电子发烧友论坛|
使用CCS v6烧写TSM320F28027的时候出现如下警告:
waring:entry_point symbol other than "c_int00" specified:"code_start" 请教这个会影响程序烧写吗? |
3 个讨论
官方的文档《2802x C/C++ Header Files and Peripheral Examples Quick Start》中有这样一段:
When I build the examples, the linker outputs the following: warning: entry point other than _c_int00 specified. What does this mean? This warning is given when a symbol other then _c_int00 is defined as the code entry point of the project. For these examples, the symbol code_start is the first code that is executed after exiting the boot ROM code and thus is defined as the entry point via the –e linker option. This symbol is defined in the DSP2802x_CodeStartBranch.asm file. The entry point symbol is used by the debugger and by the hex utility. When you load thecode, CCS will set the PC to the entry point symbol. By default, this is the _c_int00 symbol which marks the start of the C initialization routine. For the DSP2802x examples,the code_start symbol is used instead. Refer to the source code for more information. |
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 18:47 , Processed in 0.728460 second(s), Total 55, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1599
