Unified Constant-Frequency Integration Control of Three-Phase Standard Bridge Boost Rectifiers With Power-Factor Correction
Abstract—In this paper, a three-phase six-switch standard boost rectifier with unity-power-factor correction is investi- gated. A general equation is derived that relates the input phase voltages, output dc voltage, and duty ratios of the switches in continuous conduction mode. Based on one of the solutions and using one-cycle control, a unified constant-frequency integration controller for PFC is proposed. For the standard bridge boost rectifier, a unity power factor and low total hARMonic distortion canberealizedinallthreephaseswithasimplecircuitthatiscom- posed of one integrator with reset along with several flips-flops, comparators, and some logic and linear components. It does not require multipliers and three-phase voltage sensors, which are requiredinmanyothercontrolapproaches.Inaddition,itemploys constant-switching-frequency modulation that is desirable for industrial applications. The proposed control approach is simple and reliable. All findings are supported by experiments. Index Terms—One-cycle control, power-factor correction (PFC), power quality control, three-phase rectifier.
1176560502.pdf
(529.8 KB, 下载次数: 2
只有小组成员才能发言,加入小组>>
5223个成员聚集在这个小组
加入小组17626.6标准中关于CDN的疑问?以及实际钳注入测试中是否需要对AE和EUT同时接CDN?
7609 浏览 1 评论
4350 浏览 2 评论
11230 浏览 1 评论
4594 浏览 4 评论
4170 浏览 0 评论
1320浏览 0评论
2509浏览 0评论
/9
GMT+8, 2025-12-3 12:59 , Processed in 0.622591 second(s), Total 73, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
