电子发烧友论坛|
1.中断介绍
cortex-m3支持256个中断,其中包含了16个内核中断,240个外部中断 stm32只有84个中断,包括16个内核中断和68个可屏蔽中断 stm32f103上只有60个可屏蔽中断,f107上才有68个中断 也可以在相应的startup_stm32f10x_hd.s 中查看中断向量表查看当前芯片的中断源数。 我当前看的这个一共是60个外部中断,也可以在参考手册查找Interrupt and exception vectors 有详细的对应寄存器地址。 __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ; External Interrupts DCD WWDG_IRQHandler ; Window Watchdog DCD PVD_IRQHandler ; PVD through EXTI Line detect DCD TAMPER_IRQHandler ; Tamper DCD RTC_IRQHandler ; RTC DCD FLASH_IRQHandler ; Flash DCD RCC_IRQHandler ; RCC DCD EXTI0_IRQHandler ; EXTI Line 0 DCD EXTI1_IRQHandler ; EXTI Line 1 DCD EXTI2_IRQHandler ; EXTI Line 2 DCD EXTI3_IRQHandler ; EXTI Line 3 DCD EXTI4_IRQHandler ; EXTI Line 4 DCD DMA1_Channel1_IRQHandler ; DMA1 Channel 1 DCD DMA1_Channel2_IRQHandler ; DMA1 Channel 2 DCD DMA1_Channel3_IRQHandler ; DMA1 Channel 3 DCD DMA1_Channel4_IRQHandler ; DMA1 Channel 4 DCD DMA1_Channel5_IRQHandler ; DMA1 Channel 5 DCD DMA1_Channel6_IRQHandler ; DMA1 Channel 6 DCD DMA1_Channel7_IRQHandler ; DMA1 Channel 7 DCD ADC1_2_IRQHandler ; ADC1 & ADC2 DCD USB_HP_CAN1_TX_IRQHandler ; USB High Priority or CAN1 TX DCD USB_LP_CAN1_RX0_IRQHandler ; USB Low Priority or CAN1 RX0 DCD CAN1_RX1_IRQHandler ; CAN1 RX1 DCD CAN1_SCE_IRQHandler ; CAN1 SCE DCD EXTI9_5_IRQHandler ; EXTI Line 9..5 DCD TIM1_BRK_IRQHandler ; TIM1 Break DCD TIM1_UP_IRQHandler ; TIM1 Update DCD TIM1_TRG_COM_IRQHandler ; TIM1 Trigger and Commutation DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare DCD TIM2_IRQHandler ; TIM2 DCD TIM3_IRQHandler ; TIM3 DCD TIM4_IRQHandler ; TIM4 DCD I2C1_EV_IRQHandler ; I2C1 Event DCD I2C1_ER_IRQHandler ; I2C1 Error DCD I2C2_EV_IRQHandler ; I2C2 Event DCD I2C2_ER_IRQHandler ; I2C2 Error DCD SPI1_IRQHandler ; SPI1 DCD SPI2_IRQHandler ; SPI2 DCD USART1_IRQHandler ; USART1 DCD USART2_IRQHandler ; USART2 DCD USART3_IRQHandler ; USART3 DCD EXTI15_10_IRQHandler ; EXTI Line 15..10 DCD RTCAlarm_IRQHandler ; RTC Alarm through EXTI Line DCD USBWakeUp_IRQHandler ; USB Wakeup from suspend DCD TIM8_BRK_IRQHandler ; TIM8 Break DCD TIM8_UP_IRQHandler ; TIM8 Update DCD TIM8_TRG_COM_IRQHandler ; TIM8 Trigger and Commutation DCD TIM8_CC_IRQHandler ; TIM8 Capture Compare DCD ADC3_IRQHandler ; ADC3 DCD FSMC_IRQHandler ; FSMC DCD SDIO_IRQHandler ; SDIO DCD TIM5_IRQHandler ; TIM5 DCD SPI3_IRQHandler ; SPI3 DCD UART4_IRQHandler ; UART4 DCD UART5_IRQHandler ; UART5 DCD TIM6_IRQHandler ; TIM6 DCD TIM7_IRQHandler ; TIM7 DCD DMA2_Channel1_IRQHandler ; DMA2 Channel1 DCD DMA2_Channel2_IRQHandler ; DMA2 Channel2 DCD DMA2_Channel3_IRQHandler ; DMA2 Channel3 DCD DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5 __Vectors_End 2.中断管理 - 中断优先级 STM32将中断分成5个组,分别为0-4组;同时对每个中断设置一个抢占优先级和响应优先级,有人把响应优先级称作‘亚优先级’或‘副优先级’,每个中断源都需要被指定这两种优先级。 在实际应用中一定要注意有时候由于中断优先级设置不合理会导致程序“截胡“。 1.抢占优先级。抢占优先级高的中断,可以打断抢占优先级低的中断。 2.响应优先级。抢占优先级相同的中断,响应优先级高的可以优先执行。 高优先级的抢占优先级是可以打断正在进行的低抢占优先级中断的。 抢占优先级相同的中断,高响应优先级不可以打断低响应优先级的中断。 抢占优先级相同的中断,当两个中断同时发生的情况下,哪个响应优先级高,哪个先执行。 如果两个中断的抢占优先级和响应优先级都是一样的话,则看哪个中断先发生就先执行; 假定设置中断优先级组为2,然后设置 中断3(RTC中断)的抢占优先级为2,响应优先级为1。 中断6(外部中断0)的抢占优先级为3,响应优先级为0。中断7(外部中断1)的抢占优先级为2,响应优先级为0。 那么这3个中断的优先级顺序为:中断7》中断3》中断6。 3.中断管理 - 中断分组 分组配置是由SCB-》AIRCR寄存器的bit10-8来定义的。SCB-》AIRCR是CM3内核定义的。其中AIRCR寄存器来确定是用哪种分组,IP寄存器是相对应于那种分组抢占优先级和响应优先级的分配比例。例如组设置成2,那么此时所有的60个中断优先寄存器高4位中的最高2位是抢占优先级,低2位为响应优先级。Cortex-M3中定义了8个Bit用于设置中断源的优先级,而STM32只选用其中的最高4个Bit。 在STM32中把这些中断分为5组,如下 /*misc.h*/ #define NVIC_PriorityGroup_0 ((uint32_t)0x700) /*!《 0 bits for pre-emption priority 4 bits for subpriority */ #define NVIC_PriorityGroup_1 ((uint32_t)0x600) /*!《 1 bits for pre-emption priority 3 bits for subpriority */ #define NVIC_PriorityGroup_2 ((uint32_t)0x500) /*!《 2 bits for pre-emption priority 2 bits for subpriority */ #define NVIC_PriorityGroup_3 ((uint32_t)0x400) /*!《 3 bits for pre-emption priority 1 bits for subpriority */ #define NVIC_PriorityGroup_4 ((uint32_t)0x300) /*!《 4 bits for pre-emption priority 0 bits for subpriority */ The table below gives the allowed values of the pre-emption priority and subpriority according to the Priority Grouping configuration performed by NVIC_PriorityGroupConfig function ============================================================================================================================ NVIC_PriorityGroup | NVIC_IRQChannelPreemptionPriority | NVIC_IRQChannelSubPriority | Description ============================================================================================================================ NVIC_PriorityGroup_0 | 0 | 0-15 | 0 bits for pre-emption priority | | | 4 bits for subpriority ---------------------------------------------------------------------------------------------------------------------------- NVIC_PriorityGroup_1 | 0-1 | 0-7 | 1 bits for pre-emption priority | | | 3 bits for subpriority ---------------------------------------------------------------------------------------------------------------------------- NVIC_PriorityGroup_2 | 0-3 | 0-3 | 2 bits for pre-emption priority | | | 2 bits for subpriority ---------------------------------------------------------------------------------------------------------------------------- NVIC_PriorityGroup_3 | 0-7 | 0-1 | 3 bits for pre-emption priority | | | 1 bits for subpriority ---------------------------------------------------------------------------------------------------------------------------- NVIC_PriorityGroup_4 | 0-15 | 0 | 4 bits for pre-emption priority | | | 0 bits for subpriority ============================================================================================================================ 4.库函数中断寄存器 在Keil中 core_cm3.h 这个NVIC_Type中控制着中断向量表中60个中断 typedef struct { __IO uint32_t ISER[8]; /*!《 Offset: 0x000 Interrupt Set Enable Register 只用了ISER[0]和ISER[1] */ uint32_t RESERVED0[24]; __IO uint32_t ICER[8]; /*!《 Offset: 0x080 Interrupt Clear Enable Register */ uint32_t RSERVED1[24]; __IO uint32_t ISPR[8]; /*!《 Offset: 0x100 Interrupt Set Pending Register中断挂起控制寄存器。通过置1可以将正在进行的中断挂起,执行同级或者更高级别的中断。写0无效。*/ uint32_t RESERVED2[24]; __IO uint32_t ICPR[8]; /*!《 Offset: 0x180 Interrupt Clear Pending Register中断解挂控制寄存器。通过置1可以将正在挂起的中断解挂。写0无效*/ uint32_t RESERVED3[24]; __IO uint32_t IABR[8]; /*!《 Offset: 0x200 Interrupt Active bit Register 这是一个只读寄存器,可以知道当前在执行的中断是哪一个(为1),在中断执行完后硬件自动清零。*/ uint32_t RESERVED4[56]; __IO uint8_t IP[240]; /*!《 Offset: 0x300 Interrupt Priority Register (8Bit wide) 中断优先级控制的寄存器。这是用来控制每个中断的优先级。由于CM3由240个外部中断,每个中断由一个8位寄存器控制,但是STM32F10x系列一共60个可屏蔽中断, 所以只使用了IP[59]~IP[0]。其中每个IP寄存器的高4位[7:4]用来设置抢占和响应优先级(根据分组),低4位没有用到。而两个优先级各占几个位又要由上面讲到的中断优先级分组决定。 */ uint32_t RESERVED5[644]; __O uint32_t STIR; /*!《 Offset: 0xE00 Software Trigger Interrupt Register */ } NVIC_Type; typedef struct { __I uint32_t CPUID; /*!《 Offset: 0x00 CPU ID Base Register */ __IO uint32_t ICSR; /*!《 Offset: 0x04 Interrupt Control State Register */ __IO uint32_t VTOR; /*!《 Offset: 0x08 Vector Table Offset Register */ __IO uint32_t AIRCR; /*!《 Offset: 0x0C Application Interrupt / Reset Control Register */ __IO uint32_t SCR; /*!《 Offset: 0x10 System Control Register */ __IO uint32_t CCR; /*!《 Offset: 0x14 Configuration Control Register */ __IO uint8_t SHP[12]; /*!《 Offset: 0x18 System Handlers Priority Registers (4-7, 8-11, 12-15) */ __IO uint32_t SHCSR; /*!《 Offset: 0x24 System Handler Control and State Register */ __IO uint32_t CFSR; /*!《 Offset: 0x28 Configurable Fault Status Register */ __IO uint32_t HFSR; /*!《 Offset: 0x2C Hard Fault Status Register */ __IO uint32_t DFSR; /*!《 Offset: 0x30 Debug Fault Status Register */ __IO uint32_t MMFAR; /*!《 Offset: 0x34 Mem Manage Address Register */ __IO uint32_t BFAR; /*!《 Offset: 0x38 Bus Fault Address Register */ __IO uint32_t AFSR; /*!《 Offset: 0x3C Auxiliary Fault Status Register */ __I uint32_t PFR[2]; /*!《 Offset: 0x40 Processor Feature Register */ __I uint32_t DFR; /*!《 Offset: 0x48 Debug Feature Register */ __I uint32_t ADR; /*!《 Offset: 0x4C Auxiliary Feature Register */ __I uint32_t MMFR[4]; /*!《 Offset: 0x50 Memory Model Feature Register */ __I uint32_t ISAR[5]; /*!《 Offset: 0x60 ISA Feature Register */ } SCB_Type; 5.具体应用中断初始化 中断优先级设置 一般情况下,系统代码执行过程中,只设置一次中断优先级分组。 设置中断优先级分组为组2:2位抢占优先级,2位响应优先级 5.1中断分组设置 /*函数调用*/ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); /*库函数源码*/ void NVIC_PriorityGroupConfig(uint32_t NVIC_PriorityGroup) { /* Check the parameters */ assert_param(IS_NVIC_PRIORITY_GROUP(NVIC_PriorityGroup)); /* Set the PRIGROUP[10:8] bits according to NVIC_PriorityGroup value */ SCB-》AIRCR = AIRCR_VECTKEY_MASK | NVIC_PriorityGroup; } 5.2中断优先级设置 /*函数调用*/ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 /*库函数源码*/ void NVIC_Init(NVIC_InitTypeDef* NVIC_InitStruct) { uint32_t tmppriority = 0x00, tmppre = 0x00, tmpsub = 0x0F; /* Check the parameters */ assert_param(IS_FUNCTIONAL_STATE(NVIC_InitStruct-》NVIC_IRQChannelCmd)); assert_param(IS_NVIC_PREEMPTION_PRIORITY(NVIC_InitStruct-》NVIC_IRQChannelPreemptionPriority)); assert_param(IS_NVIC_SUB_PRIORITY(NVIC_InitStruct-》NVIC_IRQChannelSubPriority)); if (NVIC_InitStruct-》NVIC_IRQChannelCmd != DISABLE) { /* Compute the Corresponding IRQ Priority --------------------------------*/ tmppriority = (0x700 - ((SCB-》AIRCR) & (uint32_t)0x700))》》 0x08; tmppre = (0x4 - tmppriority); tmpsub = tmpsub 》》 tmppriority; tmppriority = (uint32_t)NVIC_InitStruct-》NVIC_IRQChannelPreemptionPriority 《《 tmppre; tmppriority |= NVIC_InitStruct-》NVIC_IRQChannelSubPriority & tmpsub; tmppriority = tmppriority 《《 0x04; NVIC-》IP[NVIC_InitStruct-》NVIC_IRQChannel] = tmppriority; /* Enable the Selected IRQ Channels --------------------------------------*/ NVIC-》ISER[NVIC_InitStruct-》NVIC_IRQChannel 》》 0x05] = (uint32_t)0x01 《《 (NVIC_InitStruct-》NVIC_IRQChannel & (uint8_t)0x1F); } else { /* Disable the Selected IRQ Channels -------------------------------------*/ NVIC-》ICER[NVIC_InitStruct-》NVIC_IRQChannel 》》 0x05] = (uint32_t)0x01 《《 (NVIC_InitStruct-》NVIC_IRQChannel & (uint8_t)0x1F); } } 6.中断嵌套 具有高抢占式优先级的中断可以在具有低抢占式优先级的中断处理过程中被响应,这样就形成了低优先级中断中嵌套着高优先级中断,当高优先级中断来的时候可以打断正在运行的低优先级中断。 当两个中断源的抢占式优先级相同时,这两个中断将没有嵌套关系,当一个中断到来后,如果正在处理另一个中断,这个后到来的中断就要等到前一个中断处理完之后才能被处理。如果这两个中断同时到达,则中断控制器根据他们的响应优先级高低来决定先处理哪一个;如果他们的抢占式优先级和响应优先级都相等,则根据他们在中断表中的排位顺序决定先处理哪一个。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 22:37 , Processed in 0.853923 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2665
