电子发烧友论坛|
bootloader未修改 放入mcuimg.bin中
oob例程未修改 放入mcuimg1.bin中 能正常启动oob文件网页什么都正常就是sta模式就卡死 但是 通过网页设置为sta模式 程序就会卡死 while(uiConnecttimeoutCnt [ //Turn RED LED On GPIO_IF_LedOn(MCU_RED_LED_GPIO); osi_Sleep(50); //Turn RED LED Off GPIO_IF_LedOff(MCU_RED_LED_GPIO); osi_Sleep(50); uiConnectTimeoutCnt++; ] 程序在这里死掉了 sta例程也是同样死掉了 能说明下为什么么? [18:01:25] Begin Format operation. [18:01:25] INFO: > Executing Operation: Connect [18:01:27] INFO: setting break signal [18:01:27] INFO: connection succeeded [18:01:27] INFO: getting storage list [18:01:28] INFO: > Executing Operation: Init [18:01:28] INFO: reading version info [18:01:28] INFO: DEVICE CC3200 ES1.32 [18:01:28] INFO: reading version info [18:01:29] INFO: reading version info [18:01:31] INFO: > Executing Operation: Format [18:01:31] INFO: Erase storage SFLASH [18:01:32] INFO: erase storage succeeded [18:01:32] INFO: erase storage completed [18:01:32] INFO: > Executing Operation: Disconnect [18:01:32] Operation Format returned. [18:01:35] Begin Program operation. [18:01:35] INFO: > Executing Operation: Connect [18:01:37] INFO: setting break signal [18:01:38] INFO: detecting FTDI for device reset [18:01:39] INFO: connection succeeded [18:01:39] INFO: getting storage list [18:01:39] INFO: > Executing Operation: Init [18:01:39] INFO: reading version info [18:01:39] INFO: DEVICE CC3200 ES1.32 [18:01:39] INFO: reading version info [18:01:41] INFO: reading version info [18:01:43] INFO: > Executing Operation: Program [18:01:43] INFO: > File name: /sys/mcuimg.bin, Update: true, Erase: true [18:01:43] INFO: > Erase File: /sys/mcuimg.bin [18:01:43] INFO: erasing file "/sys/mcuimg.bin" [18:01:43] INFO: deleting file "/sys/mcuimg.bin" [18:01:43] INFO: erase file completed [18:01:43] INFO: > Size of file = 13952 [18:01:43] INFO: > Update File: /sys/mcuimg.bin [18:01:43] INFO: Downloading file "/sys/mcuimg.bin" with size 13952 [18:01:44] INFO: New Token is 0x0 [18:01:44] INFO: Download complete [18:01:44] INFO: Verifying Data... [18:01:44] INFO: get file [18:01:45] INFO: Done. Reading 13952 bytes [18:01:45] INFO: Verification OK [18:01:46] INFO: > Updated Token value: 0x0 [18:01:46] INFO: > File name: /cert/ca.pem, Update: false, Erase: false [18:01:46] INFO: > File name: /cert/client.pem, Update: false, Erase: false [18:01:46] INFO: > File name: /cert/private.key, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/macadd.bin, Update: false, Erase: true [18:01:46] INFO: > Erase File: /sys/macadd.bin [18:01:46] INFO: erasing file "/sys/macadd.bin" [18:01:46] INFO: deleting file "/sys/macadd.bin" [18:01:46] INFO: erase file completed [18:01:46] INFO: > File name: /sys/mode.cfg, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/ipcfg.ini, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/ap.cfg, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/devname.cfg, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/mdns.cfg, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/dhcpsrv.cfg, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/httpsrv.cfg, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/pref.net, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/smartconfigkeys.cfg, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/stacfg.ini, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/p2p.cfg, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/pmcfg.ini, Update: false, Erase: false [18:01:46] INFO: > File name: /sys/mcuimg1.bin, Update: true, Erase: true [18:01:46] INFO: > Erase File: /sys/mcuimg1.bin [18:01:46] INFO: erasing file "/sys/mcuimg1.bin" [18:01:46] INFO: deleting file "/sys/mcuimg1.bin" [18:01:46] INFO: erase file completed [18:01:46] INFO: > Size of file = 48420 [18:01:46] INFO: > Update File: /sys/mcuimg1.bin [18:01:46] INFO: Downloading file "/sys/mcuimg1.bin" with size 48420 [18:01:49] INFO: New Token is 0x0 [18:01:49] INFO: Download complete [18:01:49] INFO: Verifying Data... [18:01:49] INFO: get file [18:01:50] INFO: Done. Reading 48420 bytes [18:01:50] INFO: Verification OK [18:01:51] INFO: > Updated Token value: 0x0 [18:01:51] INFO: > Executing Operation: Disconnect [18:01:51] Operation Program returned. [18:01:54] Begin ListFileSystem operation. [18:01:55] INFO: > Executing Operation: Connect [18:01:57] INFO: setting break signal [18:01:58] INFO: detecting FTDI for device reset [18:01:59] INFO: connection succeeded [18:01:59] INFO: getting storage list [18:01:59] INFO: > Executing Operation: Init [18:01:59] INFO: reading version info [18:01:59] INFO: DEVICE CC3200 ES1.32 [18:01:59] INFO: reading version info [18:02:01] INFO: reading version info [18:02:03] INFO: > Executing Operation: ListFileSystem [18:02:03] INFO: extracting file system information... [18:02:03] INFO: Serial Flash block size: 4096 bytes [18:02:03] INFO: Serial Flash capacity: 2048 blocks [18:02:03] INFO: file start size fail total size filename [18:02:03] INFO: index block [BLKs] safe [BLKs] [18:02:03] INFO: ---------------------------------------------------------------------------- [18:02:03] INFO: N/A 0 5 N/A 5 FATFS [18:02:03] INFO: 0 15 4 yes 8 /sys/mcuimg.bin [18:02:03] INFO: 4 5 5 yes 10 /tmp/phy.cal [18:02:03] INFO: 6 23 12 yes 24 /sys/mcuimg1.bin [18:02:03] INFO: [18:02:03] INFO: Flash usage [18:02:03] INFO: ------------------------- [18:02:03] INFO: used space: 47 blocks [18:02:03] INFO: free space: 2001 blocks [18:02:03] INFO: memory hole: [47-2047] [18:02:03] INFO: > Executing Operation: Disconnect [18:02:03] Operation ListFileSystem returned. |
7 个讨论
zsl1220548 发表于 2020-6-16 07:19 你芯片的版本读出来怎么是1.32的,这个版本是以前工程样品的版本。量产的芯片版本是1.33. 如果有答案已经回答了您的问题,请标注为已回答。 Please close your question if it has been solved. ------------------------------------------------------------------ |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 19:31 , Processed in 0.943942 second(s), Total 62, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1542
