电子发烧友论坛|
1个回答
Matlab处理音频文件
Audio_filename = ‘Audio.wav’; % 获取原音频数据 [Audio,Audio_Fs]=audioread(Audio_filename, ‘native’); % 取单声道 Audio_1 = int32(Audio(:, 1)); % -32768~32768 加偏移得到 0~65536 Audio_Output = uint16(Audio_1 + 32768); % 写入文件 fid = fopen(‘Audio.bin’, ‘w’); fwrite(fid, Audio_Output, ‘uint16’); fclose(fid); DAC播放 Tim2触发DAC+DMA播放音频 DAC配置 DAC_HandleTypeDef hdac1; DMA_HandleTypeDef hdma_dac_ch1; /* DAC1 init function */ void MX_DAC1_Init(void) { DAC_ChannelConfTypeDef sConfig = {0}; /** DAC Initialization */ hdac1.Instance = DAC1; if (HAL_DAC_Init(&hdac1) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } /** DAC channel OUT1 config */ sConfig.DAC_SampleAndHold = DAC_SAMPLEANDHOLD_DISABLE; sConfig.DAC_Trigger = DAC_TRIGGER_T2_TRGO; sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_DISABLE; sConfig.DAC_ConnectOnChipPeripheral = DAC_CHIPCONNECT_DISABLE; sConfig.DAC_UserTrimming = DAC_TRIMMING_FACTORY; if (HAL_DAC_ConfigChannel(&hdac1, &sConfig, DAC_CHANNEL_1) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } } void HAL_DAC_MspInit(DAC_HandleTypeDef* dacHandle) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(dacHandle-》Instance==DAC1) { /* DAC1 clock enable */ __HAL_RCC_DAC1_CLK_ENABLE(); __HAL_RCC_DMA2_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); /**DAC1 GPIO Configuration PA4 ------》 DAC1_OUT1 */ GPIO_InitStruct.Pin = GPIO_PIN_4; GPIO_InitStruct.Mode = GPIO_MODE_ANALOG; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* DAC1 DMA Init */ /* DAC_CH1 Init */ hdma_dac_ch1.Instance = DMA2_Channel4; hdma_dac_ch1.Init.Request = DMA_REQUEST_3; hdma_dac_ch1.Init.Direction = DMA_MEMORY_TO_PERIPH; hdma_dac_ch1.Init.PeriphInc = DMA_PINC_DISABLE; hdma_dac_ch1.Init.MemInc = DMA_MINC_ENABLE; hdma_dac_ch1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_dac_ch1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; hdma_dac_ch1.Init.Mode = DMA_CIRCULAR; hdma_dac_ch1.Init.Priority = DMA_PRIORITY_LOW; if (HAL_DMA_Init(&hdma_dac_ch1) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } __HAL_LINKDMA(dacHandle,DMA_Handle1,hdma_dac_ch1); /* DAC1 interrupt Init */ HAL_NVIC_SetPriority(TIM6_DAC_IRQn, 7, 0); HAL_NVIC_EnableIRQ(TIM6_DAC_IRQn); HAL_NVIC_SetPriority(DMA2_Channel4_IRQn, 7, 0); HAL_NVIC_EnableIRQ(DMA2_Channel4_IRQn); } } void TIM6_DAC_IRQHandler(void) { HAL_DAC_IRQHandler(&hdac1); } void DMA2_Channel4_IRQHandler(void) { HAL_DMA_IRQHandler(&hdma_dac_ch1); } Tim配置 播放音频频率为441000 /* TIM2 init function */ /* 44.1KHz */ void MX_TIM2_Init(void) { TIM_ClockConfigTypeDef sClockSourceConfig = {0}; TIM_MasterConfigTypeDef sMasterConfig = {0}; htim2.Instance = TIM2; htim2.Init.Prescaler = 2; htim2.Init.Period = 907-1; htim2.Init.CounterMode = TIM_COUNTERMODE_UP; htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE; if (HAL_TIM_Base_Init(&htim2) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK) { Error_Handler(__FILE__, __LINE__); } } 开始 #define AUDIO_SIZE 2048 uint8_t audio_data[AUDIO_SIZE*2] = {0}; void StartPlayer(void) { Player_StreamBuffer = xStreamBufferCreate(AUDIO_SIZE*10,AUDIO_SIZE); if(NULL == Player_StreamBuffer) Debug(“Player_StreamBuffer Create ERROR”); /* 获取音频长度 */ AudioLen = *(uint32_t *)ADDR_AUDIO_LEN_START; if ((AudioLen == 0xFFFFFFFF) || (AudioLen 》= E_FLASH_AUDIO_SIZE)) AudioLen = 1024*1024; MX_DAC1_Init(); MX_TIM2_Init(); HAL_TIM_Base_Start(&htim2); /* 左对齐的方式,取16位音频数据的高12位播放 */ HAL_DAC_Start_DMA(&hdac1, DAC_CHANNEL_1, (uint32_t *)audio_data, AUDIO_SIZE, DAC_ALIGN_12B_L); } 应用层数据流向 数据流 void HAL_DAC_ConvHalfCpltCallbackCh1(DAC_HandleTypeDef *hdac) { BaseType_t pxHigherPriorityTaskWoken = pdFALSE; static uint8_t silent = 0; if(xStreamBufferBytesAvailable(Player_StreamBuffer) 》= AUDIO_SIZE) { xStreamBufferReceiveFromISR(Player_StreamBuffer,audio_data,AUDIO_SIZE,&pxHigherPriorityTaskWoken); portYIELD_FROM_ISR(pxHigherPriorityTaskWoken); if(silent) { silent = 0; Debug(“Player Half Stream Be Recover rn”); } } else { if(!silent) { silent = 1; memset(audio_data,0,AUDIO_SIZE); Debug(“Player Half Stream Be Empty rn”); } } } void HAL_DAC_ConvCpltCallbackCh1(DAC_HandleTypeDef *hdac) { BaseType_t pxHigherPriorityTaskWoken = pdFALSE; static uint8_t silent = 0; if(xStreamBufferBytesAvailable(Player_StreamBuffer) 》= AUDIO_SIZE) { xStreamBufferReceiveFromISR(Player_StreamBuffer,(uint8_t*)(audio_data+AUDIO_SIZE),AUDIO_SIZE,&pxHigherPriorityTaskWoken); portYIELD_FROM_ISR(pxHigherPriorityTaskWoken); if(silent) { silent = 0; Debug(“Player Cplt Stream Be Recover rn”); } } else { if(!silent) { silent = 1; memset((uint8_t*)(audio_data+AUDIO_SIZE),0,AUDIO_SIZE); Debug(“Player Cplt Stream Be Empty rn”); } } } 获取音频 void GetAudioFormFlash(void) { size_t i; if(xStreamBufferSpacesAvailable(Player_StreamBuffer) 》= AUDIO_SIZE) { if (flash_addr 》 (E_FLASH_AUDIO_START_ADDR + AudioLen)) { /* 回到初始地址再次播放 */ flash_addr = E_FLASH_AUDIO_START_ADDR; } QSPI_ReadBuffer(audio_buffer, flash_addr, AUDIO_SIZE); xStreamBufferSend(Player_StreamBuffer,audio_buffer,AUDIO_SIZE,0); flash_addr += AUDIO_SIZE; } } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 20:38 , Processed in 2.840956 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
10755
