电子发烧友论坛|
修改SetSysClock()函数,将时钟源由默认的HSE改为内部HSI时钟
system_stm32f0xx.c static void SetSysClock(void) { __IO uint32_t StartUpCounter = 0, HSIStatus = 0; /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/ /* Enable HSI */ RCC-》CR |= ((uint32_t)RCC_CR_HSION);//((uint32_t)RCC_CR_HSEON) /* Wait till HSI is ready and if Time out is reached exit */ do { HSIStatus = RCC-》CR & RCC_CR_HSIRDY;//RCC-》CR & RCC_CR_HSERDY; StartUpCounter++; } while((HSIStatus == 0) && (StartUpCounter != HSI_STARTUP_TIMEOUT)); if ((RCC-》CR & RCC_CR_HSIRDY) != RESET)//((RCC-》CR & RCC_CR_HSERDY) != RESET { HSIStatus = (uint32_t)0x01; } else { HSIStatus = (uint32_t)0x00; } if (HSIStatus == (uint32_t)0x01) { /* Enable Prefetch Buffer and set Flash Latency */ FLASH-》ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY; /* HCLK = SYSCLK */ RCC-》CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1; /* PCLK = HCLK */ RCC-》CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1; /* PLL configuration = HSE * 6 = 48 MHz */ /* PLL configuration = HSI/2 * 12 = 48 MHz */ RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL)); RCC-》CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_DIV2| RCC_CFGR_PLLMULL12); // RCC-》CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6) /* Enable PLL */ RCC-》CR |= RCC_CR_PLLON; /* Wait till PLL is ready */ while((RCC-》CR & RCC_CR_PLLRDY) == 0) { } /* Select PLL as system clock source */ RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC-》CFGR |= (uint32_t)RCC_CFGR_SW_PLL; /* Wait till PLL is used as system clock source */ while ((RCC-》CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL) { } } else { /* If HSI fails to start-up, the application will have wrong clock configuration. User can add here some code to deal with this error */ } } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4145 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3230 浏览 1 评论
2756 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2185 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14998 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3092浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1898浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2070浏览 3评论
1981浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2172浏览 3评论
/9
GMT+8, 2025-12-3 13:20 , Processed in 0.807621 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2845
