电子发烧友论坛|
最近刚刚上手CC1310,空间限制很大而由于市面上很难找到2.0*1.6封装晶振的ESR是小于60欧姆的晶振,请问是否可以支持无源晶振?
1 个讨论
推荐其他几颗CC2640上用的24M晶振http://processors.wiki.ti.com/index.php/CC26xx_Crystals
如果自己选其他型号的话,参考这篇文档 http://www.ti.com/general/docs/lit/getliterature.tsp?baseLiteratureNumber=swra495&fileType=pdf • Crystals must be selected to meet CC26xx and CC13xx data sheet or specification requirements – ESR must not be greater than can be driven by – CC26xx and CC13xx (60 Ω for the 24-MHz crystal). Capacitive loading and frequency tolerance must meet the specifications of the standard used (for example, Bluetooth) – Motional inductance must also meet specifications. Many crystal manufactures provide only motional inductance data upon customer request. TI has tested crystals with motional inductances up to the value specified in the CC2650 SimpleLink ™ Multistandard Wireless MCU data sheet (SWRS158). • Configuring the device – The required tuning capacitance of the 24-MHz crystal cannot lie outside of 2 – 11 pF unless external tuning capacitors are used. NOTE: To achieve reliable results, keep the required tuning capacitance from 5 to 9 pF though a wider tuning range can be set. • Some other considerations when selecting a crystal include the following: – To improve start-up time and reduce power consumption, the crystal must have the following: • Low-capacitive loading, at the expense of greater susceptability to frequency variation caused by the environment • Low-motional inductance • Low-motional resistance |
只有小组成员才能发言,加入小组>>
600 浏览 0 评论
1653 浏览 0 评论
2095 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1385 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1680浏览 13评论
/9
GMT+8, 2025-12-14 14:30 , Processed in 0.569907 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3346
