电子发烧友论坛|
EPwm1Regs.TBPRD = 500; // Period = 500 TBCLK counts
EPwm1Regs.TBPHS.half.TBPHS = 0; // Set Phase register to zero EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Asymmetrical mode EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Master module EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1 ; EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Sync down-stream module EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET; // set actions for EPWM1A EPwm1Regs.AQCTLA.bit.PRD = AQ_CLEAR; EPwm2Regs.TBPRD = 500; // Period = 500 TBCLK counts EPwm2Regs.TBPHS.half.TBPHS = 0; // Set Phase register to zero EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Asymmetrical mode EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Master module EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1 ; EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // Sync down-stream module EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm2Regs.AQCTLA.bit.ZRO = AQ_SET; // set actions for EPWM1A EPwm2Regs.AQCTLA.bit.PRD = AQ_CLEAR; |
楼主你好,
设置同步以后,主同步ePWM模块和其他被同步的ePWM单元间会有计数值差,其它被同步的单元之间计数值是一样的。 这一点规格书里有详细描述如下: EPWMxSYNCI: Synchronization Input Pulse: The value of the phase register is loaded into the counter register when an input synchronization pulse is detected (TBPHS ® TBCTR). This operation occurs on the next valid time-base clock (TBCLK) edge. The delay from internal master module to slave modules is given by: – if ( TBCLK = SYSCLKOUT): 2 x SYSCLKOUT – if ( TBCLK != SYSCLKOUT):1 TBCLK |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 00:47 , Processed in 0.930139 second(s), Total 55, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3980
