电子发烧友论坛|
在LM3S9B96的驱动函数库文件sound.c中,中断处理函数:
void SoundIntHandler(void) [ unsigned long ulStatus; unsigned long *pulTemp; // // Get the interrupt status and clear any pending interrupts. // ulStatus = ROM_I2SIntStatus(I2S0_BASE, 1); // // Clear out any interrupts. // ROM_I2SIntClear(I2S0_BASE, ulStatus); // // Handle the RX channel interrupt // if(HWREGBITW(&g_ulDMAFlags, FLAG_RX_PENDING)) [ // // If the RX DMA is done, then start another one using the same // RX buffer. This keeps the RX running continuously. // if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_PRI_SELECT) == UDMA_MODE_STOP) [ // // Save a temp pointer so that the current pointer can be set to // zero before calling the callback. // pulTemp = g_sInBuffers[0].pulData; // // If at the mid point the refill the first half of the buffer. // if(g_sInBuffers[0].pfnBufferCallback) [ g_sInBuffers[0].pulData = 0; g_sInBuffers[0].pfnBufferCallback(pulTemp, BUFFER_EVENT_FULL); ] ] else if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_ALT_SELECT) == UDMA_MODE_STOP) [ // // Save a temp pointer so that the current pointer can be set to // zero before calling the callback. // pulTemp = g_sInBuffers[1].pulData; // // If at the mid point the refill the first half of the buffer. // if(g_sInBuffers[1].pfnBufferCallback) [ g_sInBuffers[1].pulData = 0; g_sInBuffers[1].pfnBufferCallback(pulTemp, BUFFER_EVENT_FULL); ] ] // // If there are no more scheduled buffers then there are no more // pending DMA transfers. // if((g_sInBuffers[0].pulData == 0) && (g_sInBuffers[1].pulData == 0)) [ HWREGBITW(&g_ulDMAFlags, FLAG_RX_PENDING) = 0; ] ] // // Handle the TX channel interrupt // if(HWREGBITW(&g_ulDMAFlags, FLAG_TX_PENDING)) [ // // If the TX DMA is done, then call the callback if present. // if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0TX | UDMA_PRI_SELECT) == UDMA_MODE_STOP) [ // // Save a temp pointer so that the current pointer can be set to // zero before calling the callback. // pulTemp = g_sOutBuffers[0].pulData; // // If at the mid point then refill the first half of the buffer. // if((g_sOutBuffers[0].pfnBufferCallback) && (g_sOutBuffers[0].pulData != 0)) [ g_sOutBuffers[0].pulData = 0; g_sOutBuffers[0].pfnBufferCallback(pulTemp, BUFFER_EVENT_FREE); ] ] // // If the TX DMA is done, then call the callback if present. // if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0TX | UDMA_ALT_SELECT) == UDMA_MODE_STOP) [ // // Save a temporary pointer so that the current pointer can be set // to zero before calling the callback. // pulTemp = g_sOutBuffers[1].pulData; // // If at the mid point then refill the first half of the buffer. // if((g_sOutBuffers[1].pfnBufferCallback) && (g_sOutBuffers[1].pulData != 0)) [ g_sOutBuffers[1].pulData = 0; g_sOutBuffers[1].pfnBufferCallback(pulTemp, BUFFER_EVENT_FREE); ] ] // // If no more buffers are pending then clear the flag. // if((g_sOutBuffers[0].pulData == 0) && (g_sOutBuffers[1].pulData == 0)) [ HWREGBITW(&g_ulDMAFlags, FLAG_TX_PENDING) = 0; ] ] ] 在系统启动后,只启动录音时,中断服务程序只执行 if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_PRI_SELECT) == UDMA_MODE_STOP) [... ......] 中的内容,而在启动语音播放后,录音部分的 if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_PRI_SELECT) == UDMA_MODE_STOP)[ .... ] 和else if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_ALT_SELECT) == UDMA_MODE_STOP)[ .... ]才会交替被执行,这事问什么? 另外为什么录音的2个中断处理的if语句之间使用else语句,而播放的 if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0TX | UDMA_PRI_SELECT) == UDMA_MODE_STOP) [ ... ] 和 if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0TX | UDMA_ALT_SELECT) == UDMA_MODE_STOP) [ ... ]之间不需要使用else语句? |
1 个讨论
原因找到了:开始在录音开始时首次调用的函数SoundBufferRead()中,设置了HWREGBITW(&g_ulDMAFlags, FLAG_RX_PENDING) = 1;首次产生的中断也是I2S主接收通道的中断,及执行中断服务程序中的if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_PRI_SELECT) ==UDMA_MODE_STOP)[ .... ]中的内容,在执行该通道的中断服务程序时,会启动I2S次接收通道读取语音数据,而I2S次接收通道UDMA_MODE_STOP中断产生时,程序仍然会执行到if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_PRI_SELECT) ==UDMA_MODE_STOP),此时上一次主通道传输结束时的条件ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_PRI_SELECT) ==UDMA_MODE_STOP仍然满足,仍会执行if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_PRI_SELECT) ==UDMA_MODE_STOP)[ .... ]中的语句,而不会执行。
而I2S发送通道开启后,I2S发送通道产生中断时,进入中断处理函数,会遇到if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_PRI_SELECT) ==UDMA_MODE_STOP)不满足条件的情况,这时才会执行else if(ROM_uDMAChannelModeGet(UDMA_CHANNEL_I2S0RX | UDMA_ALT_SELECT) ==UDMA_MODE_STOP) [ ... ]中的语句。 |
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1755浏览 29评论
2780浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1721浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1633浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1643浏览 13评论
/9
GMT+8, 2025-12-1 10:48 , Processed in 0.666968 second(s), Total 58, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2309
