电子发烧友论坛|
#include
#include #define uchar unsigned char #define uint unsigned int uchar code IC_DAT[]; uchar code pic1[]; uchar code pic2[]; uchar code pic3[]; ***it RS = P0^7; ***it WRD = P0^6; ***it E = P0^5; ***it PSB = P0^4; ***it RES = P0^3; void TransferData(char data1,bit DI); void display(void); void display_grapic(void); void delayms(uint n); void DisplayLine(uchar line1,uchar line2); void Extended Function Set RE=1: extended instruction(uchar code *adder); void delay(uint m); void lcd_mesg(uchar code *adder1); uchar code IC_DAT[]={ " HOT-51 " " " " ?????ú??·?°? " " ???è??×? " }; uchar code IC_DAT2[]={ " 1111111 " //0x80 " 111111111 " //0x90 " 1111111 " //0x88 " 1111111 " //0x98 }; /******************************************************************** ***********************************************************************/ unsigned char Convert(unsigned char In_Date) { unsigned char i, Out_Date = 0, temp = 0; for(i=0; i<8; i++) { //temp = (In_Date >> i) & 0x01; //Out_Date |= (temp << (7 - i)); Out_Date= In_Date; } return Out_Date; } void initinal(void) { delay(40); SB=1; delay(1); RES=0; delay(1); RES=1; delay(10); TransferData(0x30,0); delay(100); TransferData(0x30,0); delay(37); TransferData(0x08,0); delay(100); TransferData(0x10,0); delay(100); TransferData(0x0C,0); delay(100); TransferData(0x01,0); delay(10); TransferData(0x06,0); delay(100); } /******************************************************************** ***********************************************************************/ void initina2(void) // { delay(40); / SB=1; / delay(1); // RES=0; delay(1); delay(10); TransferData(0x36,0); //Extended Function Set RE=1: extended instruction delay(100); TransferData(0x36,0); //Extended Function Set:RE=1: extended instruction set delay(37); TransferData(0x3E,0); //EXFUNCTION(DL=8BITS,RE=1,G=1) delay(100); TransferData(0x01,0); //CLEAR SCREEN delay(100); } /******************************************************************** ***********************************************************************/ void main(void) { while(1) { initina2(); // DisplayGraphic(pic2); // delayms(200); initinal(); // delay(100); //? lcd_mesg(IC_DAT); // delayms(240); delayms(240); initinal(); // delay(100); //? lcd_mesg(IC_DAT2); / delayms(240); delayms(240); initinal(); } } /******************************************************************** ***********************************************************************/ void lcd_mesg(unsigned char code *adder1) { unsigned char i; TransferData(0x80,0); //Set Graphic Display RAM Address delay(100); for(i=0;i<32;i++) { TransferData(*adder1,1); adder1++; } TransferData(0x90,0); //Set Graphic Display RAM Address delay(100); for(i=32;i<64;i++) { TransferData(*adder1,1); adder1++; } } /******************************************************************** ***********************************************************************/ void TransferData(char data1,bit DI) //?? { WRD=0; RS=DI; delay(1); P2=Convert(data1); E=1; delay(1); E=0; } /******************************************************************** ***********************************************************************/ void delayms(unsigned int n) // { unsigned int i,j; for(i=0;i } /******************************************************************** * ***********************************************************************/ void delay(unsigned int m) { unsigned int i,j; for(i=0;i } ***********************************************************************/ void DisplayGraphic(unsigned char code *adder) { int i,j; for(i=0;i<32;i++) // { TransferData((0x80 + i),0); TransferData(0x80,0); / for(j=0;j<16;j++) { TransferData(*adder,1); adder++; } } for(i=0;i<32;i++) // { TransferData((0x80 + i),0); // TransferData(0x88,0); // for(j=0;j<16;j++; { TransferData(*adder,1); adder++; } } } unsigned char code pic2[]= { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x07,0x80,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0x78,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x07,0x80,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x00,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0x00,0x00,0x70,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x03,0xC0,0x00,0x00,0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0x00,0x00,0x01,0xE6,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x3C,0x00,0x00,0x00,0x00,0x07,0x82,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x1E,0x02,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x78,0x03,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x01,0xE0,0x00,0x00,0x00,0x01,0xE0,0x03,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x01,0x78,0x00,0x00,0x00,0x07,0x80,0x01,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x03,0x1E,0x00,0x00,0x00,0x1E,0x00,0x07,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x03,0x07,0x80,0x00,0x00,0x78,0x00,0x1F,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x02,0x01,0xE0,0x00,0x01,0xE0,0x00,0x3F,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x06,0x00,0x78,0x1F,0x07,0x80,0x01,0xF1,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0E,0x00,0x1E,0x3F,0x9E,0x00,0x03,0xF9,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0E,0x00,0x07,0xB3,0x78,0x00,0x0F,0xF9,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0x80,0x01,0xFF,0xE0,0x00,0x79,0x98,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0xE0,0x00,0x7F,0x80,0x00,0xE0,0xD8,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0xF8,0x00,0x0C,0x00,0x07,0xE0,0xF8,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0E,0x7E,0x00,0x0C,0x00,0x1F,0xF0,0xF8,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0E,0x1F,0x80,0x0C,0x00,0x7E,0x70,0xDC,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0x07,0xE0,0x0C,0x01,0xE3,0x70,0x5C,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0x81,0xF8,0x0C,0x07,0x83,0x70,0x5F,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0D,0xE0,0x7E,0x0C,0x1F,0xC1,0xF0,0x5F,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0x78,0x3F,0x8C,0x7F,0xC1,0xB8,0x47,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0x1E,0x0F,0xED,0xEC,0xE1,0xB8,0xC7,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x07,0x83,0xFF,0xC6,0xE1,0xB9,0xC7,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x07,0xE0,0xFF,0xE7,0xE1,0xBF,0x07,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x07,0xF8,0x3F,0xE7,0xE1,0xBF,0x07,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x07,0x9E,0x0C,0xE6,0xE1,0x8F,0x07,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x07,0x87,0x8C,0xE6,0xE3,0x8F,0x83,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x0F,0x81,0xED,0xE6,0xE7,0x0F,0x83,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x07,0x00,0x7F,0xE6,0xFE,0x0F,0x83,0x40,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x00,0x00,0x1E,0x76,0xFE,0x0F,0x83,0x40,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0x72,0x1E,0x0F,0x83,0x40,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0x7E,0x1A,0x0F,0x83,0x40,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0x7C,0x1A,0x0F,0x83,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0C,0x00,0x00,0x00,0x78,0x1A,0x0F,0x83,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x1A,0x07,0x83,0xC0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x1E,0x07,0x80,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x1F,0x07,0x80,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x1F,0x07,0x80,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x1F,0x07,0x80,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x1F,0x07,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x1F,0x00,0x00,0x00,0x00,0x08,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x1F,0x00,0x00,0x00,0x00,0x10,0x00,0x40, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x1F,0x00,0x00,0x00,0x00,0xFF,0x08,0x20, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x1F,0x00,0x00,0x00,0x00,0x28,0x05,0xFC, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0x0C,0x00,0x00,0x00,0x00,0x48,0x00,0x40, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0x00,0x00,0x00,0x00,0x00,0xFF,0x08,0x88, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0x00,0x00,0x00,0x00,0x00,0x08,0x05,0xFC, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,0x4A,0x00,0xA8, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,0x89,0x04,0xA8, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x01,0x08,0x88,0xA8, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x10,0xAA, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x01,0x2E, }; |
2个回答
看函数名称就知道了呀,再说了你知道了又有什么用呢
只有小组成员才能发言,加入小组>>
2071 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4792 浏览 0 评论
4273 浏览 9 评论
3863 浏览 16 评论
4433 浏览 1 评论
4261浏览 3评论
3435浏览 0评论
1203浏览 0评论
2888浏览 0评论
3952浏览 0评论
/9
GMT+8, 2025-12-14 21:33 , Processed in 0.889708 second(s), Total 80, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4523
