1个回答
16.1时钟树的讲解
时钟相当于人的心脏 所有的外设想要工作都得配置时钟 无源晶振 配置起振电容 时钟起振需要一定时间,所以需要就绪标志HSERDY 易受温度影响 HSE的备胎 一般配置PLLSRC为1,PLLXTPRE为0 一般配置SW为10,SWS为10 具体使用时先配置AHB和桥接的APB1、APB2的时钟,外设的时钟具体使用时再配置 实时时钟 LSLRC提高的时钟容易受温度影响 LSE由外部时钟提供给RTC 看门狗由LSI提供 可通过示波器检测输出的引脚对不对 系统时钟必须要会 16.2系统时钟配置函数SetSysClockTo72() 代码讲解 static void SetSysClockTo72(void) { __IO uint32_t StartUpCounter = 0, HSEStatus = 0; //配置系统和总线时钟 /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/ /* Enable HSE */ RCC->CR |= ((uint32_t)RCC_CR_HSEON); /* Wait till HSE is ready and if Time out is reached exit */ do { HSEStatus = RCC->CR & RCC_CR_HSERDY; StartUpCounter++; } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT)); if ((RCC->CR & RCC_CR_HSERDY) != RESET) { HSEStatus = (uint32_t)0x01; } else { HSEStatus = (uint32_t)0x00; } //如果HSE启动成功,程序继续往下 if (HSEStatus == (uint32_t)0x01) { /* Enable Prefetch Buffer */ //使能预取指 FLASH->ACR |= FLASH_ACR_PRFTBE; /* Flash 2 wait state */ //取指等待周期 时钟频率越快等待时间越长 FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY); FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2; /* HCLK = SYSCLK = 72M*/ RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1; /* PCLK2 = HCLK = 72M*/ RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1; /* PCLK1 = HCLK = 36M*/ RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2; #ifdef STM32F10X_CL //互联型 /* Configure PLLs ------------------------------------------------------*/ /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */ /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */ RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL | RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC); RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 | RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5); /* Enable PLL2 */ RCC->CR |= RCC_CR_PLL2ON; /* Wait till PLL2 is ready */ while((RCC->CR & RCC_CR_PLL2RDY) == 0) { } /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */ RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL); RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLMULL9); #else //锁相环配置 /* PLL configuration: PLLCLK = HSE * 9 = 72 MHz */ RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL)); //HSR*9 = 72M 最高可配置16 RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9); #endif /* STM32F10X_CL */ /* Enable PLL */ RCC->CR |= RCC_CR_PLLON; /* Wait till PLL is ready */ while((RCC->CR & RCC_CR_PLLRDY) == 0) { } /* Select PLL as system clock source */ RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL; /* Wait till PLL is used as system clock source */ while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08) { } } else { /* If HSE fails to start-up, the application will have wrong clock configuration. User can add here some code to deal with this error */ //如果HSE启动失败,用户可以在这里添加出来错误的代码 } } #endif 16.3使用HSE配置系统时钟并且使用MCO输出监控系统时钟 注意PA8的复用 MCO bsp_rccclkconfig.c #include "bsp_rccclkconfig.h" void HSE_SetSysClk(uint32_t RCC_PLLMul_x) { ErrorStatus HSEStatus; //把RCC 寄存器复位成复位值 RCC_DeInit(); //配置 RCC_HSEConfig(RCC_HSE_ON); //等待 HSEStatus = RCC_WaitForHSEStartUp(); if(HSEStatus == SUCCESS) { //使能预处理 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //FLASH两个等待 FLASH_SetLatency(FLASH_Latency_2); //分频 RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_PCLK2Config(RCC_HCLK_Div1); //锁相环配置 PLLCLK = HSK * RCC_PLLMul_x RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_x); //超频 //使能PLL RCC_PLLCmd(ENABLE); //等待PLL稳定 while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //选择系统时钟 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); // while(RCC_GetSYSCLKSource() != 0x08); } else { //如果HSE 启动失败,用户可以在这里添加处理错误的代码 } } void MCO_GPIO_Config() { GPIO_InitTypeDef GPIO_InitStruct; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStruct); } main.c #include "stm32f10x.h" #include "bsp_led.h" #include "bsp_rccclkconfig.h" void Delay(uint32_t count) { for(;count!=0; count--); } int main() { //来到这个系统时钟被配置成72M HSE_SetSysClk(RCC_PLLMul_16); MCO_GPIO_Config(); RCC_MCOConfig(RCC_MCO_SYSCLK); LED_GPIO_Config(); while(1) { LED_R(OFF); //GPIO_SetBits(LED_G_GPIO_PORT, LED_G_GPIO_PIN); Delay(0xFFFFF); //GPIO_ResetBits(LED_G_GPIO_PORT, LED_G_GPIO_PIN); LED_R(ON); Delay(0xFFFFF); } } 16.4使用HSI配置系统时钟并用MCO监控系统时钟 没有太大意义 配置64MHz #include "bsp_rccclkconfig.h" void HSI_SetSysClk(uint32_t RCC_PLLMul_x) { // __IO 防止编译器优化 volatile 的作用就是指示编译器不要因优化而省略此指令,必须每次都直接读写其值 __IO uint32_t HSIStatus = 0; //把RCC 寄存器复位成复位值 RCC_DeInit(); //使能 HSI RCC_HSICmd(ENABLE); //等待 HSIStatus = RCC->CR & RCC_CR_HSIRDY; if(HSIStatus == RCC_CR_HSIRDY) { //使能预处理 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //FLASH两个等待 FLASH_SetLatency(FLASH_Latency_2); //分频 RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_PCLK2Config(RCC_HCLK_Div1); //锁相环配置 PLLCLK = HSK * RCC_PLLMul_x RCC_PLLConfig(RCC_PLLSource_HSE_Div2,RCC_PLLMul_x); //超频 //使能PLL RCC_PLLCmd(ENABLE); //等待PLL稳定 while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //选择系统时钟 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); // while(RCC_GetSYSCLKSource() != 0x08); } else { //如果HSI 启动失败,用户可以在这里添加处理错误的代码 } } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1977浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2166浏览 3评论
/9
GMT+8, 2025-12-2 06:40 , Processed in 1.276461 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4020
