【FPGA经典试题】FPGA的乘法运算Verilog 模块、DPRAM 的设计模块
⑴ 请参看如下文章,写出文中的关键点;
⑵ 写出当外部同时输入了时钟和reset 信号,两个8bit 补码数的乘法运算的
Verilog 模块;
⑶ 写出当外部同时输入了时钟和reset 信号,DPRAM 的设计代码;
1.文中重要讲的事复位方式的选择会影响设计性能。乘法器和RAMs 的寄存器只
能使用同步复位。
Verilog 模块;
- 2.
- module mul_8bit(clk,reset,multiplicand,multiplier,ValOut); //start
- parameter width = 8;
- input clk;
- input reset;
- //input start;
- input [7:0] multiplicand;
- input [7:0] multiplier;
- output [15:0] ValOut;
- reg [15:0] ValOut;
- wire [7:0] mulD;
- wire [7:0] mulR;
- wire sign1,sign2,sign3,sign4;
- wire one1,one2,one3,one4;
- wire two1,two2,two3,two4;
- //·ûºÅsign=~A[2n+1] & (A[2n]|
- A[2n-1])£»sign±íʾ·ûºÅλ£¬μ±ÆäΪ1ʱ£¬Ôò²¼Ë¹±àÂëÈ¡Õý£»·´Ö®£¬È¡¸º¡£
- A[-1] ²¹Áã¼´A[-1]=0
- assign sign1 = ~mulR[1] & (mulR[0] | 0);
- assign sign2 = ~mulR[3] & (mulR[2] | mulR[1]);
- assign sign3 = ~mulR[5] & (mulR[4] | mulR[3]);
- assign sign4 = ~mulR[7] & (mulR[6] | mulR[5]);
- //one; one=A[2n]^A[2n-1]£»Èôone=1,Ôò²¿·Ö»ýΪb£»·ñÔòΪ0¡£
- assign one1 = mulR[0]^0;
- assign one2 = mulR[2]^mulR[1];
- assign one3 = mulR[4]^mulR[3];
- assign one4 = mulR[6]^mulR[5];
- //two=(¡«A[2n+1]&A[2n]&A[2n-1])|(A[2n+1]&¡«A[2n]&¡«A[2n-1])£»ÈôtwoΪ1£¬Ô
- ò²¿·Ö»ýΪ2b£»·ñÔòΪ0¡£
- assign two1 = (~mulR[1] & mulR[0] & 0)|(mulR[1] & ~mulR[0] & 1);
- assign two2 = (~mulR[3] & mulR[2] & mulR[1])|(mulR[3] & ~mulR[2] &
- ~mulR[1]);
- assign two3 = (~mulR[5] & mulR[4] & mulR[3])|(mulR[5] & ~mulR[4] &
- ~mulR[3]);
- assign two4 = (~mulR[7] & mulR[6] & mulR[5])|(mulR[7] & ~mulR[6] &
- ~mulR[5]);
- //·ûºÅÀ©Õ¹
- wire [15:0] temp;
- assign temp = {{8{mulD[7]}},mulD[7:0]};
- // ¼ÆËãÊä³ö
- wire [15:0] dat_w1,dat_w2,dat_w3,dat_w4;
- //- 2 * B = = (~ (B << 1)) + 1 ;2B= (B<<1);
- assign dat_w1 = (two1) ? ((sign1) ? {temp[14:0],1'b0}:(~{temp[14:0],1'b0} + 1'b1 ) ) :
- ((one1) ? ((sign1) ? temp :{~temp+1'b1} ) : 0);
- assign dat_w2 = (two2) ? ((sign2) ? {temp[14:0],1'b0}: (~{temp[14:0],1'b0} + 1'b1 )) :
- ((one2) ? ((sign2) ? temp :{~temp+1'b1} ) : 0);
- assign dat_w3 = (two3) ? ((sign3) ? {temp[14:0],1'b0}:(~{temp[14:0],1'b0} + 1'b1 ) ) :
- ((one3) ? ((sign3) ? temp :{~temp+1'b1} ) : 0);
- assign dat_w4 = (two4) ? ((sign4) ? {temp[14:0],1'b0}:(~{temp[14:0],1'b0} + 1'b1 ) ) :
- ((one4) ? ((sign4) ? temp :{~temp+1'b1}) : 0);
- //assign ValOut = dat_w1 + {dat_w2[13:0],2'b00} + {dat_w3[11:0],4'b0000} +
- {dat_w4[9:0],6'b000000};
- assign mulD = multiplicand;
- assign mulR = multiplier;
- always @(posedge clk) begin
- if(!reset) begin
- ValOut <= 0;
- end
- else begin
- ValOut <= dat_w1 + {dat_w2[13:0],2'b00} + {dat_w3[11:0],4'b0000}
- + {dat_w4[9:0],6'b000000};
- end
- end
- endmodule
复制代码
- 3.
- module reg_dpram(Data,Q,clk,reset,WE,RE,Waddress,Raddress);
- parameter depth = 8;
- parameter addr = 3;
- input clk,WE,RE;
- input reset;
- input [addr-1:0] Waddress,Raddress;
- input [width-1:0] data;
- output [width-1:0] Q;
- reg [width-1:0] Q;
- reg [width-1:0] in_reg;
- reg [width-1:0] mem_data [depth-1:0];
- //写RAM
- Always @(posedge clk) begin
- if(~reset) begin
- in_reg <= 0;
- end
- else begin
- in_reg <= Data;
- end
- end
- if(WE) begin
- mem_data[Waddress] <= in_reg;
- end
- emd
- //读数据
- if(~reset) begin
- Q <= 0;
- end
- else begin
- Q <= mem_data[Raddress];
- end
- end
复制代码
