电子发烧友论坛|
0简介
开发板: stm32f407vgt6 IDE: keil + cubemx6.0 功能: 实现stm32HAL 串口IAP, 协议采用非阻塞式ymodem协议, 能够使用超级终端或者securRT 发送bin文件, 同时能接受文件 1 流程 串口中断发送过来的数据存储到缓冲区, 每次从缓冲区中拿出数据丢到数据解析器, 解析出每帧. // 可以切换接受和发送模式 #define USE_RX_MODE #define KAPP_ADDR (uint32_t)0x08004000 // 串口接受回调 void g_com_rx_callBack(unsigned char* data,uint32_t size) { #ifdef USE_RX_MODE ymodem_rx_handle(data,size); #else ymodem_tx_handle(data,size); #endif } // 串口错误回调 void g_ymodem_rx_error_handle(int error_code) { printf("--error code :%d--rn",error_code); } // 接受head回调 char g_ymodem_rx_head_handle(char *file_name,uint16_t file_name_len, uint32_t file_len) { printf("file:%s %drn",file_name,file_len); FLASH_If_Erase( KAPP_ADDR); return 0; } uint32_t app_addr = KAPP_ADDR; // 接受数据回调 void g_ymodem_rx_data_handle(char *data, uint16_t len,uint32_t download_byte,uint8_t percent) { printf("data len:%d %d %drn",len,download_byte ,percent); if (FLASH_If_Write(app_addr,(uint32_t*) data,len/4) == FLASHIF_OK) { app_addr += len; printf("data write okrn"); }else{ printf("data write errorrn"); } } // 接受完成回调 void g_ymodem_rx_finish_handle(int state) { if(state ==0){ printf("--file end--rn"); iap_load_app(KAPP_ADDR); }else{ printf("--file end error1 :%d--rn",state); } } // 发送数据处理 void g_ymodem_tx_data_handle(uint8_t **file_read_addr, uint32_t file_read_size, uint32_t file_has_read_size, uint32_t file_remain_size,uint8_t percent) { printf("read size:%d has_read:%d remain:%d per:%drn",file_read_size,file_has_read_size, file_remain_size,percent); // 指针指向的地址 重新指向 *file_read_addr = &file[file_has_read_size]; } int main() { // 注册串口缓冲区回调 dev_comctrl_init(); dev_comctrl_regist_rx_callback(g_com_rx_callBack); // 注册ymodem回调 Ymodem_TypeDef ymodem; ymodem.ymodem_write_byte = drv_com1_write; ymodem.ymodem_rx_error_handle = g_ymodem_rx_error_handle; ymodem.ymodem_rx_head_handle = g_ymodem_rx_head_handle; ymodem.ymodem_rx_data_handle = g_ymodem_rx_data_handle; ymodem.ymodem_rx_finish_handle = g_ymodem_rx_finish_handle; ymodem.ymodem_tx_data_handle = g_ymodem_tx_data_handle; ymodem_init(&ymodem); // 循环 while (1) { // 串口缓冲区处理 dev_comctrl_handle(); // ymodem定时处理 ymodem_rx_time_handle(); return 0; } 2 发送模式使用: 1 流程 把宏定义注释打开,就是往单片机写数据 #define USE_RX_MODE 软件: securRT或者超级终端都可以 1 重启32, 会一直发C 2 选择transfer -> send ymodem , 选择要发送的文件 选中固件之后, 直接点击发送 3 接受模式使用 1 流程 把宏定义去掉 // #define USE_RX_MODE 打开接受模式 注意的是: // 发送数据处理 void g_ymodem_tx_data_handle(uint8_t **file_read_addr, uint32_t file_read_size, uint32_t file_has_read_size, uint32_t file_remain_size,uint8_t percent) { printf("read size:%d has_read:%d remain:%d per:%drn",file_read_size,file_has_read_size, file_remain_size,percent); // 指针指向的地址 重新指向 *file_read_addr = &file[file_has_read_size]; } file_read_addr是指针的指针, 用于重定向指针指向, 所以每次发送数据后都要重新指定, 避免发送重复 ,这种使用的最好场景就是大文件的发送, 可以开1K的缓冲区, 然后每次发送之后重新指定指针指向 如果下载失败,或者擦除失败 注意除了main.c 有定义用户启动地址, flash_if.h .c中也定义了APP地址和要擦除的扇区 如果往stm32写数据失败, 注意flash_if.c里面的扇区擦除, 如果目前代码太大,超过了之前设置的代码, 那么就造成失败 所以一定要预留好bootloader的flash空间 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4226 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3266 浏览 1 评论
2799 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2232 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15204 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3178浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1948浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2117浏览 3评论
2022浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2223浏览 3评论
/9
GMT+8, 2025-12-17 16:56 , Processed in 0.777199 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1273
