电子发烧友论坛|
如下述代码所示,加入处理notify和indicate的分支
else if ( pMsg->method == ATT_HANDLE_VALUE_NOTI || pMsg->method == ATT_HANDLE_VALUE_IND ) static void simpleBLECentralProcessGATTMsg( gattMsgEvent_t *pMsg )[ if ( simpleBLEState != BLE_STATE_CONNECTED ) [ // In case a GATT message came after a connection has dropped, // ignore the message return; ] if ( ( pMsg->method == ATT_READ_RSP ) || ( ( pMsg->method == ATT_ERROR_RSP ) && ( pMsg->msg.errorRsp.reqOpcode == ATT_READ_REQ ) ) ) [ if ( pMsg->method == ATT_ERROR_RSP ) [ uint8 status = pMsg->msg.errorRsp.errCode; //LCD_WRITE_STRING_VALUE( "Read Error", status, 10, HAL_LCD_LINE_1 ); ] else [ // After a successful read, display the read value uint8 valueRead = pMsg->msg.readRsp.value[0]; //LCD_WRITE_STRING_VALUE( "Read rsp:", valueRead, 10, HAL_LCD_LINE_1 ); ] simpleBLEProcedureInProgress = FALSE; ] else if ( ( pMsg->method == ATT_WRITE_RSP ) || ( ( pMsg->method == ATT_ERROR_RSP ) && ( pMsg->msg.errorRsp.reqOpcode == ATT_WRITE_REQ ) ) ) [ if ( pMsg->method == ATT_ERROR_RSP == ATT_ERROR_RSP ) [ uint8 status = pMsg->msg.errorRsp.errCode; //LCD_WRITE_STRING_VALUE( "Write Error", status, 10, HAL_LCD_LINE_1 ); ] else [ // After a succesful write, display the value that was written and increment value //LCD_WRITE_STRING_VALUE( "Write sent:", simpleBLECharVal++, 10, HAL_LCD_LINE_1 ); ] simpleBLEProcedureInProgress = FALSE; ] else if ( pMsg->method == ATT_HANDLE_VALUE_NOTI || pMsg->method == ATT_HANDLE_VALUE_IND ) [ if(pMsg->msg.handleValueNoti.handle == 0x001B) [ //在此处处理notify,注意对应的handle替换成正确的值 ] else if(pMsg->msg.handleValueInd.handle == 0x001F) [ //在此处处理indicate,注意对应的handle替换成正确的值 ATT_HandleValueCfm(simpleBLEConnHandle); ] ] else if ( simpleBLEDiscState != BLE_DISC_STATE_IDLE ) [ simpleBLEGATTDiscoveryEvent( pMsg ); ] ] |
只有小组成员才能发言,加入小组>>
590 浏览 0 评论
1645 浏览 0 评论
2084 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1537 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1376 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1788浏览 29评论
2816浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1746浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1662浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1676浏览 13评论
/9
GMT+8, 2025-12-12 05:25 , Processed in 0.537863 second(s), Total 47, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
553
