电子发烧友论坛|
专家您好:
我用的是28034,需要AD以下功能: 1.同时采样模式,且同时采样4个AD通道 2.触发源都是PWM2_SOCA 3.等4个AD转换完成后触发ADCINT1中断,只此一个中断即可 以下是我的配置代码,请帮忙审核,谢谢 EALOW; AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 1; //SOC0/SOC1同时采样 //SOC0 AdcRegs.ADCSOC0CTL.bit.ACQPS=6;//SOC0采样窗口 AdcRegs.ADCSOC0CTL.bit.CHSEL = 0; //soc通道选择A0 ---ADCRESULT0 AdcRegs.ADCSOC0CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA //SOC1 AdcRegs.ADCSOC1CTL.bit.ACQPS=6;//SOC1采样窗口 AdcRegs.ADCSOC1CTL.bit.CHSEL = 8; //soc通道选择B0 ---ADCRESULT1 AdcRegs.ADCSOC1CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA AdcRegs.ADCSAMPLEMODE.bit.SIMULEN2 = 1; //SOC2/SOC3同时采样 //SOC2 AdcRegs.ADCSOC0CTL.bit.ACQPS=6;//SOC2采样窗口 AdcRegs.ADCSOC0CTL.bit.CHSEL = 1; //soc通道选择A1 ---ADCRESULT2 AdcRegs.ADCSOC0CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA //SOC3 AdcRegs.ADCSOC1CTL.bit.ACQPS=6;//SOC3采样窗口 AdcRegs.ADCSOC1CTL.bit.CHSEL = 9; //soc通道选择B1 ---ADCRESULT3 AdcRegs.ADCSOC1CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //结果存入寄存器才产生中断 PieVectTable.ADCINT1 = &ADC_convered; !!!AdcRegs.INTSEL1N2.bit.INT1SEL = 1; //中断线1选择soc1 !!!AdcRegs.INTSEL1N2.bit.INT1CONT = 0; AdcRegs.INTSEL1N2.bit.INT1E = 1; //中断使能 PieCtrlRegs.PIEIER1.bit.INTx1 = 1; //使能int1.1 EDIS; 加!!!标注的句子是网上的例程,有点看不明白。唉 |
4 个讨论
Seven,
你的配置有问题。 EALOW; AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 1; // 这个配置表示SOC0,SOC1同时采样 AdcRegs.ADCSAMPLEMODE.bit.SIMULEN1 = 1; //这个配置表示SOC2,SOC3同时采样。 //SOC0 这里要SOC0 SOC1同时 采样 A0,B0 AdcRegs.ADCSOC0CTL.bit.ACQPS=6;//SOC0采样窗口 AdcRegs.ADCSOC0CTL.bit.CHSEL = 0; //soc通道选择A0 ---ADCRESULT0 AdcRegs.ADCSOC0CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA //SOC2 这里要SOC2同时采样 A1,B1 AdcRegs.ADCSOC2CTL.bit.ACQPS=6;//SOC1采样窗口 AdcRegs.ADCSOC2CTL.bit.CHSEL = 1; //soc通道选择B0 ---ADCRESULT1 AdcRegs.ADCSOC2CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA Eric - ERIC |
那底下的这些呢?能否完成转换完成后触发ADCINT1中断的功能?谢谢: AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //结果存入寄存器才产生中断 PieVectTable.ADCINT1 = &ADC_convered; !!!AdcRegs.INTSEL1N2.bit.INT1SEL = 1; //中断线1选择soc1 !!!AdcRegs.INTSEL1N2.bit.INT1CONT = 0; AdcRegs.INTSEL1N2.bit.INT1E = 1; //中断使能 PieCtrlRegs.PIEIER1.bit.INTx1 = 1; //使能int1.1 EDIS; 加!!!标注的句子是网上的例程,有点看不明白。唉 |
广州洋钒 发表于 2020-6-8 16:09 AdcRegs.INTSEL1N2.bit.INT1SEL = 1; AdcRegs.INTSEL1N2.bit.INT1CONT = 0; 这两句的功能是设置 ADCINT1 这一中断的中断源为 EOC1,即在 SOC1 所触发的 ADC 操作结束之后触发 ADCINT1 的中断响应函数;并将中断标志位设置为单次触发等待清除。 具体请参考技术文档中关于 INTSELxNy 寄存器的说明:http://www.ti.com.cn/cn/lit/ug/spruge5f/spruge5f.pdf |
只有小组成员才能发言,加入小组>>
586 浏览 0 评论
1643 浏览 0 评论
2082 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1534 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1374 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1784浏览 29评论
2811浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1742浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1655浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1673浏览 13评论
/9
GMT+8, 2025-12-10 12:43 , Processed in 0.739505 second(s), Total 68, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1908
