电子发烧友论坛|
你好,我们用CR95HF定制了读卡器板。该阅读器与运行linux的IMX6 CPU接口。通过SPI总线与阅读器通信。
我试着阅读DOC9303生物识别护照。我可以毫无问题地以默认速度106 kbit / sec读取它,现在我试图设置双速212 kbit / sec我在ISO14443A-4激活后遇到通信问题。 PPS响应后没有任何答案。 看起来像一些等待时间常数或类似的其他模拟寄存器设置的问题。 对于不同的数据波特率,是否有任何提示或一组这样的常量? WBR #cr95hf#iso14443a 以上来自于谷歌翻译 以下为原文 Hello, we made custom reader board with CR95HF. This reader is interfaces with IMX6 CPU running linux. Communication with reader via SPI bus. I tried to read DOC9303 biometric passport. I can read it on default speed 106 kbit/sec without problem, now i'm trying to set double speed 212 kbit/sec i have problems with communication after ISO14443A-4 activation. There is no any answer after PPS responce. Looks like the problem with some of wait time constant or similar other setting for Analog registers. Is there any hints or set of such constants for different data baud rates? WBR #cr95hf #iso14443a |
2个回答
你好egor,
CR95HF支持ISO 14443A中的数据速率212 kbps 您必须以106kps的速度启动通信 执行防冲突序列和RATS请求命令 然后用适当的设置PPS 04 04 D0 11 05 28 05表示第3字节数据的212kbps。 然后,您必须通过在CR95HF上执行新的协议选择来更改读取器速度 我建议以下命令。 02 04 02 50 02 80 在您应该能够从标记中获取响应之后,使用选择的应用程序命令作为示例 问候 P 以上来自于谷歌翻译 以下为原文 Hello egor, The CR95HF support the datarate 212 kbps in ISO 14443A You have to 1st initiate the communication at 106kps perform your anticollision sequence and RATS request command Then the PPS with the appropriate setting 04 04 D0 11 05 28 05 means 212 kbps for the 3rd byte of data. Then you will have to change the reader speed by performing a new protocol select on the CR95HF I suggest the following command. 02 04 02 50 02 80 After you should be able to get the response from your tag, with a select application command for exemple Regards P |
你好。
我们决定不使用STM RF芯片,因为它记录非常糟糕,并且没有制造商的支持。我们搬到了恩智浦读卡器。 STM太糟糕了 - 他们制造芯片,但没有制作好的文件和支持! 以上来自于谷歌翻译 以下为原文 Hello. We decided not to use STM RF chips as it is very bad documented and does not have manufactorer support. We moved to NXP readrs. Too bad for STM - they make chips, but not make good documents and support! |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1469 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1521 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3860 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
747浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
680浏览 5评论
726浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
968浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
770浏览 5评论
/9
GMT+8, 2025-12-11 18:45 , Processed in 1.187088 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1383
