我应该先说一下,我已经离开FPGA领域已经有几年了,并且对新一代的Xilinx硬件没有太多帮助。
我来自一所设计理念的学校,它重视低级别的可访问性,清晰度和简单性,我一直在关注Xilinx工具的发展和迷恋。 我早期的设计经验是使用Spartan-3和Virtex-IIProFPGAs。 对我来说,这些芯片的吸引力在于ISE的设计流程以及完全按照我的意愿设计设计的能力,可以自由地实现实现和语法错误(并由ISE指出)。 由于Xilinx已将设计师推向PlanAhead和Vivado,因此设计方向似乎朝着更高层次的方向发展,从设计师那里去除了设计控制的某些方面。 图形架构,C到VHDL HLS,以及(据我所知,我可能是错误的)完全改进的后端消除了简单地编写脚本并修改基于文本的配置文件的能力。 我注意到ISE已进入其生命的“持续”阶段。 这意味着,在未来的某个时刻,ISE的过时将成为一个真正的关注点,以及为其支持的硬件构建的能力。 ISE的最终消亡不仅是一个问题,而且能够获得廉价,简单,裸露的FPGA,只需很少的花哨,如Spartan-6,可以用简单的文本编辑器编写,似乎也在养育 它的头。 所以我想我的问题就是这些。 ISE需要支持多长时间? Spartan-6可以使用多长时间? 有没有计划维护一系列简单的,精简的FPGA? Vivado中是否有(或现在有)选项可以恢复到像Project Navigator这样的低级HDL / UCF设计流程用于裸逻辑设计? 或者Vivado会继续将设计流程从HDL架构转移到高级功能块生成器吗? 谢谢你的时间。 以上来自于谷歌翻译 以下为原文 I should preface this by saying that I've been out of the FPGA field for a couple of years now, and haven't worked much with newer generations of Xilinx hardware. I come from a school of design philosophy that values low-level accessibility, clarity, and simplicity, and I've been watching the progression of Xilinx tools with fascination and a small measure of concern. My early design experiences were with Spartan-3 and Virtex-II Pro FPGAs. For me, the appeal of those chips was the design flow of ISE and the ability to architect a design exactly as I wanted, free to make implementation and syntax errors (and have them pointed out by ISE). As Xilinx has pushed designers toward PlanAhead and then Vivado, it seems like the direction of design is going towards a higher-level picture that removes some aspects of design control from the designer. Graphical architecture, C to VHDL HLS, and a completely revamped backend that (to my knowledge, I could be wrong) eliminates the ability to simply script builds and modify text-based configuration files. I notice that ISE has entered the "sustaining" phase of its life. This implies that at some point down the road, obsolescence of ISE will become a genuine concern, along with the ability to build for its supported hardware. Not only is the eventual demise of ISE a concern, but the ability to obtain cheap, simple, bare FPGAs with few bells and whistles like the Spartan-6 that can be written for with something as simple as a text editor also seems to be rearing its head. So I guess my questions are these. How long will ISE be supported? How long will the Spartan-6 be available? Are there any plans to maintain a line of simple, stripped-down FPGAs? Will there ever be (or is there now) an option in Vivado to revert to a low-level HDL/UCF design flow like Project Navigator for bare logic designs? Or will Vivado just continue to move design flow from an HDL architecture to a high level function block generator? Thanks for your time. |
1个回答
E,
ISE 14.7将得到支持,直到没有理由支持它(没有客户)。 这可能需要很长时间,因为Xilinx的客户需要15年或20年的产品“生命周期”。 即使使用最新的工具和流程,也可以创建一个单独操作的脚本,然后使用该脚本而不是GUI。 这样可以实现极其精细的控制。 您可以选择不使用模糊您的愿景和目标的功能。 产品将继续发展,工具也将不断发展。 但是总是需要深入了解,并且在某些情况下会进入比特流级别(这个位做什么?)。 这听起来像是在工业,航空航天或安全关键市场,因为这些市场都要求一切都是可见的,能够被验证,结果是可重复的。 这代表了Xilinx的一个巨大的增长市场,并且正在积极解决。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 e, ISE 14.7 will be supported until there is no more reason to support it (there are no customers). That could be a long time, as Xilinx has customers who require 15 or 20 years of 'life' for a product. Even with the latest tools and flows, one can create a script of the indivual operations, and then use that script instead of the GUI. That allows an extremely fine level of control. You may choose not to use the features which obscure your vision and goals. The products will continue to evolve, and the tools will evolve also. But there is always a need to get under the hood, and in some cases go down to the bitstream level (what does THIS bit do?). It sounds like you are in an industrial, aerospace, or safety-critical market, as those markets all require that everything is visible, is able to be verified, and results are repeatable, exactly. That represents a large growing market for Xilinx, and is actively being addressed. Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
2323 浏览 7 评论
2736 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2222 浏览 9 评论
3301 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2371 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
663浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
468浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
236浏览 1评论
675浏览 0评论
1870浏览 0评论
GMT+8, 2024-10-5 20:47 , Processed in 1.120969 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
