-----[Print the board config pathname(s)]------------------------------------ C:UsersCanAppDataLocalTEXASI~1CCS This utility will load the adapter 'jioserdesu***.dll'. The library build time was '02:44:08'. The library component version is '35.35.0.0'. The controller has a version number of '4' (0x00000004). This utility will attempt to reset the controller. The controller is the FTDI FT2232 with USB interface. The software is configured for FTDI FT2232 features. The controller cannot monitor the value on the EMU[1] pin. The controller cannot control the timing on input pins. The title is 'SC_ERR_FTDI_FAIL'. The explanation is: configuration returned a invalid status or an error. [End: Texas Instruments XDS100v1 USB Debug Probe_0] 重新连接了好几次也还是出现这个错误,请问一下是什么原因啊? |
1个回答
刚看了一下 上面的不是完整的
[Start: Texas Instruments XDS100v1 USB Debug Probe_0] Execute the command: %ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathname(s)]------------------------------------ C:UsersCanAppDataLocalTEXASI~1CCS ti BrdDattestBoard.dat -----[Print the reset-command software log-file]----------------------------- This utility has selected a 100- or 510-class product. This utility will load the adapter 'jioserdesu***.dll'. The library build date was 'Apr 8 2016'. The library build time was '02:44:08'. The library package version is '6.0.222.0'. The library component version is '35.35.0.0'. The controller does not use a programmable FPGA. The controller has a version number of '4' (0x00000004). The controller has an insertion length of '0' (0x00000000). This utility will attempt to reset the controller. This utility has successfully reset the controller. -----[Print the reset-command hardware log-file]----------------------------- The scan-path will be reset by toggling the JTAG TRST signal. The controller is the FTDI FT2232 with USB interface. The link from controller to target is direct (without cable). The software is configured for FTDI FT2232 features. The controller cannot monitor the value on the EMU[0] pin. The controller cannot monitor the value on the EMU[1] pin. The controller cannot control the timing on output pins. The controller cannot control the timing on input pins. The scan-path link-delay has been set to exactly '0' (0x0000). An error occurred while hard opening the controller. -----[An error has occurred and this utility has aborted]-------------------- This error is generated by TI's USCIF driver or utilities. The value is '-150' (0xffffff6a). The title is 'SC_ERR_FTDI_FAIL'. The explanation is: One of the FTDI driver functions used during configuration returned a invalid status or an error. [End: Texas Instruments XDS100v1 USB Debug Probe_0] |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
TMS320C6748 板卡设计中是否一定需要有SDRAM或者DDR
1958 浏览 0 评论
988 浏览 0 评论
3654 浏览 1 评论
【六岳微LY-F335开发板试用体验】epwm启动ADC并在OLED上显示结果
4493 浏览 0 评论
【六岳微LY-F335开发板试用体验】软件开发环境及调试下载
4541 浏览 0 评论
/9
GMT+8, 2025-12-2 03:26 , Processed in 0.622110 second(s), Total 77, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7918
