电子发烧友论坛|
如果我有一个引脚连接到一个原理图符号(比如一个SPI主块,例如),我能力销到一个给定的状态(高,低,三态)通过单独的软件,或者我要添加一个控制登记和复用的原理吗?
我的用例是一个SPI主机和外部部件和组件有一些非常具体的设置要求,没有SPI。我想把SPI MOSI引脚然后给销回”的SPI模块正常SPI通讯一旦我的外部组件已初始化。 我看了看通过销数据和得到的代码生成的,但我没有看到这样做。添加一个多路复用器和控制登记似乎是一个非常“做这个重”的方式。 以上来自于百度翻译 以下为原文 If I have a pin connected to a schematic symbol (say a SPI Master block, for example), can I force the pin to a given state (high, low, tri-state) through software alone, or do I have to add a control register and mux to the schematic to do this? My use case is a SPI Master talking to an external component, and the component has some very specific setup requirements that are not SPI. I'd like to wiggle the SPI MOSI pin and then "give the pin back" to the SPI module for normal SPI communications once my external component has been initialized. I took a look through the pin datasheet and the resultant code generated, but I didn't see a way to do this. Adding a MUX and control register seems to be an awfully "heavy" way to do this. |
2个回答
再次回答我自己的问题:
查看架构TRM,CyPress给出了GPIO块的框图。(第19.2页第144页,例如5LP)。它专门调用MUX周围的寄存器名,进入驱动逻辑块。PRT[X] BYP控制GPIO引脚是否从DSI或端口的数据寄存器PRT[x] DR获得其输出电平。 如果PIN的示意符号已经正确设置,您就不需要摆弄PRT[x] DM(驱动模式)或PRT[X] BIE(双向控制)寄存器。在PRT[x] DM中写入正确的位的逻辑电平,并将PRT[X] DR位翻转到“0”。当您完成并希望外围设备重新接通时,将PRT [X] DM位设置为“1”,以便PIN从DSI获取其逻辑电平。 这些寄存器的内存地址是在(难读的)登记时间。 以上来自于百度翻译 以下为原文 Answering my own question (again): Looking at the Architecture TRM, Cypress gives a block diagram of the GPIO blocks. (section 19.2 on page 144 for the 5LP, for example). It specifically calls out the register names surrounding the MUX leading into the drive logic block. PRT[x]BYP controls whether the GPIO pin takes its output level from the DSI or the port's data register PRT[x]DR. If the schematic symbol for the pin is already set up correctly you should not need to fiddle with the PRT[x]DM (drive mode) or PRT[x]BIE (bidirectional control) registers. Write the logic level you want to put on the pin to the correct bit in PRT[x]DM and flip PRT[x]DR bit to '0'. When you're done and want the peripheral to take over again, set the PRT[x]DM bit to '1' so the pin takes its logic level from the DSI. The memory addresses for these registers is in the (very difficult to read) Register TRM. |
这可能是赞成的。
HTTP://www. CyPress?COM/?RID=57571 问候,Dana。 以上来自于百度翻译 以下为原文 This might be of assitance - http://www.cypress.com/?rID=57571 Regards, Dana. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 01:55 , Processed in 0.725517 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1651
