本篇主要任务:
接电机 可控制调整电机旋转方向 解决初始化时处理问题(每次启动时可获取的) 任务一:接电机 电机控制芯片:L298N(淘宝购) 电机供电:9V电池(淘宝购电池盒) 电机焊接电线定义如下 注:电机正负不知道怎么测,所以正负极先统一这么接根据控制调整接入L298N的OUT口就可以改变电机转动方向。 接线完成图 注:PS2无线手柄接收器同时还有一个带插针的,之前的那个准备 任务二+任务三(做) 附上代码: #include 《PS2X_lib.h》 PS2X ps2x; //right now, the library does NOT support hot-pluggable controllers, meaning //you must always either restart your Arduino after you connect the controller, //or call config_gamepad(pins) again after connecting the controller. int error = 0; byte type = 0; byte vibrate = 0; int count = 10; // 电机控制引脚; #define IN1 4 #define IN2 5 #define IN3 6 #define IN4 7 void setup(){ //初始化针脚 pinMode(IN1, OUTPUT); pinMode(IN2, OUTPUT); pinMode(IN3, OUTPUT); pinMode(IN4, OUTPUT); Serial.begin(57600); while(count 》 0){ count--; error = ps2x.config_gamepad(13,11,10,12, true, true); //GamePad(clock, command, attention, data, Pressures?, Rumble?) if(error == 0){ Serial.println(“Found Controller, configured successful”); Serial.println(“Try out all the buttons, X will vibrate the controller, faster as you press harder;”); Serial.println(“holding L1 or R1 will print out the analog stick values.”); Serial.println(“Go to www.billporter.info for updates and to report bugs.”); break; } else if(error == 1) Serial.println(“No controller found, check wiring, see readme.txt to enable debug. visit www.billporter.info for troubleshooting tips”); else if(error == 2) Serial.println(“Controller found but not accepting commands. see readme.txt to enable debug. Visit www.billporter.info for troubleshooting tips”); else if(error == 3) Serial.println(“Controller refusing to enter Pressures mode, may not support it. ”); delay(100); } type = ps2x.readType(); switch(type) { case 0: Serial.println(“Unknown Controller type”); break; case 1: Serial.println(“DualShock Controller Found”); break; case 2: Serial.println(“GuitarHero Controller Found”); break; } } void loop(){ /* You must Read Gamepad to get new values Read GamePad and set vibration values ps2x.read_gamepad(small motor on/off, larger motor strenght from 0-255) if you don‘t enable the rumble, use ps2x.read_gamepad(); with no values you should call this at least once a second */ if(error == 1) return; if(type == 2){ ps2x.read_gamepad(); //read controller if(ps2x.ButtonPressed(GREEN_FRET)) Serial.println(“Green Fret Pressed”); if(ps2x.ButtonPressed(RED_FRET)) Serial.println(“Red Fret Pressed”); if(ps2x.ButtonPressed(YELLOW_FRET)) Serial.println(“Yellow Fret Pressed”); if(ps2x.ButtonPressed(BLUE_FRET)) Serial.println(“Blue Fret Pressed”); if(ps2x.ButtonPressed(ORANGE_FRET)) Serial.println(“Orange Fret Pressed”); if(ps2x.ButtonPressed(STAR_POWER)) Serial.println(“Star Power Command”); if(ps2x.Button(UP_STRUM)) //will be TRUE as long as button is pressed Serial.println(“Up Strum”); if(ps2x.Button(DOWN_STRUM)) Serial.println(“DOWN Strum”); if(ps2x.Button(PSB_START)) //will be TRUE as long as button is pressed Serial.println(“Start is being held”); if(ps2x.Button(PSB_SELECT)) Serial.println(“Select is being held”); if(ps2x.Button(ORANGE_FRET)) // print stick value IF TRUE { Serial.print(“Wammy Bar Position:”); Serial.println(ps2x.Analog(WHAMMY_BAR), DEC); } } else { //DualShock Controller ps2x.read_gamepad(false, vibrate); //read controller and set large motor to spin at ’vibrate‘ speed if(ps2x.Button(PSB_START)) //will be TRUE as long as button is pressed Serial.println(“Start is being held”); if(ps2x.Button(PSB_SELECT)) Serial.println(“Select is being held”); if (ps2x.Button(PSB_START)){ //will be TRUE as long as button is pressed Serial.println(“Start is being held”); } else if (ps2x.Button(PSB_SELECT)){ Serial.println(“Select is being held”); } else if(ps2x.Button(PSB_PAD_UP)) { //will be TRUE as long as button is pressed Serial.print(“Up held this hard: ”); Serial.println(ps2x.Analog(PSAB_PAD_UP), DEC); //电机控制 Serial.print(“---------前进 ”); digitalWrite(IN1, LOW); digitalWrite(IN2, HIGH); digitalWrite(IN3, HIGH); digitalWrite(IN4, LOW); } else if(ps2x.Button(PSB_PAD_RIGHT)){ Serial.print(“Right held this hard: ”); Serial.println(ps2x.Analog(PSAB_PAD_RIGHT), DEC); Serial.print(“---------右转 ”); digitalWrite(IN1, LOW); digitalWrite(IN2, HIGH); digitalWrite(IN3, LOW); digitalWrite(IN4, HIGH); } else if(ps2x.Button(PSB_PAD_LEFT)){ Serial.print(“LEFT held this hard: ”); Serial.println(ps2x.Analog(PSAB_PAD_LEFT), DEC); Serial.print(“---------左转 ”); digitalWrite(IN1, HIGH); digitalWrite(IN2, LOW); digitalWrite(IN3, HIGH); digitalWrite(IN4, LOW); } else if(ps2x.Button(PSB_PAD_DOWN)){ Serial.print(“DOWN held this hard: ”); Serial.println(ps2x.Analog(PSAB_PAD_DOWN), DEC); Serial.print(“---------后退 ”); digitalWrite(IN1, HIGH); digitalWrite(IN2, LOW); digitalWrite(IN3, LOW); digitalWrite(IN4, HIGH); } else if(ps2x.Button(PSB_SELECT)){ // SELECT digitalWrite(IN1, LOW); //停 digitalWrite(IN2, LOW); digitalWrite(IN3, LOW); digitalWrite(IN4, LOW); }else{ // 没有任何操作,停止电机转动 digitalWrite(IN1, LOW); //停 digitalWrite(IN2, LOW); digitalWrite(IN3, LOW); digitalWrite(IN4, LOW); } vibrate = ps2x.Analog(PSAB_BLUE); //this will set the large motor vibrate speed based on //how hard you press the blue (X) button if (ps2x.NewButtonState()) //will be TRUE if any button changes state (on to off, or off to on) { if(ps2x.Button(PSB_L3)) Serial.println(“L3 pressed”); if(ps2x.Button(PSB_R3)) Serial.println(“R3 pressed”); if(ps2x.Button(PSB_L2)) Serial.println(“L2 pressed”); if(ps2x.Button(PSB_R2)) Serial.println(“R2 pressed”); if(ps2x.Button(PSB_GREEN)) Serial.println(“Triangle pressed”); } if(ps2x.ButtonPressed(PSB_RED)) //will be TRUE if button was JUST pressed Serial.println(“Circle just pressed”); if(ps2x.ButtonReleased(PSB_PINK)) //will be TRUE if button was JUST released Serial.println(“Square just released”); if(ps2x.NewButtonState(PSB_BLUE)) //will be TRUE if button was JUST pressed OR released Serial.println(“X just changed”); if(ps2x.Button(PSB_L1) || ps2x.Button(PSB_R1)) // print stick values if either is TRUE { Serial.print(“Stick Values:”); Serial.print(ps2x.Analog(PSS_LY), DEC); //Left stick, Y axis. Other options: LX, RY, RX Serial.print(“,”); Serial.print(ps2x.Analog(PSS_LX), DEC); Serial.print(“,”); Serial.print(ps2x.Analog(PSS_RY), DEC); Serial.print(“,”); Serial.println(ps2x.Analog(PSS_RX), DEC); } } delay(50); } 因为不是每次启动初始化的时候都可以检测到手柄,所以加了一次设置,10次,尝试10次,就找不到了手动重启!**** 手动重启!**** 手动重启!。作者尝试了自己无法完成的问题。计数值。查找手柄程序会跳出查找手柄操作的,继续执行停止的代码。 注。调整电机控制:按本文中的接线方式应该不需要调整。如果是乱走的话,则需要轮子的方向调整电机与298N的接线。 |
只有小组成员才能发言,加入小组>>
2070 浏览 0 评论
7624 浏览 4 评论
35243 浏览 18 评论
4663 浏览 0 评论
22693 浏览 34 评论
745浏览 2评论
994浏览 1评论
1101浏览 1评论
3506浏览 0评论
877浏览 0评论
GMT+8, 2024-6-26 20:26 , Processed in 1.035528 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
