data3,1);//空开3 while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容4 USART1_SendUnfixedData(crc16_data4,1);//空开4 while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容5 USART1_SendUnfixedData(crc16_data5,2);//饮水机 空烧数据 while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容设备接地的数据 (过载实验)(1111 1111)(八个设备) USART1_SendUnfixedData(crc16_data6,1); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容7 接地触电 crc16_data7[0] 湿手触电 crc16_data7[1] USART1_SendUnfixedData(crc16_data7,1); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容8 发送给串口的数据 USART1_SendUnfixedData(crc16_data8,1); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 //发送协议尾 FD FD USART_SendData(USART1,0xFD);//向串口1发送数据 while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 USART_SendData(USART1,0xFD); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 } } void send_data_usart3(void) { //刷新位置信息 if(timer8flag200ms==1) { timer8flag200ms=0; //发送协议头 FE FE D1 USART_SendData(USART3,0xFA);//向串口1发送数据 while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 USART_SendData(USART3,0xFC); while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容1 USART3_SendUnfixedData(crc16_data1,1);//空开1 while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容2 USART3_SendUnfixedData(crc16_data2,1);//空开2 while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容3 USART3_SendUnfixedData(crc16_data3,1);//空开3 while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容4 USART3_SendUnfixedData(crc16_data4,1);//空开4 while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容5 USART3_SendUnfixedData(crc16_data5,2);//饮水机 空烧数据 while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容设备接地的数据 (过载实验)(1111 1111)(八个设备) USART3_SendUnfixedData(crc16_data6,1); while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容7 接地触电 crc16_data7[0] 湿手触电 crc16_data7[1] USART3_SendUnfixedData(crc16_data7,1); while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送数据内容8 发送给串口的数据 USART3_SendUnfixedData(crc16_data8,1); while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 //发送协议尾 FD FD USART_SendData(USART3,0xFD);//向串口1发送数据 while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 USART_SendData(USART3,0xFD); while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束 } } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4194 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3256 浏览 1 评论
2788 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2221 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15119 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3159浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1933浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2103浏览 3评论
2016浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2207浏览 3评论
/9
GMT+8, 2025-12-11 17:23 , Processed in 0.566951 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2244
