电子发烧友论坛|
SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ| SYSCTL_OSC_MAIN); SysCtlPeripheralEnable( SYSCTL_PERIPH_I2C0 ); SysCtlPeripheralEnable( SYSCTL_PERIPH_GPIOB ); //配置相应控制端口 GPIOPinConfigure( GPIO_PB3_I2C0SDA ); GPIOPinConfigure( GPIO_PB2_I2C0SCL ); GPIOPinTypeI2CSCL( GPIO_PORTB_BASE, GPIO_PIN_2 ); GPIOPinTypeI2C( GPIO_PORTB_BASE, GPIO_PIN_3 ); //设置I2C模块传输速率,并使能主机控制功能 I2CMasterInitExpClk( I2C0_BASE, SysCtlClockGet(), false ); I2CMasterEnable( I2C0_BASE ); // // Enable and configure the GPIO port for the LED operation. // SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED); I2CMasterSlaveAddrSet( I2C0_BASE, 0x50, false); I2CMasterDataPut( I2C0_BASE, 0x00 ); //写入主机数据(寄存器地址) while( I2CMasterErr(I2C0_BASE) | I2CMasterBusy(I2C0_BASE) ); I2CMasterControl( I2C0_BASE, I2C_MASTER_CMD_BURST_SEND_START ); //主机数据开始传输 while( I2CMasterErr(I2C0_BASE) | I2CMasterBusy(I2C0_BASE) ); I2CMasterDataPut( I2C0_BASE, 0x06 ); //写入主机数据(寄存器内容) while( I2CMasterErr(I2C0_BASE) | I2CMasterBusy(I2C0_BASE) ); I2CMasterControl( I2C0_BASE, I2C_MASTER_CMD_SINGLE_SEND ); //主机数据+stop传输 while( I2CMasterErr(I2C0_BASE) | I2CMasterBusy(I2C0_BASE) ); I2CMasterSlaveAddrSet( I2C0_BASE, 0x50, false); //????′?ê?·??ò?a?÷?úD′ I2CMasterDataPut( I2C0_BASE, 0x20 ); //D′è??÷?úêy?Y(êy?Y??′??÷μ??·) while( I2CMasterErr(I2C0_BASE) | I2CMasterBusy(I2C0_BASE) ); I2CMasterControl( I2C0_BASE, I2C_MASTER_CMD_SINGLE_SEND ); while( I2CMasterErr(I2C0_BASE) | I2CMasterBusy(I2C0_BASE) ); // // Loop Forever // while(1) [ // // Turn on the LED // GPIOPinWrite(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED, RED_LED); I2CMasterSlaveAddrSet( I2C0_BASE, 0x50, true); I2CMasterControl( I2C0_BASE, I2C_MASTER_CMD_SINGLE_RECEIVE ); //μ¥′??óê? while( I2CMasterErr(I2C0_BASE) | I2CMasterBusy(I2C0_BASE) ); Result_H = I2CMasterDataGet( I2C0_BASE ); // // Delay for a bit // SysCtlDelay(2000000); // // Turn on the LED // GPIOPinWrite(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED, BLUE_LED); // // Delay for a bit // SysCtlDelay(2000000); ]
可以读其他的,就是不能读写AT24C01,好奇怪 |
4 个讨论
给你个24c02的测试代码,还是觉得你器件地址的问题
This is the code that has worked for me:MY SLAVE ADDR = 0x50THE CODE WAS ORIGINALLY GIVEN IN SEPARATE FORUMS HERE... I HAVE JUST MODIFIED A BIT ACCORDING TO MY USEI2C MODULE USED = I2C1HAVE SAVED SOME DATA AND RECALLED IT BACK USING REPEATED START TECHNIQUE.THIS CODE I HAVE TESTED WITH PA6 = SCL & PA7 = SDA AND WORKD FINE WITH 24C02#include |
ljmlvmd 发表于 2019-9-5 10:22 我试了一下,还是一样的死掉了,如果说是芯片坏了的话,我试了好几个了。真不知道为什么 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 07:23 , Processed in 0.949181 second(s), Total 62, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3271
