电子发烧友论坛|
大家好,我最近打算在 DM8168 平台上使用 ti 的 AER 库,版本为 AER version 17.0.0 ,按照提示进行如下修改:
XDC_INSTALL_DIR := /opt/DVRRDK_03.00.00.00/ti_tools/xdc/xdctools_3_23_03_53 XDAIS_INSTALL_DIR := /opt/DVRRDK_03.00.00.00/ti_tools/xdais/xdais_7_22_00_03 export SDOARCH_INSTALL_DIR := /tmp/sdoarch/sdoarch_standards_1_00_00/packages export C64CODEGENTOOL := /opt/DVRRDK_03.00.00.00/ti_tools/cgt_dsp/cgt6x_7_3_5 export MVARM9CGTOOL := /apps/montavista/mv_pro_4.0.1-gt/arm_v5t_le/1/montavista/pro/devkit/arm/v5t_le export GCARMV6CGTOOL := /opt/DVRRDK_03.00.00.00/ti_tools/cgt_a8/arm-2009q1 export GCARMV7ACGTOOL := /opt/DVRRDK_03.00.00.00/ti_tools/cgt_a8/arm-2009q1 export GCARMV7ACGTOOLHFP := /home/davinci/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux export TI_DOXYGEN_TEMPLATES := /apps/ti/doxygen/TI_Templates/10-01-2007 export DOXYGEN_INSTALL_DIR := /apps/ti/doxygen/doxygen/1.4.6-15.2/bin export XDCBUILDCFG := /home/davinci/AER/packages/ti/mas/swtools/config.bld export COVPATH := /apps/cmdevtools/coverity/prevent-linux-3.8.0 export MAS_INSTALL_DIR := /home/davinci/AER/packages 没有编译成功,报错如下: .libraries files complete: Tue Jun 28 09:29:54 CST 2016. ======== .dlls [/home/davinci/AER/packages/ti/mas/swtools] ======== ======== .dlls [/home/davinci/AER/packages/ti/mas/aer/test] ======== .dlls files complete: Tue Jun 28 09:29:54 CST 2016. ======== .executables [/home/davinci/AER/packages/ti/mas/swtools] ======== ======== .executables [/home/davinci/AER/packages/ti/mas/aer/test] ======== gmake[2]: *** No rule to make target `all'. Stop. gmake[1]: [make_dependent] Error 2 (ignored) gmake[2]: *** No rule to make target `all'. Stop. gmake[1]: [make_dependent] Error 2 (ignored) gmake[2]: *** No rule to make target `all'. Stop. gmake[1]: [make_dependent] Error 2 (ignored) gmake[2]: *** No rule to make target `all'. Stop. gmake[1]: [make_dependent] Error 2 (ignored) clv7A ./aersim/aersim.c ... if [ ! -d package/cfg/lnkr/gcarmv7a/aertest_cortexA8/./aersim ]; then mkdir -p package/cfg/lnkr/gcarmv7a/aertest_cortexA8/./aersim ; fi; ld: failed to merge target specific data of file /home/davinci/AER/packages/ti/mas/util/lib/util_c.av7A(utilnum.ov7A) /opt/DVRRDK_03.00.00.00/ti_tools/cgt_a8/arm-2009q1/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/../../../../arm-none-linux-gnueabi/bin/ld: error: /home/davinci/AER/packages/ti/mas/util/lib/util_c.av7A(wngnum.ov7A) uses VFP register arguments, lnkr/gcarmv7a/aertest_cortexA8.xv7A does not /opt/DVRRDK_03.00.00.00/ti_tools/cgt_a8/arm-2009q1/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/../../../../arm-none-linux-gnueabi/bin/ld: failed to merge target specific data of file /home/davinci/AER/packages/ti/mas/util/lib/util_c.av7A(wngnum.ov7A) collect2: ld returned 1 exit status gmake[2]: *** [lnkr/gcarmv7a/aertest_cortexA8.xv7A] Error 1 gmake[1]: *** [lnkr/gcarmv7a/aertest_cortexA8.xv7A] Error 2 gmake: *** [/home/davinci/AER/packages/ti/mas/aer/test,.executables] Error 2 make: *** [all] Error 2 请问是否有人成功包 AER 和 dm8168 的 DVRDK 成功结合使用? |
4 个讨论
物是人非aaa 发表于 2019-8-27 17:11 非常感谢您的回答。我编译的是A8 的软件,而且我也注意到和文档软件不一致的问题。 Linaro ARM Linux 2013.03 for hard floating point. 可以在TI WIKI 中的论坛中找到并且下载,请问 Codesourcery tools Arm 2009 Q1 for soft floating point 去哪里下载呢,全名是什么? 而且,如果和 DVR RDK 中默认的编译器不一致,集成到一起使用会不会产生问题?最终采用 Codesourcery tools Arm 2009 Q1 for soft floating point. 作为统一的编译器吗,还是分别采用两个编译器。 |
ryanyhh 发表于 2019-8-27 17:22 Vivian, Code sourcery公司被Mentor Graphic收购了,这个编译器现在不清楚在哪里可以下载。 使用不同的编译环境编译出来的代码在DVR RDK环境下运行,无法评估是否会有怎样的问题。我不建议这样做。 我建议修改一下makefile用arago的编译器来编译AER for A8,或者去e2e论坛上问问。 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 03:04 , Processed in 0.585191 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1094
