电子发烧友论坛|
serial库安装
pip install pyserial python上位机代码 以下功能具体封装成函数了,在实际开发中,接收数据可以和线程配合使用。实现了循环发送与接收 import serial # 串口打开函数 def open_ser(): port = 'com4' # 串口号 baudrate = 9600 # 波特率 try: global ser ser = serial.Serial(port,baudrate,timeout=0.5) if(ser.isOpen()==True): print("串口打开成功") except Exception as exc: print("串口打开异常",exc) # 数据发送 def send_msg(): try: send_datas = input("请输入要发送的数据n") ser.write(str(send_datas).encode("gbk")) print("已发送数据:",send_datas) except Exception as exc: print("发送异常", exc) # 接收数据 def read_msg(): try: print("等待接收数据") while True: data = ser.read(ser.in_waiting).decode('gbk') if data != '': break print("已接受到数据:",data) except Exception as exc: print("读取异常",exc) # 关闭串口 def close_ser(): try: ser.close() if ser.isOpen(): print("串口未关闭") else: print("串口已关闭") except Exception as exc: print("串口关闭异常", exc) if __name__ == '__main__': open_ser() # 打开串口 send_msg() # 写数据 read_msg() # 读数据 close_ser() # 关闭串口 stm32端程序 在这里32 的程序没必要太复杂,就写一个串口程序方便测试就行。 #include #include void USART1_Init(u32 bound) { //端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); /* 配置IO口*/ GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;//TX PA9 GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP; GPIO_Init(GPIOA,&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;//RX PA10 GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA,&GPIO_InitStructure); //USART1 初始化设置 USART_InitStructure.USART_BaudRate = bound;//波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); USART_ClearFlag(USART1, USART_FLAG_TC); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启相关中断 //Usart1 NVIC 中断配置 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;//串口1中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority =3; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /*********中断服务子程序************/ void USART1_IRQHandler(void) { unsigned char r; if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) { r =USART_ReceiveData(USART1);//(USART1->DR); USART_SendData(USART1,r); while(USART_GetFlagStatus(USART1,USART_FLAG_TC) != SET); } USART_ClearFlag(USART1,USART_FLAG_TC); } /********LED IO口配置***********/ void LED_INIT() { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE); GPIO_InitStructure.GPIO_Pin=GPIO_Pin_13;//PC13 GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP; GPIO_Init(GPIOC,&GPIO_InitStructure); GPIO_SetBits(GPIOC,GPIO_Pin_13); } /**************LED闪烁***************/ void display1(void) { GPIO_SetBits(GPIOC,GPIO_Pin_13);//点亮 delay_ms(1000); GPIO_ResetBits(GPIOC,GPIO_Pin_13);//熄灭 delay_ms(1000); } /***********主函数**************/ int main() { SysTick_Init(72); LED_INIT(); //led初始化 USART1_Init(9600);//串口初始化,自动开启串口中断,进行数据自动接收和发送 while(1) { display1();// led闪烁表示系统正常运行 } } 以上代码我是亲测可用的。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 22:04 , Processed in 0.739094 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2898
