电子发烧友论坛扫一扫,分享给好友
一、 使用说明
1、测试前,需要下载最新的软件包,参见[1] 2、测试例程于:STM32Cube_FW_H7_V1.8.0ProjectsNUCLEO-H7A3ZI-QExamplesGPIOGPIO_IOToggleMDK-ARM 3、由于板子默认支持SMPS,不直接支持LDO,故使用STM32CubeMX生成的时钟初始化函数中,需要进行如下替换: HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);->HAL_PWREx_ConfigSupply(PWR_DIRECT_SMPS_SUPPLY); 4、目前网上买的板子有两个版本:MB1363D [2]和MB1363C [3],可从ST中文官网和ST英文官网下载,使用板子时注意一下版本即可,两个版本的板子差别不大。 5、运行默认例程的新板子的功耗为20~22mA 二、SMPS SMPS 即Switched mode power supply feature ,开关电源 LDO即low dropout regulator,是一种低压差线性稳压器 "NUCLEO-STM32H7A3ZI-Q"中的符号“Q”表示支持SMPS的板子/MCU[4]。 资料[5]中对LDO和SMPS进行的比较: LDOs are simple to regulate, create very little noise and requires no inductor for operation. They also produce a highly accurate output voltage, making them an attractive choice in many aspects. On the other hand, the use of a pass transistor creates excessive heat, leading to reliability issues and low efficiency levels. LDOs are most often used in low-power applications where these drawbacks are minimized by the nature of the application.资料[6]进行了如下的说明: 通过从外部DC/DC(直流/直流)转换器而不是集成LDO生成VCORE逻辑供电来提高运行模 式下的能效。这些器件(标有后缀“P”)使用不同的引脚排列,用两个必须连接到外部 SMPS的VDD12供电引脚取代两个GPIO引脚。因此,可用GPIO的数量减少了2个。“运行 ”模式下的预期功耗增益可高至~60%。三、STM32H743和STM32H7A3的功耗分析 直接贴出STM32H7A3ZI器件手册的典型功耗: Typical and maximum current consumption in Run mode, code with data processing running from Flashmemory, cache ON Typical and maximum current consumption in Run mode, code with data processing running from Flashmemory, cache OFF 根基手册[7][8],笔者归纳出一下结论:
[1]STM32-HAL库(固件库)升级 https://blog.csdn.net/NoDistanceY/article/details/107843529 [2] en.MB1363-H7A3ZIQ-D01_Schematic.pdf [3] en.mb1363_bdp.zip [4] UM2408 User manual STM32H7 Nucleo-144 boards (MB1363) [5] LDOs vs SMPS Power Supplies for Industrial Automation Equipment https://www.motioncontrolonline.org/blog-article.cfm/LDOs-vs-SMPS-Power-Supplies-for-Industrial-Automation-Equipment/44 [6] AN4978_STM32L4外部SMPS设计推荐 https://www.stmcu.org.cn/document/detail/index/id-217922 [7] STM32H7A3xI/G Datasheet [8] STM32H742xI/G STM32H743xI/G Datasheet |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-2 01:19 , Processed in 0.747116 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
657
